Topic "icons are all illegiable"
tonym
why are my icons all illegiable - im using win98 version 3.0
everything else works fine except my icons
tonym@pronto.com.au
Which icons?
tonym
all my icons are hazy - i can see them but i can make out what they say or look like - i can even see the images - they are just hazy/fuzzy
any suggestion on how i can fix it - i downloaded the scpversion 3.0 installation - all the icons at the top of the page/screen - all other applications show the icons as they should......
thanks
So you mean icons on the toolbar? There is one well know bug in Borland products (WinSCP is made using Borland C++Builder) with displaying icons on some types of graphic cards. It this is your problem, I cannot help you. I'm sorry.
