Topic "Using FTP and an Open VMS box Directory fails"
Carazariah
When trying to connect to our Open VMS box.
WINSCP fails to open the default directory which it is duplicating with users1:[system_users.flastname]/users1:[system_users.flastname]
I tried putting the info in the remote directory but it still gives the error.
"Could not retrieve directory listing
Failed to set default directory to USERS1:[system_users.flastname]/USERS1:[system_users.flastname].
file specification syntax error"
Thanks for any help you can provide
Version 4.03 Build 345
Session protocol = FTP
Compression = No
Can change permissions = Yes
Can change owner/group = No
Can execute arbitrary command = Protocol commands only
Can create symlink/hardlink = No/No
Can lookup user groups = No
Additional information
The server does not support any additional FTP feature.
C
WinSCP does not support VMS systems.
Is there a plan to support VMS file name ? I could connect to a VMS FTP server but the directory listing is empty.
Here is the debug=1 log:
. 2008-02-01 10:57:01.926 --------------------------------------------------------------------------
. 2008-02-01 10:57:01.926 WinSCP Version 4.0.6 (Build 358) (OS 5.1.2600 Service Pack 2)
. 2008-02-01 10:57:01.926 Login time: February 1, 2008 10:57:01 AM
. 2008-02-01 10:57:01.926 Session name: bi24593@msghub
. 2008-02-01 10:57:01.926 Host name: msghub (Port: 21)
. 2008-02-01 10:57:01.926 User name: bi24593 (Password: No, Key file: No)
. 2008-02-01 10:57:01.926 Tunnel: No
. 2008-02-01 10:57:01.926 Transfer Protocol: FTP
. 2008-02-01 10:57:01.926 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2008-02-01 10:57:01.926 Proxy: none
. 2008-02-01 10:57:01.926 FTP: Passive: No
. 2008-02-01 10:57:01.926 Local directory: default, Remote directory: /, Update: No, Cache: Yes
. 2008-02-01 10:57:01.926 Cache directory changes: Yes, Permanent: Yes
. 2008-02-01 10:57:01.926 DST mode: 1
. 2008-02-01 10:57:01.926 Password prompt (no password provided or last login attempt failed)
. 2008-02-01 10:57:05.782 Connecting to msghub ...
. 2008-02-01 10:57:05.792 Connected with msghub. Waiting for welcome message...
< 2008-02-01 10:57:05.792 220 msghub.pwc.ca MultiNet FTP Server Process V4.2(16) at Fri 1-Feb-2008 11:00AM-EST
> 2008-02-01 10:57:05.792 USER bi24593
< 2008-02-01 10:57:05.832 331 User name (bi24593) ok. Password, please.
> 2008-02-01 10:57:05.832 PASS ********
< 2008-02-01 10:57:06.884 230 User BI24593 logged into PMDF$DISK:[BI24593] at Fri 1-Feb-2008 11:00AM-EST, job 28d4c.
> 2008-02-01 10:57:06.884 SYST
< 2008-02-01 10:57:06.894 215 VMS MultiNet V4.2(16)
> 2008-02-01 10:57:06.894 FEAT
< 2008-02-01 10:57:06.894 500 I never heard of the FEAT command. Try HELP.
. 2008-02-01 10:57:06.894 Connected
. 2008-02-01 10:57:06.894 Got reply 1 to the command 1
. 2008-02-01 10:57:06.894 --------------------------------------------------------------------------
. 2008-02-01 10:57:06.894 Using FTP protocol.
. 2008-02-01 10:57:06.894 Doing startup conversation with host.
> 2008-02-01 10:57:06.894 PWD
< 2008-02-01 10:57:06.894 257 "PMDF$DISK:[BI24593]" is current directory.
. 2008-02-01 10:57:06.894 Got reply 1 to the command 16
. 2008-02-01 10:57:06.894 Changing directory to "/".
> 2008-02-01 10:57:06.894 CWD /
< 2008-02-01 10:57:06.904 250 Connected to /pmdf$disk/bi24593/.
. 2008-02-01 10:57:06.904 Got reply 1 to the command 16
. 2008-02-01 10:57:06.904 Getting current directory name.
> 2008-02-01 10:57:06.904 PWD
< 2008-02-01 10:57:06.904 257 "/pmdf$disk/bi24593/" is current directory.
. 2008-02-01 10:57:06.904 Retrieving directory listing...
> 2008-02-01 10:57:06.904 TYPE A
< 2008-02-01 10:57:06.904 200 Type A ok.
> 2008-02-01 10:57:06.914 PORT 141,119,26,130,18,55
< 2008-02-01 10:57:06.914 200 Port 18.55 at Host 141.119.26.130 accepted.
