Topic "winscp.com command to change remote directory"
vmanne
I am using this command syntax to transfer file to remote location.
echo put "file with spaces.dat" | winscp.com /command "open user@example.com" "option transfer ascii"
Question: How do I change the remote target directory from root to root/xx?
I researched to find this post http://winscp.net/forum/viewtopic.php?t=4756&highlight=command but was not able to find preferences to save the ini file. How do I do that?
Thanks for your time!
Vik
I'm not sure what you mean, maybe you look for:
put "file with spaces.dat" /xx
