Topic "problems with different windows-users"
guest
I have a strange problem:
My WinXP-Professional has 10 User-Accounts iwth own login. Now, I installed WinSCP under user "MisterX" in the programs-directory. All works fine, I can transfer files etc.
Now, I wanna let User "Mister Z" use WinSCP,too. What I done is, setting a shortcut to programs/Winscp/etc and place that shortcut on the desktop of "Mister Z".
But now came the problem: Every time, I wanna login, comes an extra-popup-window where I should insert the password. But the password is not accepted, although it's definetly right.
After deinstalling and re-install under User "Mister Z" it doesn't work yet, but if reinstall under "Mister X" it works...
What is the problem here ? Does I have to change the registry ?
Swen
Please post a log file for "Mister Z"
guest
which log-file do I have to post ? I can't find one in the winscp-directory...
guest
ok, I found to activate loggin in WinSCP. Will post the file soon...
sorry
guest
Here my log-file:
. 2007-06-19 15:35:24.250 --------------------------------------------------------------------------
. 2007-06-19 15:35:24.250 WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 2)
. 2007-06-19 15:35:24.250 Login time: Dienstag, 19. Juni 2007 15:35:24
. 2007-06-19 15:35:24.250 Session name: tierschutz@139.18.233.235
. 2007-06-19 15:35:24.250 Host name: 139.18.233.235 (Port: 22)
. 2007-06-19 15:35:24.250 User name: tierschutz (Password: Yes, Key file: No)
. 2007-06-19 15:35:24.250 Transfer Protocol: SFTP (SCP)
. 2007-06-19 15:35:24.250 SSH protocol version: 2; Compression: No
. 2007-06-19 15:35:24.250 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-06-19 15:35:24.250 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-06-19 15:35:24.250 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-06-19 15:35:24.250 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-06-19 15:35:24.250 SFTP Bugs: -,-,-
. 2007-06-19 15:35:24.250 Proxy: none
. 2007-06-19 15:35:24.250 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-06-19 15:35:24.250 Shell: default, EOL: 0
. 2007-06-19 15:35:24.250 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-06-19 15:35:24.250 Cache directory changes: Yes, Permanent: Yes
. 2007-06-19 15:35:24.250 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-06-19 15:35:24.250 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-06-19 15:35:24.250 Looking up host "139.18.233.235"
. 2007-06-19 15:35:24.250 Connecting to 139.18.233.235 port 22
. 2007-06-19 15:35:24.609 Server version: SSH-1.99-OpenSSH_4.4
. 2007-06-19 15:35:24.609 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2007-06-19 15:35:24.609 Using SSH protocol version 2
. 2007-06-19 15:35:24.609 Doing Diffie-Hellman group exchange
. 2007-06-19 15:35:24.656 Doing Diffie-Hellman key exchange
. 2007-06-19 15:35:24.968 Host key fingerprint is:
. 2007-06-19 15:35:24.968 ssh-rsa 1024 4b:34:59:39:7e:d1:e0:82:77:e5:1e:0c:5b:bb:2b:9b
. 2007-06-19 15:35:24.968 Initialised AES-256 client->server encryption
. 2007-06-19 15:35:24.968 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-06-19 15:35:24.968 Initialised AES-256 server->client encryption
. 2007-06-19 15:35:24.968 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-06-19 15:35:25.015 Using username "tierschutz".
! 2007-06-19 15:35:25.062 Using keyboard-interactive authentication.
. 2007-06-19 15:35:25.062 Password: prompt from server
. 2007-06-19 15:35:25.062 Responding with stored password.
! 2007-06-19 15:35:25.062 Authenticating with pre-entered password.
! 2007-06-19 15:35:25.062 Access denied.
. 2007-06-19 15:35:25.062 Access denied
! 2007-06-19 15:35:25.078 Using keyboard-interactive authentication.
. 2007-06-19 15:35:25.078 Password: prompt from server
. 2007-06-19 15:35:25.078 Asking user for response.
! 2007-06-19 15:35:28.640 Access denied.
. 2007-06-19 15:35:28.640 Access denied
! 2007-06-19 15:35:28.656 Using keyboard-interactive authentication.
. 2007-06-19 15:35:28.656 Password: prompt from server
. 2007-06-19 15:35:28.656 Asking user for response.
! 2007-06-19 15:35:29.187 Access denied.
. 2007-06-19 15:35:29.187 Access denied
! 2007-06-19 15:35:29.187 Using keyboard-interactive authentication.
. 2007-06-19 15:35:29.187 Password: prompt from server
. 2007-06-19 15:35:29.187 Asking user for response.
! 2007-06-19 15:35:29.546 Access denied.
. 2007-06-19 15:35:29.546 Access denied
! 2007-06-19 15:35:29.562 Using keyboard-interactive authentication.
. 2007-06-19 15:35:29.562 Password: prompt from server
. 2007-06-19 15:35:29.562 Asking user for response.
. 2007-06-19 15:35:32.218 Unable to authenticate
. 2007-06-19 15:35:32.218 Attempt to close connection due to fatal exception:
* 2007-06-19 15:35:32.218 Unable to authenticate
. 2007-06-19 15:35:32.218 Closing connection.
* 2007-06-19 15:35:32.234 (ESshFatal) Authentication failed.
* 2007-06-19 15:35:32.234 Authentication log (see session log for details):
* 2007-06-19 15:35:32.234 Using username "tierschutz".
* 2007-06-19 15:35:32.234 Using keyboard-interactive authentication.
* 2007-06-19 15:35:32.234 Authenticating with pre-entered password.
* 2007-06-19 15:35:32.234 Access denied.
* 2007-06-19 15:35:32.234 Unable to authenticate
Thanks. So please also a log for MisterX.