> 2008-02-01 10:57:06.914 LIST -a
< 2008-02-01 10:57:06.934 150 List started.
. 2008-02-01 10:57:06.934 <Empty directory listing>
< 2008-02-01 10:57:07.064 226 Transfer completed.
. 2008-02-01 10:57:07.064 Directory listing successful
. 2008-02-01 10:57:07.064 Got reply 1 to the command 2
. 2008-02-01 10:57:07.064 Startup conversation with host finished.
. 2008-02-01 10:57:07.705 Session upkeep
. 2008-02-01 10:57:08.226 Session upkeep
. 2008-02-01 10:57:08.706 Session upkeep
. 2008-02-01 10:57:09.207 Session upkeep
. 2008-02-01 10:57:09.708 Session upkeep
. 2008-02-01 10:57:10.208 Session upkeep
. 2008-02-01 10:57:10.709 Session upkeep
. 2008-02-01 10:57:11.210 Session upkeep
. 2008-02-01 10:57:11.711 Session upkeep
. 2008-02-01 10:57:12.211 Session upkeep
. 2008-02-01 10:57:12.712 Session upkeep
. 2008-02-01 10:57:13.213 Session upkeep
. 2008-02-01 10:57:13.713 Session upkeep
. 2008-02-01 10:57:14.214 Session upkeep
. 2008-02-01 10:57:14.715 Session upkeep
. 2008-02-01 10:57:15.216 Session upkeep
. 2008-02-01 10:57:15.716 Session upkeep
. 2008-02-01 10:57:16.217 Session upkeep
. 2008-02-01 10:57:16.718 Session upkeep
. 2008-02-01 10:57:17.218 Session upkeep
. 2008-02-01 10:57:17.719 Session upkeep
. 2008-02-01 10:57:18.220 Session upkeep
. 2008-02-01 10:57:18.721 Session upkeep
. 2008-02-01 10:57:19.221 Session upkeep
. 2008-02-01 10:57:19.722 Session upkeep
. 2008-02-01 10:57:20.223 Session upkeep
. 2008-02-01 10:57:20.724 Session upkeep
. 2008-02-01 10:57:21.224 Session upkeep
. 2008-02-01 10:57:21.725 Session upkeep
. 2008-02-01 10:57:22.226 Session upkeep
. 2008-02-01 10:57:22.726 Session upkeep
. 2008-02-01 10:57:23.227 Session upkeep
. 2008-02-01 10:57:23.728 Session upkeep
. 2008-02-01 10:57:24.229 Session upkeep
. 2008-02-01 10:57:24.729 Session upkeep
. 2008-02-01 10:57:25.230 Session upkeep
. 2008-02-01 10:57:25.731 Session upkeep
. 2008-02-01 10:57:26.231 Session upkeep
. 2008-02-01 10:57:26.732 Session upkeep
. 2008-02-01 10:57:27.233 Session upkeep
. 2008-02-01 10:57:27.734 Session upkeep
. 2008-02-01 10:57:28.234 Session upkeep
. 2008-02-01 10:57:28.735 Session upkeep
. 2008-02-01 10:57:29.236 Session upkeep
. 2008-02-01 10:57:29.736 Session upkeep
. 2008-02-01 10:57:30.237 Session upkeep
. 2008-02-01 10:57:30.738 Session upkeep
. 2008-02-01 10:57:31.239 Session upkeep
. 2008-02-01 10:57:31.739 Session upkeep
. 2008-02-01 10:57:32.240 Session upkeep
. 2008-02-01 10:57:32.741 Session upkeep
. 2008-02-01 10:57:33.242 Session upkeep
. 2008-02-01 10:57:33.742 Session upkeep
. 2008-02-01 10:57:34.243 Session upkeep
. 2008-02-01 10:57:34.744 Session upkeep
. 2008-02-01 10:57:35.244 Session upkeep
. 2008-02-01 10:57:35.745 Session upkeep
. 2008-02-01 10:57:36.246 Session upkeep
. 2008-02-01 10:57:36.747 Session upkeep
. 2008-02-01 10:57:37.247 Session upkeep
. 2008-02-01 10:57:37.748 Session upkeep
. 2008-02-01 10:57:38.249 Session upkeep
> 2008-02-01 10:57:38.249 PWD
< 2008-02-01 10:57:38.249 257 "/pmdf$disk/bi24593/" is current directory.
