Topic "WinScp and Vista"
I can only transfer very small files with WinScp using Vista. When ever I try to transfer a larger file, WinScp stops transferring after approximately 12,000 bytes. I get the retry message but I cannot get past this limit.
I am able to connect using a machine with XP without a problem.
Any assistance with settings in Vista or WinScp would be appreciated.
I finally found the fix to this problem in case anyone else has the same problem.
It is related to the auto tuning function in Vista.
Type in the line at the command prompt: netsh interface tcp set global autotuninglevel=disabled
Afterwards WinScp downloads/uploads files without a problem.
Sooner Al
You might try restricted first to see if it works...
FYI, here is the article that talks about this issue...
"When all else fails, read the instructions..."
