Topic "WinSCP4.0.4 - Bug in FTP"
Autourdupc
With WinSCP 4.0.4, using graphical interface, under Windows XP SP2 french.
When transferring files, after each end of transfer, the transfer starts again and again and again...
On the destination folder, once the file is good, it is erased and a new file is created, until the tranfer completes... This is in an infinite loop !
Best regards
Laurent (from France)
Can you post a log file showing this? How do you transfer a file?
autourdupc
Dear,
Here is a log file with more than 2 loops for the same file...
Hope this can help.
Note that I use 4.0.5 (build 354)
BR,
laurent.
. 2007-11-02 16:59:48.806 --------------------------------------------------------------------------
. 2007-11-02 16:59:48.806 WinSCP Version 4.0.5 (Build 354) (OS 5.1.2600 Service Pack 2)
. 2007-11-02 16:59:48.806 Login time: vendredi 2 novembre 2007 16:59:48
. 2007-11-02 16:59:48.806 Session name: FTP Berthelet NS26380
. 2007-11-02 16:59:48.806 Host name: 91.121.72.16 (Port: 21)
. 2007-11-02 16:59:48.822 User name: isa (Password: Yes, Key file: No)
. 2007-11-02 16:59:48.822 Tunnel: No
. 2007-11-02 16:59:48.822 Transfer Protocol: FTP
. 2007-11-02 16:59:48.822 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2007-11-02 16:59:48.822 Proxy: none
. 2007-11-02 16:59:48.822 FTP: Passive: No
. 2007-11-02 16:59:48.822 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-11-02 16:59:48.822 Cache directory changes: Yes, Permanent: Yes
. 2007-11-02 16:59:48.822 DST mode: 1
. 2007-11-02 16:59:48.822 --------------------------------------------------------------------------
. 2007-11-02 16:59:48.837 Connexion 91.121.72.16...
. 2007-11-02 16:59:48.837 FtpControlSocket.cpp(1056): OnConnect(0) OpMode=1 OpState=-1 caller=0x01d64c04
. 2007-11-02 16:59:48.837 Connect 91.121.72.16. En attente du message de bienvenue...
. 2007-11-02 17:00:03.820 Expiration du dlai dtecte !
. 2007-11-02 17:00:03.820 FtpControlSocket.cpp(1199): DoClose(0) OpMode=1 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:03.820 FtpControlSocket.cpp(4184): ResetOperation(4100) OpMode=1 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:03.820 La connexion a choue.
. 2007-11-02 17:00:03.820 Got reply 1004 to the command 1
* 2007-11-02 17:00:03.820 (ESshFatal) La connexion a choue.
* 2007-11-02 17:00:03.820 Expiration du dlai dtecte !
* 2007-11-02 17:00:03.820 La connexion a choue.
. 2007-11-02 17:00:06.195 Connexion 91.121.72.16...
. 2007-11-02 17:00:06.195 FtpControlSocket.cpp(1056): OnConnect(0) OpMode=1 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:06.195 Connect 91.121.72.16. En attente du message de bienvenue...
. 2007-11-02 17:00:06.273 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:00:06.273 220 Microsoft FTP Service
> 2007-11-02 17:00:06.273 USER isa
. 2007-11-02 17:00:06.320 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=0 caller=0x01d64c04
< 2007-11-02 17:00:06.320 331 Password required for isa.
> 2007-11-02 17:00:06.320 PASS ****
. 2007-11-02 17:00:06.367 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=3 caller=0x01d64c04
< 2007-11-02 17:00:06.367 230 User isa logged in.
> 2007-11-02 17:00:06.367 SYST
. 2007-11-02 17:00:06.413 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-14 caller=0x01d64c04
< 2007-11-02 17:00:06.413 215 Windows_NT
> 2007-11-02 17:00:06.413 FEAT
. 2007-11-02 17:00:06.445 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01d64c04
< 2007-11-02 17:00:06.445 211-FEAT
. 2007-11-02 17:00:06.679 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01d64c04
< 2007-11-02 17:00:06.679 SIZE
< 2007-11-02 17:00:06.679 MDTM
< 2007-11-02 17:00:06.679 211 END
. 2007-11-02 17:00:06.679 Connect
. 2007-11-02 17:00:06.679 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=1 OpState=-13 caller=0x01d64c04
. 2007-11-02 17:00:06.679 Got reply 1 to the command 1
. 2007-11-02 17:00:06.679 Doing startup conversation with host.
. 2007-11-02 17:00:06.679 FtpControlSocket.cpp(1269): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01d64c04
> 2007-11-02 17:00:06.679 PWD
. 2007-11-02 17:00:07.632 FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:00:07.632 257 "/" is current directory.
. 2007-11-02 17:00:07.632 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:07.632 Got reply 1 to the command 16
. 2007-11-02 17:00:07.632 Getting current directory name.
. 2007-11-02 17:00:07.632 FtpControlSocket.cpp(1276): List(FALSE,0,"/","",1) OpMode=0 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:07.632 Listage du rpertoire en cours...