. 2008-02-01 10:57:38.749 Session upkeep
. 2008-02-01 10:57:39.250 Session upkeep
. 2008-02-01 10:57:39.751 Session upkeep
. 2008-02-01 10:57:40.252 Session upkeep
. 2008-02-01 10:57:40.752 Session upkeep
. 2008-02-01 10:57:41.253 Session upkeep
. 2008-02-01 10:57:41.754 Session upkeep
. 2008-02-01 10:57:42.254 Session upkeep
. 2008-02-01 10:57:42.755 Session upkeep
. 2008-02-01 10:57:43.256 Session upkeep
. 2008-02-01 10:57:43.757 Session upkeep
. 2008-02-01 10:57:44.257 Session upkeep
. 2008-02-01 10:57:44.758 Session upkeep
. 2008-02-01 10:57:45.259 Session upkeep
. 2008-02-01 10:57:45.760 Session upkeep
. 2008-02-01 10:57:46.260 Session upkeep
. 2008-02-01 10:57:46.761 Session upkeep
. 2008-02-01 10:57:47.262 Session upkeep
. 2008-02-01 10:57:47.762 Session upkeep
. 2008-02-01 10:57:48.263 Session upkeep
. 2008-02-01 10:57:48.764 Session upkeep
. 2008-02-01 10:57:49.265 Session upkeep
. 2008-02-01 10:57:49.765 Session upkeep
. 2008-02-01 10:57:50.266 Session upkeep
. 2008-02-01 10:57:50.767 Session upkeep
. 2008-02-01 10:57:51.267 Session upkeep
. 2008-02-01 10:57:51.768 Session upkeep
. 2008-02-01 10:57:52.269 Session upkeep
. 2008-02-01 10:57:52.770 Session upkeep
. 2008-02-01 10:57:53.270 Session upkeep
. 2008-02-01 10:57:53.771 Session upkeep
. 2008-02-01 10:57:54.272 Session upkeep
. 2008-02-01 10:57:54.772 Session upkeep
. 2008-02-01 10:57:55.273 Session upkeep
. 2008-02-01 10:57:55.774 Session upkeep
. 2008-02-01 10:57:56.275 Session upkeep
. 2008-02-01 10:57:56.775 Session upkeep
. 2008-02-01 10:57:57.276 Session upkeep
. 2008-02-01 10:57:57.777 Session upkeep
. 2008-02-01 10:57:58.278 Session upkeep
. 2008-02-01 10:57:58.778 Session upkeep
. 2008-02-01 10:57:59.279 Session upkeep
. 2008-02-01 10:57:59.780 Session upkeep
. 2008-02-01 10:58:00.280 Session upkeep
. 2008-02-01 10:58:00.781 Session upkeep
. 2008-02-01 10:58:01.282 Session upkeep
. 2008-02-01 10:58:01.783 Session upkeep
. 2008-02-01 10:58:02.283 Session upkeep
. 2008-02-01 10:58:02.784 Session upkeep
. 2008-02-01 10:58:03.285 Session upkeep
. 2008-02-01 10:58:03.785 Session upkeep
. 2008-02-01 10:58:04.286 Session upkeep
. 2008-02-01 10:58:04.787 Session upkeep
. 2008-02-01 10:58:05.368 Session upkeep
. 2008-02-01 10:58:05.788 Session upkeep
. 2008-02-01 10:58:06.289 Session upkeep
. 2008-02-01 10:58:06.790 Session upkeep
. 2008-02-01 10:58:07.290 Session upkeep
> 2008-02-01 10:58:07.290 REST 0
< 2008-02-01 10:58:07.290 500 I never heard of the REST command. Try HELP.
