Topic "Possible Bug while transfering very small files via SFTP"
Camember
hello,
I've experienced an annoying bug,
using Winscp 4.4 and prior versions when transfering very small files (tipically desktop.ini in windows)
the error message (sorry err message is in french):
Fichier ou repertoire inexistant
Code l'erreur: 2
Message d'erreur du serveur(en): no such file
Code demand: 3
approximative translation:
File or folder doesn't exist
Error Code: 2
Error message from the serveur(en): no such file
Asked code: 3
i've tested to create a new empty .txt, same error.
i've tryed to past some text in the files, same error
increasing .txt to 4.5 Mo.
I've been able to reproduce the error from 3 different stations with WinSCP 4.4 and 2 versions before, running under Windows XP SP2.
I've tested the same files on the same serveur with FileZilla and it works fine.
The serveur is MySecureShell running on OpenBSD.
i've not been able to find log file of the WinSCP client.
I hope this report 'll be usefull.
Best regards.
Can you post a log file?
Camember
The log file:
. 2007-10-22 13:11:45.784 --------------------------------------------------------------
. 2007-10-22 13:11:45.784 WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 2)
. 2007-10-22 13:11:45.784 Login time: lundi 22 octobre 2007 13:11:45
. 2007-10-22 13:11:45.784 Session name: session
. 2007-10-22 13:11:45.784 Host name: XXX.XXX.XXX.XXX (Port: 1022)
. 2007-10-22 13:11:45.794 User name: testscp (Password: Yes, Key file: No)
. 2007-10-22 13:11:45.794 Transfer Protocol: SFTP (SCP)
. 2007-10-22 13:11:45.794 SSH protocol version: 2; Compression: No
. 2007-10-22 13:11:45.794 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-10-22 13:11:45.794 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-10-22 13:11:45.794 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-10-22 13:11:45.794 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-10-22 13:11:45.794 SFTP Bugs: -,-,-
. 2007-10-22 13:11:45.794 Proxy: none
. 2007-10-22 13:11:45.794 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-10-22 13:11:45.794 Shell: default, EOL: 0
. 2007-10-22 13:11:45.794 Local directory: default, Remote directory: home, Update: No,
Cache: Yes
. 2007-10-22 13:11:45.794 Cache directory changes: Yes, Permanent: Yes
. 2007-10-22 13:11:45.794 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-10-22 13:11:45.794 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-10-22 13:11:45.794 --------------------------------------------------------------
. 2007-10-22 13:11:45.944 Looking up host "XXX.XXX.XXX.XXX"
. 2007-10-22 13:11:45.954 Connecting to XXX.XXX.XXX.XXX port 1022
. 2007-10-22 13:11:46.265 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:46.275 Looking for incoming data
. 2007-10-22 13:11:46.355 Select result is 1
. 2007-10-22 13:11:46.365 Server version: SSH-1.99-OpenSSH_4.2
. 2007-10-22 13:11:46.375 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2007-10-22 13:11:46.385 Using SSH protocol version 2
. 2007-10-22 13:11:46.395 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:46.405 Looking for incoming data
. 2007-10-22 13:11:46.425 Select result is 1
. 2007-10-22 13:11:46.435 Doing Diffie-Hellman group exchange
. 2007-10-22 13:11:46.445 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:46.455 Looking for incoming data
. 2007-10-22 13:11:46.716 Select result is 1
. 2007-10-22 13:11:46.736 Doing Diffie-Hellman key exchange
. 2007-10-22 13:11:46.986 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:47.006 Looking for incoming data
. 2007-10-22 13:11:47.186 Select result is 1
. 2007-10-22 13:11:47.487 Host key fingerprint is:
. 2007-10-22 13:11:47.497 ssh-rsa 2048 6a:e2:17:ce:1f:eb:39:5d:cc:b9:f0:4c:40:30:11:38
. 2007-10-22 13:11:47.517 Initialised AES-256 client->server encryption
. 2007-10-22 13:11:47.527 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-10-22 13:11:47.537 Initialised AES-256 server->client encryption
. 2007-10-22 13:11:47.557 Initialised HMAC-SHA1 server->client MAC algorithm
. 2007-10-22 13:11:47.567 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:47.587 Looking for incoming data
. 2007-10-22 13:11:47.787 Select result is 1
! 2007-10-22 13:11:47.827 Utilisation du nom d'utilisateur "testscp".
