Topic "Bug: Using Insert Key for Fileselection"
Possible
WinSCP 4.0.2 (Build 344) on Windows Vista.
When using "Insert"-Key for selecting (multiple) files the actions: edit, copy, move and delete and options gets disabled.
PS dont forget http://winscp.net/forum/viewtopic.php?t=4372 xD
Thanks for your report. I'll check it.
I have exactly same problem.
WinSCP 4.03 (Build 345) @ Windows 6.0 Vista Ultimate
Can anyone, who is having this problem, contact me on my email address?
boldi
Hi!
I have the same problem with WinSCP 4.0.3 build 345 on windows vista x64
Kind regards
There's actually a bug in Windows Vista. Workaround has been implemented, which will be part of the next major release.
This has been fixed in 4.0.4.
