Topic "Filetype on local PC truncated, wrong sort results by type"
If you have a file:
bla.php4 the "Type" column says PHP
bla.php5 says PHP
asdf.php5 says PHP
bla.asdfg says ASD
Does affect sorting by type to wrong results, gets sorted like that, which is wrong:
Thanks for the great product! Keep your very good work!
I get:
bla.php4: "PHP4 File"
bla.php5: "PHP5 File"
asdf.php5: "PHP5 File"
bla.asdfg: "ASDFG File"
Anyway the value of "Type" column is generated by operating system. What version of Windows are you using?
Also to sort by an extension you should better click the "Ext" path of the "Name" column.