. 2007-10-22 13:11:47.837 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:47.857 Looking for incoming data
. 2007-10-22 13:11:47.907 Select result is 1
. 2007-10-22 13:11:47.927 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:47.937 Looking for incoming data
. 2007-10-22 13:11:47.977 Select result is 1
. 2007-10-22 13:11:47.997 Keyboard-interactive authentication refused
. 2007-10-22 13:11:48.007 Session password prompt (testscp@XXX.XXX.XXX.XXX's password: )
. 2007-10-22 13:11:48.027 Using stored password.
! 2007-10-22 13:11:48.047 Authentification avec le mot de passe pr-entr.
. 2007-10-22 13:11:48.068 Sent password
. 2007-10-22 13:11:48.088 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:48.108 Looking for incoming data
. 2007-10-22 13:11:48.148 Select result is 1
. 2007-10-22 13:11:48.168 Access granted
. 2007-10-22 13:11:48.188 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:48.208 Looking for incoming data
. 2007-10-22 13:11:48.228 Select result is 1
. 2007-10-22 13:11:48.248 Opened channel for session
. 2007-10-22 13:11:48.268 Waiting for the server to continue with the initialisation
. 2007-10-22 13:11:48.288 Looking for incoming data
. 2007-10-22 13:11:48.318 Select result is 1
. 2007-10-22 13:11:48.328 Started a shell/command
. 2007-10-22 13:11:48.348 --------------------------------------------------------------
. 2007-10-22 13:11:48.368 Using SFTP protocol.
. 2007-10-22 13:11:48.398 Doing startup conversation with host.
> 2007-10-22 13:11:48.428 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2007-10-22 13:11:48.448 01,00,00,00,05,
. 2007-10-22 13:11:48.468 Sent 9 bytes
. 2007-10-22 13:11:48.498 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:11:48.518 Waiting for another 4 bytes
. 2007-10-22 13:11:48.548 Looking for incoming data
. 2007-10-22 13:11:48.568 Select result is 1
. 2007-10-22 13:11:48.598 Received 4 bytes
. 2007-10-22 13:11:48.628 Received 77 bytes
< 2007-10-22 13:11:48.648 Type: SSH_FXP_VERSION, Size: 77, Number: -1
< 2007-10-22 13:11:48.678
02,00,00,00,05,00,00,00,07,6E,65,77,6C,69,6E,65,00,00,00,01,0A,00,00,00,09,
73,75,70,70,6F,72,74,65,64,00,00,00,27,8F,FF,FF,FF,80,00,03,FF,00,00,00,7F,
00,00,01,F8,00,01,00,00,00,00,00,0F,73,70,61,63,65,2D,61,76,61,69,6C,61,62,
< 2007-10-22 13:11:48.678 6C,65,
. 2007-10-22 13:11:48.789 SFTP version 5 negotiated.
. 2007-10-22 13:11:48.839 Server requests EOL sequence 0x0A.
. 2007-10-22 13:11:48.869 Server support information:
. 2007-10-22 13:11:48.869   Attribute mask: 8FFFFFFF, Attribute bits: 800003FF, Open
flags: 7F
. 2007-10-22 13:11:48.869   Access mask: 1F8, Open block masks: 0, Block masks: 0, Max
read size: 65536
. 2007-10-22 13:11:48.929   Attribute extensions (0)
. 2007-10-22 13:11:48.959   Extensions (1)
. 2007-10-22 13:11:48.989     space-available
. 2007-10-22 13:11:49.019 We will use UTF-8 strings when appropriate
. 2007-10-22 13:11:49.059 Limiting packet size to OpenSSH limit of 262148 bytes
. 2007-10-22 13:11:49.089 Getting current directory name.
. 2007-10-22 13:11:49.119 Getting real path for '.'
> 2007-10-22 13:11:49.159 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2007-10-22 13:11:49.189 10,00,00,00,10,00,00,00,01,2E,
. 2007-10-22 13:11:49.219 Sent 14 bytes
. 2007-10-22 13:11:49.259 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:11:49.299 Waiting for another 4 bytes
. 2007-10-22 13:11:49.329 Looking for incoming data
. 2007-10-22 13:11:49.369 Select result is 1
. 2007-10-22 13:11:49.409 Received 4 bytes
. 2007-10-22 13:11:49.450 Received 19 bytes
< 2007-10-22 13:11:49.490 Type: SSH_FXP_NAME, Size: 19, Number: 16
< 2007-10-22 13:11:49.530 68,00,00,00,10,00,00,00,01,00,00,00,01,2F,00,00,00,00,00,
. 2007-10-22 13:11:49.570 Real path is '/'
. 2007-10-22 13:11:49.600 Listing directory "/".
