Topic "Execution of executable files question. :) (Far plugin)"
Alex Grushin
Hi!
First of all - awesome plug-in, thank you for it!
But I wonder, is there a way to execute my program without writing "./MyProgram"?
Example: When I'm working remotely via SecureCRT+"Midnight Commander" file manager, executables are highlighted with green color (like Windows *.exe in Far) and normally execute after hitting Enter on them. In WinSCP, however, it's not that simple. Sad
Thank you in advance.
Good point. I've never thought of that Smile
Oh, and by the way - when I copy files from one folder on remote Unix machine to another folder (on the same host), this plug-in copies everything on my machine at first and then copies it back to remote machine. Am I doing something wrong?
And some note on execution - built-in programs (like "tar" or "mpirun") work fine without "./". Just for the full picture. Smile
Thanks for fast reply.
Direct copy is not implemented.
