Topic "Need to build a batch file to send files sFTP via winscp"
DHarper2
<Moved from Documentation Forum...DUH!>
Hi-
I am a mac java guy transitioning to windows / .net.
I need to automate the sending of a file via winSCP. I have it set up on my windows 2003 server and can drag and drop via the GUI. However, I need to send a file on a weekly basis from sql2005. Can someone point me to a batch file 'how to' to walk me through building a .bat file? I am assuming I can then schedule the bat file to fire off at the desired time via scheduled events in windows. Bonus points for any scripts that can fire off a bat file from asp.net.
TIA
Dan
You will find an example in documentation.
For scheduling, see FAQ.
Thanks, tried that one, no luck.
I was just wondering if anyone had a batch file they could cut and paste so I could take a look at the code.
thanks
Dan
Ok, let me ask it this way.
If I save the following file in a .bat file and run it, shouldn't it work?
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
open myuserName:MyPassword@myftpserver.net:22 (DO I need :22 here?)
# Change remote directory
cd /usr/home/ftpaccts/MyDirectory/
# Force binary mode transfer
option transfer binary
# Download file to the local directory
get TestFile.txt C:\Documents and Settings\Administrator\Desktop\DATA_IN
# Disconnect
close
-OR- Asked another way, if I set up windows scheduled event to fire up winSCP, WHERE do I add the code to run the get and put? I only have a place for putting comments in the scheduled task. Im running win 2003 server.
Thank you for any clarity
Dan
jc
The script that you listed is to be interpreted by winscp. In the documentation
http://winscp.net/eng/docs/scripting
this script is named example.txt see the two examples at the bottom of the docs page to see the command line syntax for using the script.
Open a shell window, at the command prompt experiment with these commands and options and when you find the right command/syntax to accomplish the task from the command line, put that code into your bat file.
Good Luck,
-jc
option batch on
# Disconnect
close
Dan
dharper3
Thanks!
I got some scripts running using command line and winscp.com
Question: What does the batch file look like?
C:\Program Files\WinSCP\winscp.com
open MyUserName:MyPassword@MySFTPserver.net
get TestFile.txt c:\
close
will not work, but it will in command line.
I am so close, so tired, so frusterdated.
thanks
dan
Put the individual steps into your script file.
For example: my_script.txt contains the following
# start script code
close
# end script
put my_script.txt in the same folder as winscp.exe
You should now be able to use the script to ftp
promp> winscp.exe /console /script=my_script.txt
if this works okay then all your bat file needs to have in it is the above command.
my_ftp.bat contains
# start
# end
When you run my_ftp.bat all it does is executes the command /w options you've included.
-jim
dharper3 wrote:
Thanks!
close
thanks
dan
Dan
That worked, thank you SO much!
For automation please read FAQ.
thinclient
I would like to see the results of the script in dos prompt but when I launch the batch file from DOS prompt it connects, calls the script, which sftp's the file into the directory. It works, but all I see in the DOS prompt is this:
"C:\Program Files (x86)\WinSCP\WinSCP.exe"
/log="C:\Logs\WinSCP.log"
/ini=nul /command
/script="C:\Script.txt"
And I would like to see the script running e.g. if script has a command "dir" I'd see a directory listing output to DOS prompt.
thinclient
# start script code
close
# end script
my_ftp.bat contains
# start
# end
-jim
dharper3 wrote:
Thanks!
close
thanks
dan
/ini=nul /command
Use the winscp.com, not winscp.exe:
https://winscp.net/eng/docs/executables