> 2007-10-22 13:11:49.640 Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
> 2007-10-22 13:11:49.680 0B,00,00,01,0B,00,00,00,01,2F,
. 2007-10-22 13:11:49.720 Sent 14 bytes
. 2007-10-22 13:11:49.760 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:11:49.800 Waiting for another 4 bytes
. 2007-10-22 13:11:49.830 Looking for incoming data
. 2007-10-22 13:11:49.870 Select result is 1
. 2007-10-22 13:11:49.910 Received 4 bytes
. 2007-10-22 13:11:49.960 Received 10 bytes
< 2007-10-22 13:11:49.990 Type: SSH_FXP_HANDLE, Size: 10, Number: 267
< 2007-10-22 13:11:50.030 66,00,00,01,0B,00,00,00,01,30,
> 2007-10-22 13:11:50.070 Type: SSH_FXP_READDIR, Size: 10, Number: 524
> 2007-10-22 13:11:50.110 0C,00,00,02,0C,00,00,00,01,30,
. 2007-10-22 13:11:50.141 Sent 14 bytes
. 2007-10-22 13:11:50.191 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:11:50.231 Waiting for another 4 bytes
. 2007-10-22 13:11:50.281 Looking for incoming data
. 2007-10-22 13:11:50.321 Select result is 1
. 2007-10-22 13:11:50.361 Received 4 bytes
. 2007-10-22 13:11:50.401 Received 477 bytes
< 2007-10-22 13:11:50.451 Type: SSH_FXP_NAME, Size: 477, Number: 524
< 2007-10-22 13:11:50.501
68,00,00,02,0C,00,00,00,06,00,00,00,01,2E,00,00,02,BD,02,00,00,00,00,00,00,
02,00,00,00,00,07,74,65,73,74,73,63,70,00,00,00,09,73,66,74,70,75,73,65,72,
73,00,00,41,ED,00,00,00,00,47,1C,8C,0A,00,00,00,00,47,1C,72,57,00,00,00,00,
44,9A,BA,FF,00,00,00,04,00,00,00,02,2E,2E,00,00,02,BD,02,00,00,00,00,00,00,
44,9A,BA,FF,00,00,00,04,00,00,00,06,2E,63,73,68,72,63,00,00,02,BD,01,00,00,
00,00,00,00,03,08,00,00,00,07,74,65,73,74,73,63,70,00,00,00,09,73,66,74,70,
75,73,65,72,73,00,00,81,A4,00,00,00,00,47,0A,3A,F5,00,00,00,00,47,1C,72,57,
00,00,00,00,43,23,4C,F2,00,00,00,04,00,00,00,06,2E,6C,6F,67,69,6E,00,00,02,
BD,01,00,00,00,00,00,00,01,3D,00,00,00,07,74,65,73,74,73,63,70,00,00,00,09,
73,66,74,70,75,73,65,72,73,00,00,81,A4,00,00,00,00,47,0A,3A,F5,00,00,00,00,
47,1C,72,57,00,00,00,00,43,23,4C,F2,00,00,00,04,00,00,00,07,2E,6D,61,69,6C,
72,63,00,00,02,BD,01,00,00,00,00,00,00,00,69,00,00,00,07,74,65,73,74,73,63,
70,00,00,00,09,73,66,74,70,75,73,65,72,73,00,00,81,A4,00,00,00,00,47,0A,3A,
F5,00,00,00,00,47,1C,72,57,00,00,00,00,43,23,4C,F2,00,00,00,04,00,00,00,08,
2E,70,72,6F,66,69,6C,65,00,00,02,BD,01,00,00,00,00,00,00,00,DA,00,00,00,07,
74,65,73,74,73,63,70,00,00,00,09,73,66,74,70,75,73,65,72,73,00,00,81,A4,00,
00,00,00,47,0A,3A,F5,00,00,00,00,47,1C,72,57,00,00,00,00,43,23,4C,F2,00,00,
< 2007-10-22 13:11:50.501 00,04,
> 2007-10-22 13:11:50.932 Type: SSH_FXP_READDIR, Size: 10, Number: 780
> 2007-10-22 13:11:50.982 0C,00,00,03,0C,00,00,00,01,30,
. 2007-10-22 13:11:51.032 Sent 14 bytes
. 2007-10-22 13:11:51.092 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:11:51.142 Waiting for another 4 bytes
. 2007-10-22 13:11:51.192 Looking for incoming data
. 2007-10-22 13:11:51.242 Select result is 1
. 2007-10-22 13:11:51.312 Received 4 bytes
. 2007-10-22 13:11:51.372 Received 30 bytes
< 2007-10-22 13:11:51.432 Type: SSH_FXP_STATUS, Size: 30, Number: 780
< 2007-10-22 13:11:51.502
65,00,00,03,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2007-10-22 13:11:51.502 00,00,02,65,6E,
< 2007-10-22 13:11:51.583 Status/error code: 1
> 2007-10-22 13:11:51.633 Type: SSH_FXP_CLOSE, Size: 10, Number: 1028
> 2007-10-22 13:11:51.683 04,00,00,04,04,00,00,00,01,30,
. 2007-10-22 13:11:51.733 Sent 14 bytes
. 2007-10-22 13:11:51.783 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:11:51.833 Startup conversation with host finished.
