Topic "Why the password is not encrypted?!"
quest
Hello, why the FTP password is not encrypted while saving it for further sessions???
its really bad i think.
quest
It is. Where do you see it unencrypted?
quest
Když jsem ten program spustil a napsal daje pro přihlšen na normln vzdlen FTP server tak se mě to pak zeptalo jestli chci přihlšen uložit na přště, ale že to nebude nějak zašifrovno nebo tak... ?
dky
quest
quest wrote:
Kdy jsem ten program spustil a napsal daje pro přihlen na normln vzdlen FTP server tak se mě to pak zeptalo jestli chci přihlen uloit na přtě, ale e to nebude nějak zaifrovno nebo tak... ?
dky
Prectete si to prosim poradne.
Demon Rob
So why DO you provide password encryption?
I've just come from the filezilla forums where the developer says that there is absolutely no need for it.
Thats why I'm here!
Seems FZ2 had password obfuscation and not encryption. !?!!
And he now thinks neither is necessary.
Plus filezilla 3 doesn't offer remote file view/edit, or keep connected options that filezilla2 had.
Lets see how good this program is!
Demon Rob
When the program saves a password it says its not really secure. That's what he means I reckon.
What would be good for the program would be a master password. Enter it once when you open the program and use it to encode all the other passwords.
That would be nice!
ps: I like this program much better than filezilla by the way!
That's what all programs have, including WinSCP. It think it is better than nothing.
Not all programs simply obfuscate the password - e.g. Subversion http://subversion.tigris.org/svn_1.2_releasenotes.html#win32-password-encryption
Google turns up https://technet.microsoft.com/en-us/library/bb457116.aspx - essentially a Windows API that will encrypt a file based on the currently logged on users credentials. If the users password is reset, the contents of the file is lost permanently (barring brute force attacks) I've no idea if that's what Subversion uses, but I suspect that it is.
Can I suggest that the WinSCP developers look at using that to provide a better mechanism for protecting passwords.
Greg
It is good point. On the other hand, this prevents usage of portable configuration, that many users of WinSCP benefit from.
Demon Rob
Definitely better than nothing, but clearly not optimal due to the well known problems.
But is there any good reason not to allow the user to enter a single password at program startup, one way hashed, to allow full access to the passwords?
Well, public key authentication with pageant is superior feature to this. Supposing you use SFTP/SCP...
'google pageant public key' - yeah, looks good.
so lets implement both, since standard ftp still requires standard password doesn't it?
(its just so easy to say gimme gimme gimme isnt it!)
OK, if more people ask for it... Smile
