Topic "Deleting filenames with leading spaces"
Greg
Against a Windows server (not tried on UNIX), WinSCP cannot delete a file that has a leading space. When attempting to delete " readme.txt", WinSCP errors with:
/path/to/directory/readme.txt: The system cannot find the file specified.
- i.e. it loses the leading space.
Greg
Can you post a full error message? Also what protocol are you using?
Greg
Sory; I should have said. I'm using FTP. The relevant bits of the log are below - you can see that the leading space is being sent from server to client, but not from client to server on the delete ...
. 2007-10-12 15:08:11.916 Connecting to ****...
. 2007-10-12 15:08:11.931 FtpControlSocket.cpp(1056): OnConnect(0)  OpMode=1 OpState=-1   caller=0x01d2684c
. 2007-10-12 15:08:11.931 Connected with ****. Waiting for welcome message...
. 2007-10-12 15:08:11.947 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=-1   caller=0x01d2684c
< 2007-10-12 15:08:11.947 220-Microsoft FTP Service
. 2007-10-12 15:08:12.103 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=-1   caller=0x01d2684c
< 2007-10-12 15:08:12.103     Welcome.
< 2007-10-12 15:08:12.103 220 Byw329a002
> 2007-10-12 15:08:12.103 USER ************
. 2007-10-12 15:08:12.119 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=0   caller=0x01d2684c
< 2007-10-12 15:08:12.119 331 Password required for ************.
> 2007-10-12 15:08:12.119 PASS ************
. 2007-10-12 15:08:12.447 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=3   caller=0x01d2684c
< 2007-10-12 15:08:12.447 230 User ************ logged in.
> 2007-10-12 15:08:12.447 SYST
. 2007-10-12 15:08:12.463 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=-14   caller=0x01d2684c
< 2007-10-12 15:08:12.463 215 Windows_NT
> 2007-10-12 15:08:12.463 FEAT
. 2007-10-12 15:08:12.478 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=-13   caller=0x01d2684c
< 2007-10-12 15:08:12.478 211-FEAT
. 2007-10-12 15:08:12.603 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=1 OpState=-13   caller=0x01d2684c
< 2007-10-12 15:08:12.603     SIZE
< 2007-10-12 15:08:12.603     MDTM
< 2007-10-12 15:08:12.603 211 END
. 2007-10-12 15:08:12.603 Connected
. 2007-10-12 15:08:12.603 FtpControlSocket.cpp(4180): ResetOperation(1)  OpMode=1 OpState=-13   caller=0x01d2684c
. 2007-10-12 15:08:12.603 Got reply 1 to the command 1
. 2007-10-12 15:08:12.603 --------------------------------------------------------------------------
. 2007-10-12 15:08:12.603 Using FTP protocol.
. 2007-10-12 15:08:22.743 Changing directory to "ajax".
. 2007-10-12 15:08:22.743 FtpControlSocket.cpp(1269): FtpCommand(CWD ajax)  OpMode=0 OpState=-1   caller=0x01d2684c
> 2007-10-12 15:08:22.743 CWD ajax
. 2007-10-12 15:08:22.947 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=2 OpState=-1   caller=0x01d2684c
< 2007-10-12 15:08:22.947 250 CWD command successful.
. 2007-10-12 15:08:22.947 FtpControlSocket.cpp(4180): ResetOperation(1)  OpMode=2 OpState=-1   caller=0x01d2684c
. 2007-10-12 15:08:22.947 Got reply 1 to the command 16
. 2007-10-12 15:08:22.947 Getting current directory name.
. 2007-10-12 15:08:22.947 FtpControlSocket.cpp(1269): FtpCommand(PWD)  OpMode=0 OpState=-1   caller=0x01d2684c
> 2007-10-12 15:08:22.947 PWD
. 2007-10-12 15:08:22.962 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=2 OpState=-1   caller=0x01d2684c
< 2007-10-12 15:08:22.962 257 "/************/backup-2007-04-17/ajax" is current directory.
. 2007-10-12 15:08:22.962 FtpControlSocket.cpp(4180): ResetOperation(1)  OpMode=2 OpState=-1   caller=0x01d2684c
. 2007-10-12 15:08:22.962 Got reply 1 to the command 16
. 2007-10-12 15:08:22.962 FtpControlSocket.cpp(1276): List(FALSE,0,"/************/backup-2007-04-17/ajax/","",1)  OpMode=0 OpState=-1   caller=0x01d2684c
. 2007-10-12 15:08:22.962 Retrieving directory listing...
> 2007-10-12 15:08:22.962 TYPE A
. 2007-10-12 15:08:22.978 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=4 OpState=8   caller=0x01d2684c
< 2007-10-12 15:08:22.978 200 Type set to A.