. 2007-10-22 13:11:52.945 Session upkeep
. 2007-10-22 13:11:52.995 Select result is 1
. 2007-10-22 13:11:53.055 Detected incoming data while idle
. 2007-10-22 13:11:53.535 Session upkeep
. 2007-10-22 13:11:53.595 Select result is 0
. 2007-10-22 13:12:05.733 Copying 1 files/directories to remote directory "/"
. 2007-10-22 13:12:05.793   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs:
N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2007-10-22 13:12:05.793   TM: M; ClAr: No; ExclM(No):
. 2007-10-22 13:12:05.793   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h;
*.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-10-22 13:12:05.893 File: "C:\Documents and Settings\Administrator\My
Documents\desktop.ini"
. 2007-10-22 13:12:05.973 Copying "C:\Documents and Settings\Administrator\My
Documents\desktop.ini" to remote directory started.
. 2007-10-22 13:12:06.033 Ascii transfer mode selected.
. 2007-10-22 13:12:06.093 Opening remote file.
> 2007-10-22 13:12:06.184 Type: SSH_FXP_OPEN, Size: 42, Number: 1283
> 2007-10-22 13:12:06.254
03,00,00,05,03,00,00,00,0C,2F,64,65,73,6B,74,6F,70,2E,69,6E,69,00,00,00,06,
> 2007-10-22 13:12:06.254 00,00,00,20,00,00,00,01,01,00,00,00,00,00,00,00,54,
. 2007-10-22 13:12:06.324 Sent 46 bytes
. 2007-10-22 13:12:06.384 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:06.454 Received 4 bytes
. 2007-10-22 13:12:06.504 Received 26 bytes
< 2007-10-22 13:12:06.574 Type: SSH_FXP_STATUS, Size: 26, Number: 1028
< 2007-10-22 13:12:06.634
65,00,00,04,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,02,65,
< 2007-10-22 13:12:06.634 6E,
. 2007-10-22 13:12:06.714 Discarding reserved response
. 2007-10-22 13:12:06.774 Waiting for another 4 bytes
. 2007-10-22 13:12:06.835 Looking for incoming data
. 2007-10-22 13:12:06.895 Select result is 1
. 2007-10-22 13:12:06.945 Received 4 bytes
. 2007-10-22 13:12:07.005 Received 31 bytes
< 2007-10-22 13:12:07.065 Type: SSH_FXP_STATUS, Size: 31, Number: 1283
< 2007-10-22 13:12:07.135
65,00,00,05,03,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2007-10-22 13:12:07.135 00,00,00,02,65,6E,
< 2007-10-22 13:12:07.215 Status/error code: 2, Message: 1283, Server: No such file,
Language: en
> 2007-10-22 13:12:07.275 Type: SSH_FXP_LSTAT, Size: 25, Number: 1543
> 2007-10-22 13:12:07.335
07,00,00,06,07,00,00,00,0C,2F,64,65,73,6B,74,6F,70,2E,69,6E,69,00,00,00,AD,
. 2007-10-22 13:12:07.395 Sent 29 bytes
. 2007-10-22 13:12:07.455 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:07.515 Waiting for another 4 bytes
. 2007-10-22 13:12:07.586 Looking for incoming data
. 2007-10-22 13:12:07.646 Select result is 1
. 2007-10-22 13:12:07.716 Received 4 bytes
. 2007-10-22 13:12:07.776 Received 31 bytes
< 2007-10-22 13:12:07.836 Type: SSH_FXP_STATUS, Size: 31, Number: 1543
< 2007-10-22 13:12:07.906
65,00,00,06,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2007-10-22 13:12:07.906 00,00,00,02,65,6E,
< 2007-10-22 13:12:07.986 Status/error code: 2, Message: 1543, Server: No such file,
Language: en
* 2007-10-22 13:12:08.076 (ETerminal) Fichier ou rpertoire inexistant
* 2007-10-22 13:12:08.076 Code de l'erreur : 2
* 2007-10-22 13:12:08.076 Message d'erreur du serveur (en) : No such file
* 2007-10-22 13:12:08.076 Code demand : 3
. 2007-10-22 13:12:08.216 Asking user:
. 2007-10-22 13:12:08.216 Impossible de crer le fichier distant '/desktop.ini'.
