Topic "/log in script automation - Question!"
Marcel
Hiyo!
I wrote a small vb.net application which help me to back up my folders with sftp. the synchronize script work fine and the data get saves successful.
i want to implement some kind of error notification if something fail while synchronize (for example permissions or whatever). so i use the parameter "/script=c:\errorlog.txt".
my problem is, this script get pretty huge. (1 mb per 10 mb syncronized files) and even if no error accured the log is huge. its ok, i understand why - but is there any option that only errors come in the log? it would make it much easyer to test the success after the batch run.
THX!
You should check for exit code of the script instead of parsing a log file. Please read FAQ.
Marcel
Fine but then i have a "true" or a "false". problem is, i need to report detail information -> what files failed and why they failed.
hm i tried to generate an error, exit code still 0
Sad
What kind of error? How do you check for exit code?
