Topic "Cant minimize."
Lukas
Using "Keep remote directory up to date" with "synchronize options"
-Update subdirectories
-Synchronize on start
If on synchronize, remote directory is updated, then the minimize button don't work, and window do not minimize. Problem happen with option "Delete Files" too if remote files are deleted.
Lukas
Sorry. I forget to say...
It happens with version 4.0.2 as well as 4.0.0
Thanks.
Thanks for your report. I'll check it.
mdknapp
I can confirm that my client (4.0.2 and 4.0.0) won't minimize when I "Keeping remote directory up to date". After the initial synchronize the "Minimize" button does not minimize WinSCP.
This has been fixed in 4.0.3.