("Fichier ou rpertoire inexistant
. 2007-10-22 13:12:08.216 Code de l'erreur : 2
. 2007-10-22 13:12:08.216 Message d'erreur du serveur (en) : No such file
. 2007-10-22 13:12:08.216 Code demand : 3")
> 2007-10-22 13:12:17.209 Type: SSH_FXP_OPEN, Size: 42, Number: 1795
> 2007-10-22 13:12:17.280
03,00,00,07,03,00,00,00,0C,2F,64,65,73,6B,74,6F,70,2E,69,6E,69,00,00,00,06,
> 2007-10-22 13:12:17.280 00,00,00,20,00,00,00,01,01,00,00,00,00,00,00,00,54,
. 2007-10-22 13:12:17.370 Sent 46 bytes
. 2007-10-22 13:12:17.440 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:17.510 Waiting for another 4 bytes
. 2007-10-22 13:12:17.570 Looking for incoming data
. 2007-10-22 13:12:17.640 Select result is 1
. 2007-10-22 13:12:17.710 Received 4 bytes
. 2007-10-22 13:12:17.780 Received 31 bytes
< 2007-10-22 13:12:17.850 Type: SSH_FXP_STATUS, Size: 31, Number: 1795
< 2007-10-22 13:12:17.920
65,00,00,07,03,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2007-10-22 13:12:17.920 00,00,00,02,65,6E,
< 2007-10-22 13:12:18.011 Status/error code: 2, Message: 1795, Server: No such file,
Language: en
> 2007-10-22 13:12:18.091 Type: SSH_FXP_LSTAT, Size: 25, Number: 2055
> 2007-10-22 13:12:18.161
07,00,00,08,07,00,00,00,0C,2F,64,65,73,6B,74,6F,70,2E,69,6E,69,00,00,00,AD,
. 2007-10-22 13:12:18.241 Sent 29 bytes
. 2007-10-22 13:12:18.331 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:18.421 Waiting for another 4 bytes
. 2007-10-22 13:12:18.511 Looking for incoming data
. 2007-10-22 13:12:18.581 Select result is 1
. 2007-10-22 13:12:18.672 Received 4 bytes
. 2007-10-22 13:12:18.752 Received 31 bytes
< 2007-10-22 13:12:18.842 Type: SSH_FXP_STATUS, Size: 31, Number: 2055
< 2007-10-22 13:12:18.922
65,00,00,08,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2007-10-22 13:12:18.922 00,00,00,02,65,6E,
< 2007-10-22 13:12:19.022 Status/error code: 2, Message: 2055, Server: No such file,
Language: en
* 2007-10-22 13:12:19.102 (ETerminal) Fichier ou rpertoire inexistant
* 2007-10-22 13:12:19.102 Code de l'erreur : 2
* 2007-10-22 13:12:19.102 Message d'erreur du serveur (en) : No such file
* 2007-10-22 13:12:19.102 Code demand : 3
. 2007-10-22 13:12:19.272 Asking user:
. 2007-10-22 13:12:19.272 Impossible de crer le fichier distant '/desktop.ini'.
. 2007-10-22 13:12:19.272 Code de l'erreur : 2
. 2007-10-22 13:12:19.272 Message d'erreur du serveur (en) : No such file
. 2007-10-22 13:12:19.272 Code demand : 3")
* 2007-10-22 13:12:23.368 (EScpSkipFile) Impossible de crer le fichier distant
'/desktop.ini'.