. 2008-02-01 10:58:07.791 Session upkeep
. 2008-02-01 10:58:08.292 Session upkeep
. 2008-02-01 10:58:08.793 Session upkeep
. 2008-02-01 10:58:09.293 Session upkeep
. 2008-02-01 10:58:09.794 Session upkeep
. 2008-02-01 10:58:10.295 Session upkeep
. 2008-02-01 10:58:10.796 Session upkeep
. 2008-02-01 10:58:11.296 Session upkeep
. 2008-02-01 10:58:11.797 Session upkeep
. 2008-02-01 10:58:12.298 Session upkeep
. 2008-02-01 10:58:12.798 Session upkeep
. 2008-02-01 10:58:13.299 Session upkeep
. 2008-02-01 10:58:13.800 Session upkeep
. 2008-02-01 10:58:14.301 Session upkeep
. 2008-02-01 10:58:14.801 Session upkeep
. 2008-02-01 10:58:15.302 Session upkeep
. 2008-02-01 10:58:15.803 Session upkeep
. 2008-02-01 10:58:16.303 Session upkeep
. 2008-02-01 10:58:16.804 Session upkeep
. 2008-02-01 10:58:17.305 Session upkeep
. 2008-02-01 10:58:17.806 Session upkeep
. 2008-02-01 10:58:18.306 Session upkeep
. 2008-02-01 10:58:18.807 Session upkeep
. 2008-02-01 10:58:19.308 Session upkeep
. 2008-02-01 10:58:19.808 Session upkeep
. 2008-02-01 10:58:20.309 Session upkeep
. 2008-02-01 10:58:20.810 Session upkeep
. 2008-02-01 10:58:21.311 Session upkeep
. 2008-02-01 10:58:21.811 Session upkeep
. 2008-02-01 10:58:22.312 Session upkeep
. 2008-02-01 10:58:22.813 Session upkeep
. 2008-02-01 10:58:23.314 Session upkeep
. 2008-02-01 10:58:23.814 Session upkeep
. 2008-02-01 10:58:24.315 Session upkeep
. 2008-02-01 10:58:24.816 Session upkeep
. 2008-02-01 10:58:25.316 Session upkeep
. 2008-02-01 10:58:25.817 Session upkeep
. 2008-02-01 10:58:26.318 Session upkeep
. 2008-02-01 10:58:26.819 Session upkeep
. 2008-02-01 10:58:27.319 Session upkeep
. 2008-02-01 10:58:27.820 Session upkeep
. 2008-02-01 10:58:28.321 Session upkeep
. 2008-02-01 10:58:28.821 Session upkeep
. 2008-02-01 10:58:29.322 Session upkeep
. 2008-02-01 10:58:29.823 Session upkeep
. 2008-02-01 10:58:30.324 Session upkeep
. 2008-02-01 10:58:30.824 Session upkeep
. 2008-02-01 10:58:31.325 Session upkeep
. 2008-02-01 10:58:31.826 Session upkeep
. 2008-02-01 10:58:32.326 Session upkeep
. 2008-02-01 10:58:32.827 Session upkeep
. 2008-02-01 10:58:33.328 Session upkeep
. 2008-02-01 10:58:33.829 Session upkeep
. 2008-02-01 10:58:34.329 Session upkeep
. 2008-02-01 10:58:34.830 Session upkeep
. 2008-02-01 10:58:35.331 Session upkeep
. 2008-02-01 10:58:35.832 Session upkeep
. 2008-02-01 10:58:36.332 Session upkeep
. 2008-02-01 10:58:36.833 Session upkeep
. 2008-02-01 10:58:37.334 Session upkeep
> 2008-02-01 10:58:37.334 REST 0
< 2008-02-01 10:58:37.334 500 I never heard of the REST command. Try HELP.
. 2008-02-01 10:58:37.834 Session upkeep
. 2008-02-01 10:58:38.335 Session upkeep
. 2008-02-01 10:58:38.836 Session upkeep
. 2008-02-01 10:58:39.337 Session upkeep
. 2008-02-01 10:58:39.837 Session upkeep
. 2008-02-01 10:58:40.338 Session upkeep
. 2008-02-01 10:58:40.839 Session upkeep
. 2008-02-01 10:58:41.339 Session upkeep
. 2008-02-01 10:58:41.840 Session upkeep
. 2008-02-01 10:58:42.341 Session upkeep
. 2008-02-01 10:58:42.842 Session upkeep
. 2008-02-01 10:58:43.342 Session upkeep
. 2008-02-01 10:58:43.843 Session upkeep
. 2008-02-01 10:58:44.344 Session upkeep
. 2008-02-01 10:58:44.844 Session upkeep
. 2008-02-01 10:58:45.345 Session upkeep
. 2008-02-01 10:58:45.846 Session upkeep
