Topic "Copy a file from a Windows command line"
brianpaul
I would like to copy a file from a Windows machine to a Linux machine(10.0.0.5). I thought maybe this would be a way I could do it...
winscp.com root:password@10.0.0.15 /synchronize d:/esxupdates/updates /home/scripts/updates
I also tried this...
winscp.com root:password@10.0.0.15 /synchronize d:/esxupdates/updates /home/scripts/updates /defaults
If /upload would work for my purpose, then that would be even better. I can copy the file by opening up a connection with the Linux server and then entering in the commands, but I would like one command-line statement to do this so I can put it into a VB program.
Thanks!
My friend Sebastian says that you can't do that on the command line.
If you want to automate the transfer, use scripting functionality:
winscp.com root:password@10.0.0.15 /command "put d:/esxupdates/updates /home/scripts/updates/"
brianpaul
That works very well, but it prompts me if I want to overwrite the file. Is there a switch that can be used that would allow the command to overwrite without prompting? Also, is there a switch or someway to have it close the session when the command is completed?
Please read documentation.
For automation please read FAQ.
guest
I tried to use winscp.com in command line, it showed the following error msg: -
'winscp.com' is not recognized as an internal or external command, operable program or batch
You have to run the command from folder, where winscp.com is located. Or ensure that winscp.com is in search path.
Peyotito
I have probs with root:password@10.0.0.15
How can I use special characters like " SPACE / ! " or else?
Greets
P.
Peyotito
I mean in Username and/or password.
i.e. if I use a / in my password it cuts it off
Please read documentation:
http://winscp.net/eng/docs/session_url
RakeshRaushan
Hi,I want to transfer files from my windows folder to unix server(using putty). Currently I am using WINSCP GUI but i want to use commands instead of using GUI. Please suggest if any way is there.
Start here:
http://winscp.net/eng/docs/guide_automation
Or have WinSCP generate the script for you:
http://winscp.net/eng/docs/ui_generateurl
(available in the latest beta version only)