* 2007-10-22 13:12:23.368 Fichier ou rpertoire inexistant
* 2007-10-22 13:12:23.368 Code de l'erreur : 2
* 2007-10-22 13:12:23.368 Message d'erreur du serveur (en) : No such file
* 2007-10-22 13:12:23.368 Code demand : 3
. 2007-10-22 13:12:23.559 Listing directory "/".
> 2007-10-22 13:12:23.629 Type: SSH_FXP_OPENDIR, Size: 10, Number: 2315
> 2007-10-22 13:12:23.709 0B,00,00,09,0B,00,00,00,01,2F,
. 2007-10-22 13:12:23.789 Sent 14 bytes
. 2007-10-22 13:12:23.869 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:23.949 Waiting for another 4 bytes
. 2007-10-22 13:12:24.029 Looking for incoming data
. 2007-10-22 13:12:24.119 Select result is 1
. 2007-10-22 13:12:24.199 Received 4 bytes
. 2007-10-22 13:12:24.280 Received 10 bytes
< 2007-10-22 13:12:24.360 Type: SSH_FXP_HANDLE, Size: 10, Number: 2315
< 2007-10-22 13:12:24.440 66,00,00,09,0B,00,00,00,01,30,
> 2007-10-22 13:12:24.530 Type: SSH_FXP_READDIR, Size: 10, Number: 2572
> 2007-10-22 13:12:24.610 0C,00,00,0A,0C,00,00,00,01,30,
. 2007-10-22 13:12:24.700 Sent 14 bytes
. 2007-10-22 13:12:24.790 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:24.870 Waiting for another 4 bytes
. 2007-10-22 13:12:24.961 Looking for incoming data
. 2007-10-22 13:12:25.041 Select result is 1
. 2007-10-22 13:12:25.121 Received 4 bytes
. 2007-10-22 13:12:25.211 Received 477 bytes
< 2007-10-22 13:12:25.291 Type: SSH_FXP_NAME, Size: 477, Number: 2572
< 2007-10-22 13:12:25.381
68,00,00,0A,0C,00,00,00,06,00,00,00,01,2E,00,00,02,BD,02,00,00,00,00,00,00,
73,00,00,41,ED,00,00,00,00,47,1C,8C,2D,00,00,00,00,47,1C,72,57,00,00,00,00,
< 2007-10-22 13:12:25.381 00,04,
> 2007-10-22 13:12:26.112 Type: SSH_FXP_READDIR, Size: 10, Number: 2828
> 2007-10-22 13:12:26.212 0C,00,00,0B,0C,00,00,00,01,30,
. 2007-10-22 13:12:26.313 Sent 14 bytes
. 2007-10-22 13:12:26.423 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:26.523 Waiting for another 4 bytes
. 2007-10-22 13:12:26.613 Looking for incoming data
. 2007-10-22 13:12:26.723 Select result is 1
. 2007-10-22 13:12:26.823 Received 4 bytes
. 2007-10-22 13:12:26.933 Received 30 bytes
< 2007-10-22 13:12:27.024 Type: SSH_FXP_STATUS, Size: 30, Number: 2828
< 2007-10-22 13:12:27.124
65,00,00,0B,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2007-10-22 13:12:27.124 00,00,02,65,6E,
< 2007-10-22 13:12:27.274 Status/error code: 1
> 2007-10-22 13:12:27.414 Type: SSH_FXP_CLOSE, Size: 10, Number: 3076
> 2007-10-22 13:12:27.534 04,00,00,0C,04,00,00,00,01,30,
. 2007-10-22 13:12:27.644 Sent 14 bytes
. 2007-10-22 13:12:27.805 There are 0 bytes remaining in the send buffer
. 2007-10-22 13:12:34.454 Select result is 1
. 2007-10-22 13:12:34.624 Detected incoming data while idle
. 2007-10-22 13:12:34.785 Session upkeep
. 2007-10-22 13:12:34.935 Select result is 0
Best Regards.
If you force binary transfer mode, would an upload succeed?
Camember
Sorry i'don't have time to do some beta testing, reporting a bug of your software is the best i can do for now Wink
I hope you'll be able to solve this probleme yourself since you have all the information to reproduce the bug.
Best Regards.
