Topic "v.4.0.1: "Check for Updates" and "Languages" / "Get More...""
Hilarion
In 4.0.1 version "Check for Updates" does not work (it does nothing). Same with "Languages" / "Get More...".
I'm sure that "Check for Updates" worked in 4.0.0. I do not know if "Languages" / "Get More..." did.
Ikarosz
Check for updates seems to work for me, but it does something different than in 4.0.0 ... The "flash" icon is always red (I'm not sure, but I think it used to be yellow when there were no updates) and when I click on it, a window comes up with three buttons:
Quote:
You have the latest version.
Jdi na seznam
[Go to] [OK] [Help]
The Go to button opens a browser window with http://www.seznam.cz/
For 4.0.1 I got the multilingual installation package (previously I had the English version), I don't know if this makes a difference.
Renwick
Same issue here. I also cannot use the hungarian translation included in the 4.0.1 multilingual installation, because the program gives me an error message that it contains translation for WinSCP 4.0, and I should remove the file. Confused
regards
R.
Ikarosz
"Check for updates" and the Hungarian translation are working now in 4.0.2.
Hilarion
I confirm that in 4.0.2 version everything is working now.
Ikarosz: I was not writing about the icon in toolbar (in opened session window), but about the button which is visible in session selection window. It was not working at all (at least for me) in 4.0.1.
PS.: Polish translation was not working for 4.0.1 version. It's working in 4.0.2.
