Topic "SFTP Connection Questions / Support"
mattshea1981
I am doing a job for a customer at the moment that requires SFTP from a windows to a linux box. I need to know if I use generated keys that are generated in putty if the key fails to connect for some reason, it asks for a password instead for the user. Can I just get it to drop out with an error if the keys dont authenticate.
You can disable password authentication on the server.
mattshea1981
This is a scheduled script, do I have to disable this on the Linux server that I am connecting to or is it a setting in WINSCP??
Thanks for any help
On the server. WinSCP does not have the option.