. 2008-02-01 10:58:46.347 Session upkeep
. 2008-02-01 10:58:46.847 Session upkeep
. 2008-02-01 10:58:47.348 Session upkeep
. 2008-02-01 10:58:47.849 Session upkeep
. 2008-02-01 10:58:48.350 Session upkeep
. 2008-02-01 10:58:48.850 Session upkeep
. 2008-02-01 10:58:49.351 Session upkeep
. 2008-02-01 10:58:49.852 Session upkeep
. 2008-02-01 10:58:50.352 Session upkeep
. 2008-02-01 10:58:50.853 Session upkeep
. 2008-02-01 10:58:51.354 Session upkeep
. 2008-02-01 10:58:51.855 Session upkeep
. 2008-02-01 10:58:52.305 Session upkeep
. 2008-02-01 10:58:52.365 Session upkeep
. 2008-02-01 10:58:53.467 Session upkeep
. 2008-02-01 10:58:53.867 Session upkeep
. 2008-02-01 10:58:54.789 Session upkeep
. 2008-02-01 10:58:54.889 Session upkeep
. 2008-02-01 10:58:55.920 Session upkeep
. 2008-02-01 10:58:56.371 Session upkeep
. 2008-02-01 10:58:57.182 Session upkeep
. 2008-02-01 10:58:57.383 Session upkeep
. 2008-02-01 10:58:58.194 Session upkeep
. 2008-02-01 10:58:58.374 Session upkeep
. 2008-02-01 10:58:59.195 Session upkeep
. 2008-02-01 10:58:59.365 Session upkeep
. 2008-02-01 10:59:00.247 Session upkeep
. 2008-02-01 10:59:00.387 Session upkeep
. 2008-02-01 10:59:01.328 Session upkeep
. 2008-02-01 10:59:01.438 Session upkeep
. 2008-02-01 10:59:01.899 Session upkeep
. 2008-02-01 10:59:02.670 Session upkeep
. 2008-02-01 10:59:02.870 Session upkeep
. 2008-02-01 10:59:03.371 Session upkeep
. 2008-02-01 10:59:03.872 Session upkeep
. 2008-02-01 10:59:04.373 Session upkeep
. 2008-02-01 10:59:04.873 Session upkeep
. 2008-02-01 10:59:05.374 Session upkeep
. 2008-02-01 10:59:05.875 Session upkeep
. 2008-02-01 10:59:06.375 Session upkeep
. 2008-02-01 10:59:06.876 Session upkeep
. 2008-02-01 10:59:07.377 Session upkeep
> 2008-02-01 10:59:07.377 TYPE A
< 2008-02-01 10:59:07.377 200 Type A ok.
. 2008-02-01 10:59:07.898 Session upkeep
. 2008-02-01 10:59:09.069 Session upkeep
. 2008-02-01 10:59:09.390 Session upkeep
. 2008-02-01 10:59:10.511 Session upkeep
. 2008-02-01 10:59:10.882 Session upkeep
. 2008-02-01 10:59:11.383 Session upkeep
. 2008-02-01 10:59:11.883 Session upkeep
. 2008-02-01 10:59:12.384 Session upkeep
. 2008-02-01 10:59:12.885 Session upkeep
. 2008-02-01 10:59:13.386 Session upkeep
. 2008-02-01 10:59:13.886 Session upkeep
. 2008-02-01 10:59:14.387 Session upkeep
. 2008-02-01 10:59:14.888 Session upkeep
. 2008-02-01 10:59:15.388 Session upkeep
. 2008-02-01 10:59:15.889 Session upkeep
. 2008-02-01 10:59:16.390 Session upkeep
. 2008-02-01 10:59:16.891 Session upkeep
. 2008-02-01 10:59:17.391 Session upkeep
. 2008-02-01 10:59:17.892 Session upkeep
. 2008-02-01 10:59:18.393 Session upkeep
. 2008-02-01 10:59:18.893 Session upkeep
. 2008-02-01 10:59:19.394 Session upkeep
. 2008-02-01 10:59:19.895 Session upkeep
. 2008-02-01 10:59:20.396 Session upkeep
. 2008-02-01 10:59:20.896 Session upkeep
. 2008-02-01 10:59:21.397 Session upkeep
. 2008-02-01 10:59:21.898 Session upkeep
. 2008-02-01 10:59:22.398 Session upkeep
. 2008-02-01 10:59:22.519 Changing directory to "sys$manager".
> 2008-02-01 10:59:22.519 CWD sys$manager
< 2008-02-01 10:59:22.529 550 %RMS-E-DNF, directory not found: [.SYS$$MANAGER]
. 2008-02-01 10:59:22.529 Got reply 4 to the command 16
* 2008-02-01 10:59:22.529 (ECommand) Error changing directory to 'sys$manager'.
