Topic "Atomic file transfers"
ikti
When i upload my PHP scripts using WINScp for a short period they are incomplete. It would be nice if file was uploaded under temp name first and after transfer is complete instantly renamed.
Set resume limit threshold to 0.
itki
It didn't solve my problem. Now during upload file does not exist.
Sorry you are right! The feature is already implemented, but not released yet. I've forgot Wink
Hasufin
Martin, will this "unreleased" feature also support going the other way?
Basically.... I need to move files from an FTP server to me... I need to remove them after I download each one. In this case it is a large directory containing lots of files.. so doing a blind mget * / mdelete * style would not work so well Smile
Otherwise, I'll have to make some major work arounds..... so far Im thinking:
- login
- write out directory listing to a tmp file.
- read file into vbscript
- parse out the filenames
- create a "temp" script.. that contains gets & rm's for each file...
- run winscp w/ temp script
- remove tmp file & script
I'm not sure that my lil app would be widely used - so no use in custom adding stuff.... but if you already have it coded........ Smile Never hurts to ask right?
The next version will support "get /delete" as an equivalent of "Move" command in GUI. I suppose that this is what you ask for.
Hasufin
......... yep. You summarize so easily!
