Topic "Playstation 2 FTP server won't transfer directory listing"
dilweed
My gut feel is "LIST -a" isn't supported using uLaunchELF's embedded FTP server.
WinSCP log:
Session name: anonymous@192.168.1.7
Host name: 192.168.1.7 (Port: 21)
User name: anonymous (Password: Yes, Key file: No)
Tunnel: No
Transfer Protocol: FTP
Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
Proxy: none
FTP: Passive: Yes
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 1
Connecting to 192.168.1.7 ...
Connected with 192.168.1.7. Waiting for welcome message...
220 ps2ftpd ready.
USER anonymous
230 User logged in.
SYST
215 UNIX Type: L8
FEAT
500 Not understood.
Connected
Using FTP protocol.
Doing startup conversation with host.
PWD
257 "/"
Getting current directory name.
Retrieving directory listing...
TYPE A
200 Command successful.
PASV
227 Entering passive mode (192,168,1,7,16,16).
LIST -a
500 Unable to open directory.
(ECommand) Error listing directory '/'.
Startup conversation with host finished.
150 Opening ASCII connection.
226 Command successful.
FileZilla Log (for comparison):
Status: Connecting to 192.168.1.7 ...
Status: Connected with 192.168.1.7. Waiting for welcome message...
Response: 220 ps2ftpd ready.
Command: USER anonymous
Response: 230 User logged in.
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 500 Not understood.
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/"
Command: TYPE A
Response: 200 Command successful.
Command: PORT 192,168,1,30,13,162
Command: LIST
Response: 150 Opening ASCII connection.
Response: 226 Command successful.
Status: Directory listing successful
Thanks!
-Tom
Thanks for your report. I'll check it.
This has been fixed in 4.0.4.
srg814
I need to connect to an old FTP server that only supports active mode.
When using active mode, WinSCP must send the PORT commmand, otherwise I can't get the directory listing.
I tried with FileZilla with active mode selected and it works without problems, so I presume the bug is not in the LIST command but in the PORT command.
Thanks.
srg814
Can you post a log file showing the problem?
srg814
Hello.
Further tests made with several FTP clients, namely, Filezilla, CuteFTP, wget, Total Commander and WinSCP, shows that the problem lies in the listing format of the server.
I could only get the remote listing correctly with Total Commander, after defining the server type.
Check the screen dump of the Total Commander option "Define server type" for a directory listing format send by this server.
Log of the session with Total Commander:
Connect to: (10-02-2008 19:08:43)
hostname=123.123.123.123
username=user
startdir=\
220 ftp server ready
USER user
331 password required for user
PASS ***********
230 user user logged in
SYST
502 SYST command not available
FEAT
502 FEAT command not available
CWD \
250 CWD comm and ok
Connect ok!
PWD
257 "\" is current directory
Get directory
TYPE A
200 Type set to A.
PORT 123,123,123,123,5,42
200 PORT comm and ok
LIST
150 Opening data connection for LIST (123.123.123.123,5003) (0 bytes).
Download
Waiting for server...
226 Transfer complete
Regards,
srg814