* 2008-02-01 10:59:22.529 %RMS-E-DNF, directory not found: [.SYS$$MANAGER]
. 2008-02-01 10:59:23.310 Session upkeep
. 2008-02-01 10:59:23.440 Session upkeep
. 2008-02-01 10:59:23.901 Session upkeep
. 2008-02-01 10:59:24.401 Session upkeep
. 2008-02-01 10:59:24.902 Session upkeep
. 2008-02-01 10:59:25.403 Session upkeep
. 2008-02-01 10:59:25.904 Session upkeep
. 2008-02-01 10:59:26.404 Session upkeep
. 2008-02-01 10:59:26.905 Session upkeep
. 2008-02-01 10:59:27.406 Session upkeep
. 2008-02-01 10:59:27.906 Session upkeep
. 2008-02-01 10:59:28.147 Session upkeep
. 2008-02-01 10:59:28.417 Session upkeep
. 2008-02-01 10:59:31.612 Session upkeep
. 2008-02-01 10:59:31.942 Session upkeep
. 2008-02-01 10:59:35.277 Session upkeep
. 2008-02-01 10:59:35.437 Session upkeep
. 2008-02-01 10:59:35.918 Session upkeep
. 2008-02-01 10:59:39.453 Session upkeep
. 2008-02-01 10:59:39.974 Session upkeep
. 2008-02-01 10:59:43.489 Session upkeep
. 2008-02-01 10:59:43.929 Session upkeep
. 2008-02-01 10:59:44.430 Session upkeep
. 2008-02-01 10:59:44.931 Session upkeep
. 2008-02-01 10:59:45.432 Session upkeep
. 2008-02-01 10:59:45.932 Session upkeep
. 2008-02-01 10:59:46.433 Session upkeep
. 2008-02-01 10:59:46.934 Session upkeep
. 2008-02-01 10:59:47.434 Session upkeep
. 2008-02-01 10:59:47.935 Session upkeep
. 2008-02-01 10:59:48.436 Session upkeep
. 2008-02-01 10:59:48.937 Session upkeep
. 2008-02-01 10:59:49.437 Session upkeep
. 2008-02-01 10:59:49.938 Session upkeep
. 2008-02-01 10:59:50.439 Session upkeep
. 2008-02-01 10:59:50.940 Session upkeep
. 2008-02-01 10:59:51.440 Session upkeep
. 2008-02-01 10:59:51.941 Session upkeep
. 2008-02-01 10:59:52.442 Session upkeep
> 2008-02-01 10:59:52.442 TYPE A
< 2008-02-01 10:59:52.442 200 Type A ok.
. 2008-02-01 10:59:52.982 Session upkeep
. 2008-02-01 10:59:53.443 Session upkeep
. 2008-02-01 10:59:53.944 Session upkeep
. 2008-02-01 10:59:54.445 Session upkeep
. 2008-02-01 10:59:54.945 Session upkeep
. 2008-02-01 10:59:55.446 Session upkeep
. 2008-02-01 10:59:55.947 Session upkeep
. 2008-02-01 10:59:56.447 Session upkeep
. 2008-02-01 10:59:56.948 Session upkeep
. 2008-02-01 10:59:57.449 Session upkeep
. 2008-02-01 10:59:57.950 Session upkeep
. 2008-02-01 10:59:58.450 Session upkeep
. 2008-02-01 10:59:58.951 Session upkeep
. 2008-02-01 10:59:59.452 Session upkeep
. 2008-02-01 10:59:59.952 Session upkeep
. 2008-02-01 11:00:00.453 Session upkeep
. 2008-02-01 11:00:00.954 Session upkeep
. 2008-02-01 11:00:01.455 Session upkeep
. 2008-02-01 11:00:01.955 Session upkeep
. 2008-02-01 11:00:02.456 Session upkeep
. 2008-02-01 11:00:02.957 Session upkeep
. 2008-02-01 11:00:03.458 Session upkeep
. 2008-02-01 11:00:03.958 Session upkeep
. 2008-02-01 11:00:04.459 Session upkeep
. 2008-02-01 11:00:04.960 Session upkeep
. 2008-02-01 11:00:05.460 Session upkeep
. 2008-02-01 11:00:05.961 Session upkeep
. 2008-02-01 11:00:06.462 Session upkeep
. 2008-02-01 11:00:06.963 Session upkeep
. 2008-02-01 11:00:07.463 Session upkeep
. 2008-02-01 11:00:07.734 Session upkeep
. 2008-02-01 11:00:07.984 Session upkeep
. 2008-02-01 11:00:15.725 Session upkeep
. 2008-02-01 11:00:16.016 Session upkeep
. 2008-02-01 11:00:24.668 Session upkeep
> 2008-02-01 11:00:24.668 TYPE I
< 2008-02-01 11:00:24.668 200 Type I ok.
. 2008-02-01 11:00:25.409 Session upkeep
. 2008-02-01 11:00:25.659 Session upkeep
. 2008-02-01 11:00:26.070 Session upkeep
. 2008-02-01 11:00:36.104 Session upkeep
. 2008-02-01 11:00:36.555 Session upkeep
. 2008-02-01 11:00:47.551 Session upkeep
. 2008-02-01 11:00:48.032 Session upkeep
. 2008-02-01 11:00:59.949 Session upkeep
> 2008-02-01 11:00:59.949 TYPE I
< 2008-02-01 11:00:59.949 200 Type I ok.
