Topic "Automatic update on opening directory"
Bar
I've got a problem with WinSCP not updating directory information on opening a directory. Kind of showing last information (cache).
For instance, when I double click a folder, if there is a new file or file sizes have changed since last time visited, this information is not updated. So I have to hit the refresh button every time I change to a directory to make sure its listing is up to date, which is annoying. This happens both in sftp and ftp sites.
At the other end, when I add, delete or edit a file within a directory, the update is done instantly, as expected.
Can you check automatic update on opening directory?
I'm using WinSCP 4.0.2 Beta on XP.
Blessings,
Bar.
Please read documentation.
Bar
I disabled directory caching at all and now windows refresh is done immediatly when opened.
Thanks a million.
Blessings,
Bar.
