Topic "bug synchronization on selected files Vista"
ver: 3.8.2 4.0.2beta
OS: vista 32bit RTM
When I select some dirs and files and then check in sychronization dialog
this options:
preview changes, selected files only and exlude mask as ".svn"
after OK click
I get the message like "no difference found" and no action is performed.
It is same for remote/local direction.
When I make synchronization without selection (unchecked selected files only)
all works fine.
This bug is presented on Vista only, on XP it works fine.
Do other operations with selected files work? Like uploading selected files?
No, when I select some files in one panel (it doesn't matter what), EDIT, COPY, MOVE are disabled and when I try upload files via popup menu function, get messagebox with "external exception EEFFACE"
thank you very much, bug is solved in 4.0.4 (some keyboard workaround is mentioned in release notices)
