Topic "WinSCP much slower than pscp -scp"
benh57
Putty 0.60's "pscp.exe -scp" gets me about 2,000 kB/sec of speed over WinSCP (using SCP) 4.0.4 with default connection settings. (force SCP on)
Could this be beacuse WinSCP is using an older version of putty code? Any plans to integrate 0.60?
thanks,
-Ben
Can you try the same with PuTTY 0.58, just to verify that the integration would have a speed benefit?
benh57
Haven't tried the 0.58 putty - i don't think that was it.
I think we figured this out. WinSCP was defaulting to AES. Blowfish is MUCH faster. I suspect pscp is defaulting to blowfish. (haven't checked, though)
Blowfish is plenty secure for us, so we just disabled AES on the server. blowfish gets used as fallback by winscp.
PSCP also uses AES be default.
You can change the algorithm on SSH tab of login dialog.
