Topic "the length of the username is limited to 50 characters."
Franz Frese
winscp403setupintl.exe
ftp
german
Norton IF
Do you mean limitation of input box on login dialog?
Franz Frese
yes : Session Edit , User Name
The ftp-server I want to connect is :
frauen-geschichtswerkstatt.homepage.t-online.de
the username is (definition by t-online.de)
frauen-geschichtswerkstatt@frauen-geschichtswerkstatt.homepage.t-online.de
I'll increase the limit in the next release. Meanwhile you should be able to set longer username directly in configuration (registry or ini file).
Franz Frese
thank you, ini-file works fine
