Topic "Errorlevel always 0 NT 4"
Hopper
Im using a simple put winscpscript.txt to scp a file:
option batch abort
open user:password@example.com
put c:/localfile*.* /remotedir/
close
On the other hand, Im using a NT batch like this:
:retryloop
winscp3.com /script=winscpscript.txt
echo errorlevel=%errorlevel%
if %errorlevel% neq 0 goto retryloop
delete localfile*.*
Unfortunately, the exit code is ALWAYS 0, which means that the local file is always deleted even if
you plug off the network cable.
Of course, theres a timeout of winscp.
Ive read all your docs and suggestions about this topic and tried out a lot of things to check if NT4 has a problem with errorlevels but I still cant find why you always return 0.
Please help!
Thanks in advance!
Can you try simpler syntax:
if errorlevel 1 goto retryloop
