Topic "AD username + url handler => not working"
celebdor
I'm currently working on an integration project that let's you open a winscp instance through the navigator but I have found a problem in the fact that since 3.7.1 the plus character (+) from urls is automatically converted to an space, so my url which is sftp://ACTION+foo.bar@hostname:22/srv/userspace ends up being sftp://ACTION foo.bar@hostname:22/srv/userspace, an address that obviously makes it impossible to authenticate. I would highly appreciate any tip or trick you could point me to use to solve this problem besides the obvious response of using an older version.
Thank you Smile
You can encode + as %2B.
celebdpr
Thanks, I'll try it right now Smile
celebdor
It doesn't work ;(, it still replaces the %2B with a space character.
