Topic "New WinSCP Icon (UPDATED)"
JohnTHaller
While working on WinSCP Portable, I needed a higher resolution icon for use in some scenarios. So, I created one with the same layout as the current icon using 3 different icons from Everaldo's Crystal icon set (also GPL licensed) modified to give the appearance of the original WinSCP logo.
I've posted it as a PNG and as a Windows ICO with 16, 32, 48 and 128 pixel icons in both Windows XP and 256-color format.
PNG Preview
Download WinSCP.ico
(These files will remain up until Sept 14, 2007)
I thought you might like to use it in the standard WinSCP releases. Smile
Regards,
John
UPDATED AUGUST 17: I fixed the shadowing problem on the 128px and 48px images (it looked chopped off).
Thanks! Already downloaded.
JohnTHaller
There were some issues with the shadowing on the 128px and 48px... it looked chopped off on the right-hand side. I've fixed the issues, so please grab the new version.
Thanks.
Jalamorm
Cool!! Thank you.
salnet
I also made a new icon for winscp. It's Vista-compatible (256x256 px).
Source for the icons are the windows-icons itself, I re-arranged the icons only.
You can download the icon from here:
http://rapidshare.com/files/100307464/winscp.ico.html
Kind regards,
Timo
salnet
It seems that the ressource is not acessible at the moment, so I uploaded the files to my own host.
Icon:
http://home.arcor.de/salnet/winscp/winscp2.ico
PNG:
http://home.arcor.de/salnet/winscp/winscp2.png
VinDSL
Thanks, salnet Exclamation
I was looking for a suitable WinSCP icon to use with Stardock ObjectDock Very Happy
fredley
I didn't like the way the icon looks in my Windows 7 taskbar, so I made my own, very basic, replacement:
http://www.tommedley.com/images/scp.ico
