Topic "Error Clearing National User Variables"
Akito
I get this error: Error Clearing National User Variables
Along with: Connection has been unexpectedly closed.
This happens when I try to login to my server. I honestly have no clue what I'm doing.
Please, post a log file.
Akito
Hi there, here is the log file (I edited out the host and user)
. WinSCP Version 3.1.0 (Build 165)
. Login time: Sunday, July 20, 2003 8:21:47 PM
. Session name: xxxxx@xxxxxxx.xxx
. Host name: xxxxx.xxx (Port: 22)
. User name: xxxxxx (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 0
. Looking up host "xxxxxxx.xxx"
. Connecting to 64.xxx.xxx.252 port 22
. Server version: SSH-1.99-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Jul 14 2003 13:14:02
. Asking user:
. The server's host key is not cached in the registry. You have no guarantee that the server is the computer you think it is. The server's key fingerprint is: ssh-rsa 1024 f5:b7:5d:15:98:cc:e6:5b:82:17:3f:fd:e9:a5:4c:77
. If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. Continue connecting and add host key to the cache? ()
. Host key fingerprint is:
. ssh-rsa 1024 f5:b7:5d:15:98:cc:e6:5b:82:17:3f:fd:e9:a5:4c:77
! Using username "xxxxxx".
. Keyboard-interactive authentication refused
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SCP protocol
> echo "WinSCP: this is end-of-file:0"
! TERM environment variable not set.
< Warning: no access to tty (Bad file descriptor).
< Thus no job control in this shell.
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$status" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$status"
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$status"
> unalias "cd" ; echo "WinSCP: this is end-of-file:$status"
> unalias "ls" ; echo "WinSCP: this is end-of-file:$status"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$status"
> unalias "scp" ; echo "WinSCP: this is end-of-file:$status"
> unalias "rm" ; echo "WinSCP: this is end-of-file:$status"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$status"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chown" ; echo "WinSCP: this is end-of-file:$status"
> unalias "unset" ; echo "WinSCP: this is end-of-file:$status"
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$status"
> unalias "alias" ; echo "WinSCP: this is end-of-file:$status"
> unalias "ln" ; echo "WinSCP: this is end-of-file:$status"
> unalias "%s" ; echo "WinSCP: this is end-of-file:$status"
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$status"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$status"
* (ESshFatal) Error clearing national user variables.
* Connection has been unexpectedly closed.
I do not know what is the problem. Just try to turn off 'Clear national variables' on SCP tab of login dialog or use SFTP instead.