> 2007-11-02 17:00:07.632 TYPE A
. 2007-11-02 17:00:07.679 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=8 caller=0x01d64c04
< 2007-11-02 17:00:07.679 200 Type set to A.
. 2007-11-02 17:00:07.679 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=8 caller=0x01d64c04
> 2007-11-02 17:00:07.679 PORT 192,168,200,5,16,116
. 2007-11-02 17:00:07.726 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=7 caller=0x01d64c04
< 2007-11-02 17:00:07.726 200 PORT command successful.
. 2007-11-02 17:00:07.726 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=7 caller=0x01d64c04
. 2007-11-02 17:00:07.726 TransferSocket.cpp(597): SetActive() caller=0x01d50488
> 2007-11-02 17:00:07.726 LIST -a
. 2007-11-02 17:00:07.773 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=9 caller=0x01d64c04
< 2007-11-02 17:00:07.773 150 Opening ASCII mode data connection for /bin/ls.
. 2007-11-02 17:00:07.773 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=9 caller=0x01d64c04
. 2007-11-02 17:00:07.804 TransferSocket.cpp(418): OnAccept(0) caller=0x01d50488
. 2007-11-02 17:00:07.804 TransferSocket.cpp(557): OnClose(0) caller=0x01d50488
. 2007-11-02 17:00:07.804 TransferSocket.cpp(1179): Close() caller=0x01d50488
. 2007-11-02 17:00:07.804 FtpControlSocket.cpp(2070): TransferEnd(4) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:07.804 FtpControlSocket.cpp(1276): List(TRUE,0,"","",0) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:07.804 10-31-07 06:14PM <DIR> __A_lire
. 2007-11-02 17:00:07.804 11-02-07 04:49PM <DIR> Brochure
. 2007-11-02 17:00:07.804 TransferSocket.cpp(108): ~CTransferSocket() caller=0x01d50488
. 2007-11-02 17:00:07.976 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=10 caller=0x01d64c04
< 2007-11-02 17:00:07.976 226 Transfer complete.
. 2007-11-02 17:00:07.976 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:07.976 Listage du rpertoire russi
. 2007-11-02 17:00:07.976 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:07.976 Got reply 1 to the command 2
. 2007-11-02 17:00:07.976 Startup conversation with host finished.
. 2007-11-02 17:00:08.601 Session upkeep
. 2007-11-02 17:00:09.101 Session upkeep
. 2007-11-02 17:00:09.601 Session upkeep
. 2007-11-02 17:00:10.101 Session upkeep
. 2007-11-02 17:00:10.600 Session upkeep
. 2007-11-02 17:00:11.069 Cached directory change via "Brochure" to "/Brochure".
. 2007-11-02 17:00:11.069 Getting current directory name.
. 2007-11-02 17:00:11.069 FtpControlSocket.cpp(1276): List(FALSE,0,"/Brochure/","",1) OpMode=0 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:11.069 Listage du rpertoire en cours...
> 2007-11-02 17:00:11.069 CWD /Brochure/
. 2007-11-02 17:00:11.100 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=1 caller=0x01d64c04
< 2007-11-02 17:00:11.100 250 CWD command successful.
. 2007-11-02 17:00:11.100 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=1 caller=0x01d64c04
> 2007-11-02 17:00:11.100 PWD
. 2007-11-02 17:00:11.147 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=2 caller=0x01d64c04
< 2007-11-02 17:00:11.147 257 "/Brochure" is current directory.
. 2007-11-02 17:00:11.147 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=2 caller=0x01d64c04
> 2007-11-02 17:00:11.147 TYPE A
. 2007-11-02 17:00:11.194 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=8 caller=0x01d64c04
< 2007-11-02 17:00:11.194 200 Type set to A.
. 2007-11-02 17:00:11.194 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=8 caller=0x01d64c04
> 2007-11-02 17:00:11.194 PORT 192,168,200,5,16,118
. 2007-11-02 17:00:11.241 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=7 caller=0x01d64c04
< 2007-11-02 17:00:11.241 200 PORT command successful.
. 2007-11-02 17:00:11.241 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=7 caller=0x01d64c04
. 2007-11-02 17:00:11.241 TransferSocket.cpp(597): SetActive() caller=0x01da6864
> 2007-11-02 17:00:11.241 LIST -a
. 2007-11-02 17:00:11.272 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=9 caller=0x01d64c04
< 2007-11-02 17:00:11.272 150 Opening ASCII mode data connection for /bin/ls.
