Topic "Invalid argument to date encode"
robw
Hi
We get a error dialog with "Invalid argument to date encode"
We have been moving files between Windows (present system date 8 Aug 2007) and an AIX 5.3 test system (present system date 29 Feb 2008).
Up to date there has been no problem even with these date differences but today when the date clocked over to 29 Feb 2008 we had this problem.
WinSCP 4.0.3 (Build 345)
SCP
Norton commander
Log file snippet
* 2007-08-08 14:46:20.481 Unexpected directory listing line '-rw------- 1 root system 10004 Feb 29 14:40 .sh_history'.
* 2007-08-08 14:46:20.481 Invalid argument to date encode
WinSCP then doesn't list all files
From UNIX terminal all files visible
I can provide log - how do I attach?
Problem is that there is no year in the listing, hence WinSCP expects it to be a 2007, making the date invalid (2007 is not a leap year). Switching to SFTP protocol should fix the problem.
george_skj
We are using the WINSCP 3.7.6. It is published in citix. When we work from GMT +5:00 time zone, we are able to tranfer the files from local desktop to solaris system. Some of our colleagues work from GMT -5:00 time zone. The reeives the error ' Invalid argument to date encode.
Please help to find the solution[/b]
First, please try to upgrade.
For list of reasons WinSCP cannot parse directory listing and possible resolutions, see documentation.
jsgrenon
Hi have this bug, and I have the latest version, do you fix the bug?
Thank
John
Make sure you have the latest version. If you do and you still experience the problem, please post a full log file showing it.
pizzaman383
The problem started happening on connections that used to work fine.
Here is the contents of the debug log:
http://pastebin.com/f38792b12
I have sent you an email with debug version.
flojo
Excat the same problem here. All went well. Just a few days ago the problem accurs.
Thannks for the help!
lanemark
I had a similar issue, and it appeared to resolve itself after I specified a timezone in Windows. The installation of Windows 7 didnt' have a timezone set and this appeared to be causing an issue with reteiving remote directory listings.
robw wrote:
Hi
SCP
Norton commander
Log file snippet
flojo
Hi lanemark, you made my day!!! This is it. It works now after resetting the time zone.
Thanks so much!
Florian
Still, can anyone of you two send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
KenInNH
I've run into this problem also, and would be glad to help out.
-Ken
Gyan
This may help somebody...
This error was driving me crazy. I updated to 4.1.9 with no luck. Then I updated to the latest beta 4.2.4 with, still, no luck. I saw the timezone post and was hoping that would fix it. It didn't as my XP had the timezone already set. So I tried something new...
I switched the timezone on my machine and then switched it back to the original version and now all is good.
Hopefully this will help someone.
Happy Holidays!
BernardS
Great suggestion!
I followed this path and it fixed my problem as well.
Thank you so much!!!!
Happy Holidays!
rcyeager
The same "Invalid argument to date encode" happened to me and was fixed by changing the timezone.
In my case, I had upgraded to Parallels v5 on my Macbook Pro when the problem started. I guess the upgrade changed something in the virtual machine.
Anyway, changing the Windows timezone has resolved the issue for me.
Once again, along with reporting that you also face the issue, can anyone of you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
skaestle
I have the same issue on Windows 7 with the latest WinSCP Version. The fix mentioned above (Setting the Regional Settings in Windows 7) cleared the issue for me too.
I've sent you an E-Mail with my details
TomH
Hello
Also for me, this problem appeared on a Macbook Pro with WinXP running in a Parallels Desktop 5 virtual machine. I installed WinSCP 4.1.9 from sourceforge.net, got the Date Encode error, quit, changed the timezone to something else and changed it back to EST, then ran WinSCP again and got through.
Tom
mydish11
The same issue here. Have Windows 7 and the latest WinSCP.
Are you sure you have WinSCP 4.2.5?
4.2.7 / Windows 7 here and the same problem.
Changing the timezone settings did not help in my case.
Can you send me an email so I can send you a debug version?
Kaspar
Just want to say to those who have this problem, and it doesn't help to change the timezone, this could be the solution:
Rightclik on one of your pictures, and see what date it had last been modified. My camera made it look like they where last modified 1970, and if I loaded the pictures into registax, I got the same error; "Invalid argument to date encode" .
I just opened the pictures in MSPAINT and saved them, without making any changes, and them I could load them into Registax without trouble.
saharhostnile
