Topic "Memory leak in 4.0.3?"
NotAHuskerFan
Problem: Memory leak used more than 400MB in one case
Using version 4.0.3 build 345
Transfer protocol SFTP-3
Interface style Norton commander; same behavior using Explorer-style, but doesnt release as much memory when minimizing window
Discovered during long duration transfer (filesize 4GB+), happens when transfer in either background or foreground; minimizing window releases memory, but WinSCP continues to reacquire. Minimizing/restoring window releases memory each time performed
Thanks for your attention.
Alan
Did you had the problem with previous releases?
NotAHuskerFan
I didn't have this issue with 3.8.2 build 330 on this system.
I'm trying to reproduce this on different systems, now. For instance, it doesn't show the leak on a Win2K Advanced Server. I'm having the problem on an XP Pro SP2 box. I'll try it on a different XP Pro SP2 system. I'll be embarrassed if it turns out to be a quirk of my workstation. That'll tell me it's time to rebuild it!
Thanks for your response. I'll let you know what I find.
Alan
