Topic "shift+Delete, shift+F5 should work like in the explorer"
fjb
I like to see the following feature. When I use in the windows explorer a delete function (in the context menue, the menu, by pressing del, or from the toolbar) while I'm pressing the shift key the file is deleted without putting it in the trash (don't know the right word, I'm working in a german environment). From the trash you can undelete the file.
I would like to see the same behaviour in Winscp. Uing the delete function together with pressing the shift key should also throw the file away without putting it in the trash.
When I use the context menu to delet the file an press shift before aktivte delete the file disapear like I expect. But using F5 or the delete butto or the menu while pressing shift put the file in the trash.
Shift delete does nothing.
fjb
Martin,
Is it possible to implement this?
~BijuGC
Sure Smile
This feature has been implemented already. It will be included into the next major release.
