Topic "^M at the end of each line when I edit in winscp"
g1967
I frequently copy files from my unix enviroment to my winxp workstation, edit through Winscp using the open or edit function and then copy the files back to the unix server. When I do this I get a ^M at the end of each file when you display in unix. How can I edit these files in windows and winscp without having the ^M added to the end of each file?
Greg
g1967
Sorry, I am using version 4.0.3 build 345
Greg
If you are using an external editor, either:
1) Instruct it to use Unix line endings
2) or configure it as an external editor for WinSCP, use edit, not open, and check "force text transfer mode for files edited in external editor"
I experience a similar problem. The ^M is added by WinSCP during the transfer, even without editing anything.
Just do this:
1) transfer a text file from Unix => Win
2) transfer it back from Win => Unix
3) edit the newly received file in Unix (i.e. using vi)
you will see the Windows' /n at the end of the line, and will have to do a 'dos2unix' for that file.
Anonymous wrote:
Just do this:
What transfer mode are you using? Text or binary? Have you used the same mode for download and upload? Had the file unix line endings originally (on unix side, before step 1)? What end-of-line characters have you configured on Environment tab of login dialog for your session?
marrtins
Is it possible to specify transfer mode in FAR manager plugin? It`s really annoying when i get converted CR/LF<->LF and vice verse Evil or Very Mad
Thnx!
Sure. In plugin settings you can set default mode. On transfer options dialog, you can change mode for particular transfer.
marrtins
No realy sure where to find that option, look here is `transfer settings` dialog in FAR manager
Here is `About` window
It can be set in plugin configuration since 1.6 only. But even in 1.5.1 you can set the transfer mode on the upload/download box.