. 2008-02-01 11:01:00.930 Session upkeep
. 2008-02-01 11:01:01.251 Session upkeep
. 2008-02-01 11:01:01.581 Session upkeep
. 2008-02-01 11:01:02.112 Session upkeep
. 2008-02-01 11:01:16.132 Session upkeep
. 2008-02-01 11:01:16.603 Session upkeep
. 2008-02-01 11:01:31.765 Session upkeep
> 2008-02-01 11:01:31.765 PWD
< 2008-02-01 11:01:31.765 257 "/pmdf$disk/bi24593/" is current directory.
. 2008-02-01 11:01:32.896 Session upkeep
. 2008-02-01 11:01:33.287 Session upkeep
. 2008-02-01 11:01:33.677 Session upkeep
. 2008-02-01 11:01:34.088 Session upkeep
. 2008-02-01 11:01:34.639 Session upkeep
. 2008-02-01 11:01:55.609 Session upkeep
> 2008-02-01 11:01:55.609 TYPE A
< 2008-02-01 11:01:55.609 200 Type A ok.
. 2008-02-01 11:01:57.011 Session upkeep
. 2008-02-01 11:01:57.431 Session upkeep
. 2008-02-01 11:01:57.852 Session upkeep
. 2008-02-01 11:01:58.273 Session upkeep
. 2008-02-01 11:01:58.693 Session upkeep
. 2008-02-01 11:01:59.174 Session upkeep
. 2008-02-01 11:01:59.725 Session upkeep
. 2008-02-01 11:02:23.359 Session upkeep
> 2008-02-01 11:02:23.359 TYPE I
< 2008-02-01 11:02:23.359 200 Type I ok.
. 2008-02-01 11:02:24.801 Session upkeep
. 2008-02-01 11:02:25.251 Session upkeep
. 2008-02-01 11:02:25.722 Session upkeep
. 2008-02-01 11:02:26.213 Session upkeep
. 2008-02-01 11:02:26.814 Session upkeep
. 2008-02-01 11:02:27.314 Session upkeep
. 2008-02-01 11:02:27.875 Session upkeep
. 2008-02-01 11:02:28.426 Session upkeep
. 2008-02-01 11:02:28.887 Session upkeep
. 2008-02-01 11:02:29.337 Session upkeep
. 2008-02-01 11:02:29.798 Session upkeep
. 2008-02-01 11:02:30.239 Session upkeep
. 2008-02-01 11:02:30.699 Session upkeep
. 2008-02-01 11:02:31.310 Session upkeep
. 2008-02-01 11:03:00.793 Session upkeep
> 2008-02-01 11:03:00.793 TYPE A
< 2008-02-01 11:03:00.793 200 Type A ok.
. 2008-02-01 11:03:02.495 Session upkeep
. 2008-02-01 11:03:03.236 Session upkeep
. 2008-02-01 11:03:03.897 Session upkeep
. 2008-02-01 11:03:04.868 Session upkeep
. 2008-02-01 11:03:05.379 Session upkeep
. 2008-02-01 11:03:05.870 Session upkeep
. 2008-02-01 11:03:06.401 Session upkeep
. 2008-02-01 11:03:06.901 Session upkeep
. 2008-02-01 11:03:07.402 Session upkeep
. 2008-02-01 11:03:07.913 Session upkeep
. 2008-02-01 11:03:08.464 Session upkeep
. 2008-02-01 11:03:09.084 Session upkeep
. 2008-02-01 11:03:09.785 Session upkeep
. 2008-02-01 11:03:10.677 Session upkeep
. 2008-02-01 11:03:11.458 Session upkeep
. 2008-02-01 11:03:12.479 Session upkeep
. 2008-02-01 11:03:13.060 Session upkeep
. 2008-02-01 11:03:13.671 Session upkeep
. 2008-02-01 11:03:14.512 Session upkeep
. 2008-02-01 11:03:15.143 Session upkeep
. 2008-02-01 11:03:15.644 Session upkeep
. 2008-02-01 11:03:16.145 Session upkeep
. 2008-02-01 11:03:16.655 Session upkeep
. 2008-02-01 11:03:17.156 Session upkeep
. 2008-02-01 11:03:17.657 Session upkeep
. 2008-02-01 11:03:18.157 Session upkeep
. 2008-02-01 11:03:18.658 Session upkeep
. 2008-02-01 11:03:19.159 Session upkeep
. 2008-02-01 11:03:19.670 Session upkeep
. 2008-02-01 11:03:20.170 Session upkeep
. 2008-02-01 11:03:20.781 Session upkeep
. 2008-02-01 11:03:21.482 Session upkeep
. 2008-02-01 11:03:22.163 Session upkeep
. 2008-02-01 11:03:22.734 Session upkeep
> 2008-02-01 11:03:22.734 TYPE I
< 2008-02-01 11:03:22.734 200 Type I ok.
