Topic "keep remote directory uptodate"
cosmoarg
hi pals!
I'm having a problem with the option keep remote directory uptdoate. The thing is it works fine with files upto 3mbs..but after that size it gives me a warnign, and If I don't press skip I can't continue coping files.
Any idea how to configure it? I don't fine any file size option.
MAriano
What warning?
hi!
thanks for your answer.
the warnign is "Can't open file "file name" ". It's only happens with files more than 4 mb when I sync between a freebsd
thanks
Mariano
Please post a log file.
hi!!
thanks again for your answer
this is the log. the problem seems to be the file extesion
. 2007-06-25 11:36:34.828 Synchronizing local directory 'C:\Inetpub\wwwroot\images\stories\imagenes USINA\multimedia\' with remote directory '/usr/local/www/usina2/images/stories/imagenes USINA/multimedia/', params = 187
. 2007-06-25 11:36:34.843 Copying 1 files/directories to remote directory "/usr/local/www/usina2/images/stories/imagenes USINA/multimedia/"
. 2007-06-25 11:36:34.843 PrTime: Yes; PrRO: No; Rght: rwxrwxrwx; PrR: Yes (Yes); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: No; Mask: *.*
. 2007-06-25 11:36:34.843 TM: M; ClAr: No; ExclM(No):
. 2007-06-25 11:36:34.843 AscM: *.*html; *.htm; *.txt; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.ini; *.xml; *.flv
. 2007-06-25 11:36:34.843 File: "C:\Inetpub\wwwroot\images\stories\imagenes USINA\multimedia\Canal13-Castells-15-12.flv"
* 2007-06-25 11:36:34.859 (ExtException)
. 2007-06-25 11:36:34.859 Asking user:
. 2007-06-25 11:36:34.859 Can't open file 'C:\Inetpub\wwwroot\images\stories\imagenes USINA\multimedia\Canal13-Castells-15-12.flv'. ()
* 2007-06-25 11:36:40.328 (EScpSkipFile) Can't open file 'C:\Inetpub\wwwroot\images\stories\imagenes USINA\multimedia\Canal13-Castells-15-12.flv'.
. 2007-06-25 11:36:40.328 Cached directory not reloaded.
. 2007-06-25 11:36:40.328 Listing directory "/usr/local/www/usina2/images/stories/imagenes USINA/multimedia/Videos".
> 2007-06-25 11:36:40.328 Type: SSH_FXP_OPENDIR, Size: 78, Number: 2520587
< 2007-06-25 11:36:40.328 Type: SSH_FXP_STATUS, Size: 24, Number: 2520324
. 2007-06-25 11:36:40.328 Discarding reserved response
< 2007-06-25 11:36:40.328 Type: SSH_FXP_HANDLE, Size: 13, Number: 2520587
> 2007-06-25 11:36:40.328 Type: SSH_FXP_READDIR, Size: 13, Number: 2520844
< 2007-06-25 11:36:40.500 Type: SSH_FXP_NAME, Size: 13712, Number: 2520844
> 2007-06-25 11:36:40.500 Type: SSH_FXP_READDIR, Size: 13, Number: 2521100
< 2007-06-25 11:36:40.515 Type: SSH_FXP_NAME, Size: 2757, Number: 2521100
> 2007-06-25 11:36:40.515 Type: SSH_FXP_READDIR, Size: 13, Number: 2521356
< 2007-06-25 11:36:40.515 Type: SSH_FXP_STATUS, Size: 28, Number: 2521356
< 2007-06-25 11:36:40.515 Status/error code: 1
> 2007-06-25 11:36:40.515 Type: SSH_FXP_CLOSE, Size: 13, Number: 2521604
Can you upload the file manually?
yes! manually no problem. for me the problem seems to be the extesions
any help or idea?
The problem may be cause by another application still having the changed file open. You can try to set configuration option KeepUpToDateChangeDelay to a larger value.
