| Author | Message |
Artur Lopes Bezerra
Guest |
Posted: 25 Jun 2007 15:35
Does exists a 64 bits WinSCP version? If not, any prevision? TIA |
| Advertisements |
Posted: 26 Jun 2007 21:54
i 2nd this also
prikryl
Posts: 16483 Location: Prague, Czech republic |
Posted: 28 Jun 2007
There are no plans for that.
_________________ Martin Prikryl |
cory
Guest |
Posted: 6 Jul 2007 21:09
I need the 64 bit also
prikryl
Posted: 9 Jul 2007
cory wrote: I need the 64 bit also What for? _________________ Martin Prikryl |
Phil
Guest |
Posted: 1 Aug 2007 03:00
prikryl wrote: cory wrote: I need the 64 bit also What for? Drag and drop from 32-bit apps into Windows Explorer doesn't work properly under 64-bit XP. There's something about the 64-bit explorer such that when the item is dragged from WinSCP to an explorer window, a folder entitled (for instance) scp51328 is created in the explorer, and then WinSCP itself complains with the "WinSCP was not able to detect folder, where the dragged file(s) was dropped. Either ...". I think that's the reason that the TortoiseSVN guys have an x64 version as well as an x86 version. Anyhow, if you need access or work done on a 64-bit platform, you can get to me from the contact links at www.pagaros.com.au. |
prikryl
Posted: 5 Aug 2007
Phil wrote: Drag and drop from 32-bit apps into Windows Explorer doesn't work properly under 64-bit XP. There's something about the 64-bit explorer such that when the item is dragged from WinSCP to an explorer window, a folder entitled (for instance) scp51328 is created in the explorer, and then WinSCP itself complains with the "WinSCP was not able to detect folder, where the dragged file(s) was dropped. Either ...".
I think that's the reason that the TortoiseSVN guys have an x64 version as well as an x86 version. It should be enough to make 64-bit drag&drop shell extension. It is planned. TortoiseSNV is Explorer-plugin not a regular application. Quote: Anyhow, if you need access or work done on a 64-bit platform, you can get to me from the contact links at www.pagaros.com.au. Thanks. I will do once I have anything to test. _________________ Martin Prikryl |
webmaster
Guest |
Posted: 12 Aug 2007 01:27
I need too!
PuTTY dont work on Windows Vista Business 64-bit |
matze
Guest |
Posted: 27 Aug 2007 02:07
is īve AMD Dual Core & win xp x64 WinScp Ver 3.8.2 works fine. Mfg Matze |
daaron
Guest |
Posted: 11 Feb 2009 19:43
I'm using WinSCP 4.1.8 on Windows Vista x64, and I get this same error:
"WinSCP was not able to detect folder, where the dragged files(s) was dropped. etc." It appears to work just fine when I drag files from WinSCP to the desktop (a 64-bit process) or to Windows Explorer x64, but when I try to drag files to the 32-bit Windows Explorer (which I use sometimes for compatibility with certain 32-bit Explorer extensions), I get this error. Is it possible to install both the 32-bit and 64-bit WinSCP Explorer extensions on x64 Windows? (Many other apps do this.) Thanks, |
prikryl
Posted: 12 Feb 2009
daaron wrote: I'm using WinSCP 4.1.8 on Windows Vista x64, and I get this same error:
"WinSCP was not able to detect folder, where the dragged files(s) was dropped. etc." It appears to work just fine when I drag files from WinSCP to the desktop (a 64-bit process) or to Windows Explorer x64, but when I try to drag files to the 32-bit Windows Explorer (which I use sometimes for compatibility with certain 32-bit Explorer extensions), I get this error. Is it possible to install both the 32-bit and 64-bit WinSCP Explorer extensions on x64 Windows? (Many other apps do this.) Thanks for your post. This issue has been added to tracker. Can you provide me your email address, so I can send you a debug version of WinSCP to test this? I do not have a 64-bit system available. If you do not want to post the address here, you can send me an email. You will find my address (if you log in) in my forum profile. Please include link to this topic. Thanks. _________________ Martin Prikryl |
Darrell
Guest |
Posted: 31 Mar 2009 20:08
How big a donation would it take to get you to build a 64 bit version that handles SMB shares??
prikryl
Posted: 1 Apr 2009
Darrell wrote: How big a donation would it take to get you to build a 64 bit version that handles SMB shares?? You do not have that amount _________________ Martin Prikryl |
Posted: 20 Oct 2009 05:41
This totally need to be offered in x64 bit. As one of the better FTP clients I would think skimping on this is wrong.
In fact all programs should be written for 64 bit computers. It doesn't make sense not to. Any program intending to run in an x64 environment should run native. Even if no serious performance benefit is evident, there certainly is a benefit. Function, operation, and integration with the OS software and a few benefits of having it run native. Sure it works as a 32bit app, but it would play nicer as a x64 app on a x64 machine. |
Nnyan
Posts: 1 Location: Sacramento |
Posted: 5 Nov 2010 19:50
prikryl wrote: There are no plans for that. Has this changed? It would be nice to get a x64 version of this. |
Jeff
Guest |
Posted: 2 Jun 2011 20:43
The best way is use the portable version. Work well.
Valera
Guest |
Posted: 24 Apr 2012 10:13
First of all, thank you for the nice product!
But this topic is almost FIVE years old. Is there any chances to see WinSCP x64? Thanks! |
prikryl
Posted: 26 Apr 2012
We cannot make 64 bit version of WinSCP in near future due to technical constraints.
Anyway, what advantage would 64 bit version bring to you? _________________ Martin Prikryl |
x64PowerUser
Guest |
Posted: 15 May 2013 01:11
prikryl wrote: We cannot make 64 bit version of WinSCP in near future due to technical constraints.
Anyway, what advantage would 64 bit version bring to you? If properly optimized, a 64 bit application would bring increased speed in processing the scripts that handle downloading large numbers of files from an FTP server. Yes, it requires more memory for these optimizations, but real power users generally have plenty of memory to spare for these things. I am currently searching for, and willing to pay for a good quality, fast, properly optimized native 64 bit FTP client. I am passing on WinSCP because it does not support 64 bit. I am passing on FileZilla for the same reason. Both are slow when compared to a product like Pragma Fortress, SmartFTP, etc. "Technical constraints" usually means there isn't a programmer that uses the required platform, nor has the expertise to optimize for 64 bit. Since that expertise doesn't exist here, I suppose I'll keep looking. |
prikryl
Posted: 16 May 2013
x64PowerUser wrote: "Technical constraints" usually means there isn't a programmer that uses the required platform, nor has the expertise to optimize for 64 bit. Since that expertise doesn't exist here, I suppose I'll keep looking. "Technical contraints" means that the first stable version of 64 bit C++ Builder was released only a month ago. |
| Advertisements |
Site design by Black Gate
