Topic "Terminal in SCP doesnt work for me"
thomas
So this is my dillemma, I'm currently trying to hack my iPod touch using WinSCP, to transfer files. The first couple of times worked, now for some reason I get this error whenever i try to open the terminal "Connection has been unexpectedly closed.Server sent command exit status 127."Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended). So can anyone help me? I kinda suck at this stuff so no complicated terms Razz, this has never happened before for me and i think its more the program then the iPod, so can anyone help? Confused
Sorry, I'm not sure what does not work. So are you able to login with WinSCP (maybe using SFTP)? DO I understand right that you get an error after going to Commands > Open Terminal?
thomas
Yes i am able to log into WinSCP but, when i try to go to commands> open terminal like you said, i get that error
The SSH server is probably not able to start a shell. Are you able to login with some SSH terminal (like PuTTY)?
thomas
yeah i can log in with putty, but i'd rather use the the terminal provided in winscp
OK would it help if you specify /bin/bash on scp/shell tab of login dialog?
Bigjim
Great !
I have the same problem and after a quick launch with Google, I found this thread.
Thank you for your help Prikryl Smile
hey guys,
I have the same problem. however for me the bin/bash/ does not work.
do you have any other ideas how I could make the terminal working?
thanks,
rog
~Biju
You may also want check iPhone sites. I have listed some links here
skylinemate@...
I have the exact same problem
my terminal doesnt work, and that error comes up
is there anyway to fix it? i have tried reinstalling winscp aswell
if anyone can help please add me on msn: skylinemate@hotmail.com
thanks a lot
Can you give us more details?
i am also trying to do that with my ipod touch
on sftp aswell
it will come up with some shell thing that its not supported, then htat error 127 when i press ok
on sftp aswell
What problem do you get with SCP?