. 2007-10-12 15:08:22.978 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0)  OpMode=4 OpState=8   caller=0x01d2684c
> 2007-10-12 15:08:22.978 PORT 10,215,156,222,11,130
. 2007-10-12 15:08:23.009 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=4 OpState=7   caller=0x01d2684c
< 2007-10-12 15:08:23.009 200 PORT command successful.
. 2007-10-12 15:08:23.009 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0)  OpMode=4 OpState=7   caller=0x01d2684c
. 2007-10-12 15:08:23.009 TransferSocket.cpp(597): SetActive()   caller=0x01d85358
> 2007-10-12 15:08:23.009 LIST -a
. 2007-10-12 15:08:23.025 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=4 OpState=9   caller=0x01d2684c
< 2007-10-12 15:08:23.025 150 Opening ASCII mode data connection for /bin/ls.
. 2007-10-12 15:08:23.025 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0)  OpMode=4 OpState=9   caller=0x01d2684c
. 2007-10-12 15:08:23.040 TransferSocket.cpp(418): OnAccept(0)   caller=0x01d85358
. 2007-10-12 15:08:23.072 TransferSocket.cpp(557): OnClose(0)   caller=0x01d85358
. 2007-10-12 15:08:23.072 TransferSocket.cpp(1179): Close()   caller=0x01d85358
. 2007-10-12 15:08:23.072 FtpControlSocket.cpp(2070): TransferEnd(4)  OpMode=4 OpState=10   caller=0x01d2684c
. 2007-10-12 15:08:23.072 FtpControlSocket.cpp(1276): List(TRUE,0,"","",0)  OpMode=4 OpState=10   caller=0x01d2684c
. 2007-10-12 15:08:23.072 07-07-06  04:00PM                  215  readme.txt
. 2007-10-12 15:08:23.072 10-12-07  03:05PM                    5 text.txt
. 2007-10-12 15:08:23.072 TransferSocket.cpp(108): ~CTransferSocket()   caller=0x01d85358
. 2007-10-12 15:08:23.165 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=4 OpState=10   caller=0x01d2684c
< 2007-10-12 15:08:23.165 226 Transfer complete.
. 2007-10-12 15:08:23.165 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0)  OpMode=4 OpState=10   caller=0x01d2684c
. 2007-10-12 15:08:23.165 Directory listing successful
. 2007-10-12 15:08:23.165 FtpControlSocket.cpp(4180): ResetOperation(1)  OpMode=4 OpState=10   caller=0x01d2684c
. 2007-10-12 15:08:23.165 Got reply 1 to the command 2
. 2007-10-12 15:08:23.197 Session upkeep
. 2007-10-12 15:08:23.431 Session upkeep
. 2007-10-12 15:08:23.931 Session upkeep
. 2007-10-12 15:08:24.431 Session upkeep
. 2007-10-12 15:08:24.931 Session upkeep
. 2007-10-12 15:08:25.431 Session upkeep
. 2007-10-12 15:08:25.931 Session upkeep
. 2007-10-12 15:08:26.431 Session upkeep
. 2007-10-12 15:08:26.587 Deleting file "readme.txt".
. 2007-10-12 15:08:26.587 FtpControlSocket.cpp(4356): Delete("readme.txt", "/802938884/development/webappsdev-resourcing/backup-2007-04-17/ajax/")  OpMode=0 OpState=-1   caller=0x01d2684c
> 2007-10-12 15:08:26.587 DELE /802938884/development/webappsdev-resourcing/backup-2007-04-17/ajax/readme.txt
. 2007-10-12 15:08:26.618 FtpControlSocket.cpp(878): OnReceive(0)  OpMode=256 OpState=-1   caller=0x01d2684c
< 2007-10-12 15:08:26.618 550 /802938884/development/webappsdev-resourcing/backup-2007-04-17/ajax/readme.txt: The system cannot find the file specified.
. 2007-10-12 15:08:26.618 FtpControlSocket.cpp(4356): Delete("", "")  OpMode=256 OpState=-1   caller=0x01d2684c
. 2007-10-12 15:08:26.618 FtpControlSocket.cpp(4180): ResetOperation(1)  OpMode=256 OpState=-1   caller=0x01d2684c
. 2007-10-12 15:08:26.618 Got reply 1 to the command 32
. 2007-10-12 15:08:26.618 Asking user:
. 2007-10-12 15:08:26.618 Error deleting file 'readme.txt'. ("/802938884/development/webappsdev-resourcing/backup-2007-04-17/ajax/readme.txt: The system cannot find the file specified. ")
OK thanks I'll check that.
The problem is inherited from FileZilla project (on which the FTP code of WinSCP is based). I'm not experienced with the FileZilla code enough to fix that ATM.
