| Author | Message |
VKNYVZ
Guest |
Posted: 18 Sep 2007 15:41
WinSCP by far the best fTP sftp client but this NEW problem which is constantly asking for confirmation when uploading the same file, is really annoying!
you guys probably know about this already, please get it fixed, as you just can't develop a site like that, you get tired after a while! I first thought it was a O/S issue(used first in vista) but no seeing many experiencing the same issue. I am using WINSCP on the following O/S'es windows v5.1.2600 (XP) windows v5.2.3790 (server 2003 r2) windows v6.0.6000 (vista ultimate) all has the same problem. please, please get it solved. being an old pc guy and all, nc (norton commander style interface is really the way to go) as Filezilla fails at that! thanks Volkan vknyvz.com |
| Advertisements |
prikryl
Posts: 11792 Location: Prague, Czech republic |
Posted: 23 Sep 2007
When have you started having the problem?
_________________ Martin Prikryl |
Posted: 26 Sep 2007 01:50
I've asked about this exact same problem before. It doesn't matter that all of the options are set to disable confirmations, it still constantly pops up. Furthermore, even when it pops up and you check "Do Not Ask Again", it pops right up again on the next file. It's so disruptive and annoying I have to use another FTP program until this gets fixed.
Windows XP, Latest Build. http://winscp.net/forum/viewtopic.php?t=4808 http://winscp.net/forum/viewtopic.php?t=4695 http://winscp.net/forum/viewtopic.php?t=4699 http://winscp.net/forum/viewtopic.php?t=2203 |
Posted: 26 Sep 2007 03:02
This is very annoying!
Please fix!! |
prikryl
Posted: 2 Oct 2007
I would fix this, if someone provides me enough information. Please follow bug reporting guidelines. Thanks!
| Advertisements |
WinSCP is an open source SFTP client and FTP client for Windows. Its main function is the secure file transfer between a local and a remote computer. Beyond this, WinSCP offers basic file manager functionality. It uses Secure Shell (SSH) and supports, in addition to Secure FTP, also legacy SCP protocol. [More]
WinSCP is also available as a plugin to two file managers, FAR and Altap Salamander.
WinSCP is free, open-source software, and is distributed under the GNU General Public License (GPL). [More]
Site design by Black Gate
