Topic "Server closed network connection"
boyet-x
I'm new to winscp so I need your help with my problem..
I tried to run a console version of winscp using the command below.
winscp [v_ftp_user]:[v_ftp_pass]@[v_ftp_host] /log="winscp.log" /console /command "option batch on" "option confirm off" "lcd [v_local_path]"
"option transfer ascii" "get [remote file]" "close" "exit"
A portion of the log is shown below.
! 2007-08-07 09:22:39.800 Authenticating with pre-entered password.
. 2007-08-07 09:22:39.810 Access granted
. 2007-08-07 09:22:39.830 Opened channel for session
. 2007-08-07 09:22:39.830 Started a shell/command
. 2007-08-07 09:22:39.830 --------------------------------------------------------------------------
. 2007-08-07 09:22:39.830 Using SFTP protocol.
. 2007-08-07 09:22:39.830 Doing startup conversation with host.
> 2007-08-07 09:22:39.830 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2007-08-07 09:22:39.860 Server sent command exit status 0
. 2007-08-07 09:22:39.860 All channels closed. Disconnecting
. 2007-08-07 09:22:39.860 Server closed network connection
Any explanation why the transfer didn't worked?
Also when using the winscp.exe directly, there's no transfer problem.
Im using v 3.8.2 (build 330).
Thanks a lot.
Please compare log file of console and GUI.
boyet-x
Sorry. should be no problem with the winscp I think. Our sys team informed me that there's some problem with granting some user rights. will update you later.
Thanks Very Happy
