Topic "Login history"
Dim
Is there anyway to check the login history for login attempts to the ip address you usually connect to. For example: I connect to u.usc.edu and have my own user name / password to connect. Now I want to view the history of login attempts which include when I logged in, the ip address, the time, etc. Is there anyway to do that?
Thanks alot!
WinSCP does not log the connection attempts. Your server may (should).