. 2008-02-01 11:03:24.346 Session upkeep
. 2008-02-01 11:03:24.867 Session upkeep
. 2008-02-01 11:03:25.388 Session upkeep
. 2008-02-01 11:03:25.909 Session upkeep
. 2008-02-01 11:03:26.429 Session upkeep
. 2008-02-01 11:03:26.950 Session upkeep
. 2008-02-01 11:03:27.471 Session upkeep
. 2008-02-01 11:03:27.982 Session upkeep
. 2008-02-01 11:03:28.502 Session upkeep
. 2008-02-01 11:03:29.233 Session upkeep
* 2008-02-01 11:03:29.233 (EStringListError) List index out of bounds (-200)
. 2008-02-01 11:03:29.263 Session upkeep
. 2008-02-01 11:03:29.764 Session upkeep
. 2008-02-01 11:03:30.265 Session upkeep
. 2008-02-01 11:03:30.766 Session upkeep
. 2008-02-01 11:03:31.266 Session upkeep
. 2008-02-01 11:03:31.767 Session upkeep
. 2008-02-01 11:03:32.268 Session upkeep
. 2008-02-01 11:03:32.768 Session upkeep
. 2008-02-01 11:03:33.269 Session upkeep
. 2008-02-01 11:03:33.770 Session upkeep
. 2008-02-01 11:03:34.281 Session upkeep
. 2008-02-01 11:03:34.771 Session upkeep
. 2008-02-01 11:03:35.272 Session upkeep
. 2008-02-01 11:03:35.773 Session upkeep
. 2008-02-01 11:03:36.274 Session upkeep
. 2008-02-01 11:03:36.774 Session upkeep
. 2008-02-01 11:03:37.275 Session upkeep
. 2008-02-01 11:03:37.776 Session upkeep
. 2008-02-01 11:03:38.276 Session upkeep
. 2008-02-01 11:03:38.777 Session upkeep
. 2008-02-01 11:03:39.278 Session upkeep
. 2008-02-01 11:03:39.779 Session upkeep
. 2008-02-01 11:03:40.289 Session upkeep
. 2008-02-01 11:03:40.780 Session upkeep
. 2008-02-01 11:03:41.281 Session upkeep
. 2008-02-01 11:03:41.781 Session upkeep
. 2008-02-01 11:03:42.282 Session upkeep
. 2008-02-01 11:03:42.783 Session upkeep
. 2008-02-01 11:03:43.284 Session upkeep
. 2008-02-01 11:03:43.784 Session upkeep
. 2008-02-01 11:03:44.285 Session upkeep
. 2008-02-01 11:03:44.786 Session upkeep
. 2008-02-01 11:03:45.286 Session upkeep
. 2008-02-01 11:03:45.787 Session upkeep
. 2008-02-01 11:03:46.288 Session upkeep
. 2008-02-01 11:03:46.789 Session upkeep
. 2008-02-01 11:03:47.289 Session upkeep
. 2008-02-01 11:03:47.790 Session upkeep
. 2008-02-01 11:03:48.291 Session upkeep
. 2008-02-01 11:03:48.792 Session upkeep
. 2008-02-01 11:03:49.292 Session upkeep
. 2008-02-01 11:03:49.793 Session upkeep
. 2008-02-01 11:03:50.294 Session upkeep
. 2008-02-01 11:03:50.794 Session upkeep
. 2008-02-01 11:03:51.295 Session upkeep
. 2008-02-01 11:03:51.796 Session upkeep
. 2008-02-01 11:03:52.297 Session upkeep
. 2008-02-01 11:03:52.797 Session upkeep
> 2008-02-01 11:03:52.797 TYPE A
< 2008-02-01 11:03:52.797 200 Type A ok.
. 2008-02-01 11:03:53.298 Session upkeep
. 2008-02-01 11:03:53.799 Session upkeep
. 2008-02-01 11:03:54.299 Session upkeep
. 2008-02-01 11:03:54.800 Session upkeep
. 2008-02-01 11:03:55.301 Session upkeep
. 2008-02-01 11:03:55.802 Session upkeep
. 2008-02-01 11:03:56.302 Session upkeep
. 2008-02-01 11:03:56.803 Session upkeep
. 2008-02-01 11:03:56.903 Session upkeep
. 2008-02-01 11:03:56.953 Got reply 1004 to the command 16
. 2008-02-01 11:03:56.953 Disconnected from server
Thank you,
Thanh
This issue is being tracked already.
I'd love to see VMS support. WinSCP and VMS, could the world get any better?