. 2007-11-02 17:00:11.272 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=9 caller=0x01d64c04
. 2007-11-02 17:00:11.319 TransferSocket.cpp(418): OnAccept(0) caller=0x01da6864
. 2007-11-02 17:00:11.319 TransferSocket.cpp(557): OnClose(0) caller=0x01da6864
. 2007-11-02 17:00:11.319 TransferSocket.cpp(1179): Close() caller=0x01da6864
. 2007-11-02 17:00:11.319 FtpControlSocket.cpp(2070): TransferEnd(4) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:11.319 FtpControlSocket.cpp(1276): List(TRUE,0,"","",0) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:11.319 10-24-07 03:31PM <DIR> AEROSUN
. 2007-11-02 17:00:11.319 10-22-07 08:08PM <DIR> Photos Aix villa Marlioz
. 2007-11-02 17:00:11.319 10-25-07 08:52PM <DIR> Photos Corfou
. 2007-11-02 17:00:11.319 10-25-07 09:11PM <DIR> Photos Crete Santa Marina
. 2007-11-02 17:00:11.319 10-22-07 08:23PM <DIR> Photos Divonne Thalasso
. 2007-11-02 17:00:11.319 10-22-07 08:21PM <DIR> Photos Dolce Fregate
. 2007-11-02 17:00:11.319 10-25-07 09:14PM <DIR> Photos Isis Djerba
. 2007-11-02 17:00:11.319 10-25-07 09:25PM <DIR> Photos Istanbul
. 2007-11-02 17:00:11.319 10-25-07 09:21PM <DIR> Photos Maroc Fashion
. 2007-11-02 17:00:11.319 10-25-07 09:38PM <DIR> Photos New York
. 2007-11-02 17:00:11.319 10-25-07 07:59PM <DIR> Photos Russie
. 2007-11-02 17:00:11.319 10-25-07 09:37PM <DIR> Photos Senegal Neptune
. 2007-11-02 17:00:11.319 10-25-07 09:09PM <DIR> Photos Tunisie Les Lilas
. 2007-11-02 17:00:11.319 10-25-07 09:06PM <DIR> Photos Tunisie Vincci Lella Baya
. 2007-11-02 17:00:11.319 10-22-07 08:02PM <DIR> Republique Dominicaine
. 2007-11-02 17:00:11.319 11-02-07 09:09AM 71 totoc.txt
. 2007-11-02 17:00:11.319 11-02-07 08:12AM <DIR> Tourinter
. 2007-11-02 17:00:11.319 11-02-07 04:49PM <DIR> Un test
. 2007-11-02 17:00:11.319 TransferSocket.cpp(108): ~CTransferSocket() caller=0x01da6864
. 2007-11-02 17:00:11.507 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=10 caller=0x01d64c04
< 2007-11-02 17:00:11.507 226 Transfer complete.
. 2007-11-02 17:00:11.507 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:11.507 Listage du rpertoire russi
. 2007-11-02 17:00:11.507 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:11.507 Got reply 1 to the command 2
. 2007-11-02 17:00:11.522 Session upkeep
. 2007-11-02 17:00:11.600 Session upkeep
. 2007-11-02 17:00:12.100 Session upkeep
. 2007-11-02 17:00:12.600 Session upkeep
. 2007-11-02 17:00:13.100 Session upkeep
. 2007-11-02 17:00:13.600 Session upkeep
. 2007-11-02 17:00:13.600 Changing directory to "Un test".
. 2007-11-02 17:00:13.600 FtpControlSocket.cpp(1269): FtpCommand(CWD Un test) OpMode=0 OpState=-1 caller=0x01d64c04
> 2007-11-02 17:00:13.600 CWD Un test
. 2007-11-02 17:00:13.647 FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:00:13.647 250 CWD command successful.
. 2007-11-02 17:00:13.647 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:13.647 Got reply 1 to the command 16
. 2007-11-02 17:00:13.647 Getting current directory name.
. 2007-11-02 17:00:13.647 FtpControlSocket.cpp(1269): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01d64c04
> 2007-11-02 17:00:13.647 PWD
. 2007-11-02 17:00:13.694 FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:00:13.694 257 "/Brochure/Un test" is current directory.
. 2007-11-02 17:00:13.694 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:13.694 Got reply 1 to the command 16
. 2007-11-02 17:00:13.694 FtpControlSocket.cpp(1276): List(FALSE,0,"/Brochure/Un test/","",1) OpMode=0 OpState=-1 caller=0x01d64c04
. 2007-11-02 17:00:13.694 Listage du rpertoire en cours...
> 2007-11-02 17:00:13.694 TYPE A
. 2007-11-02 17:00:13.741 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=8 caller=0x01d64c04
< 2007-11-02 17:00:13.741 200 Type set to A.
. 2007-11-02 17:00:13.741 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=8 caller=0x01d64c04
> 2007-11-02 17:00:13.741 PORT 192,168,200,5,16,120
. 2007-11-02 17:00:13.788 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=7 caller=0x01d64c04
< 2007-11-02 17:00:13.788 200 PORT command successful.
. 2007-11-02 17:00:13.788 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=7 caller=0x01d64c04
. 2007-11-02 17:00:13.788 TransferSocket.cpp(597): SetActive() caller=0x01da6d2c
> 2007-11-02 17:00:13.788 LIST -a
. 2007-11-02 17:00:13.819 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=9 caller=0x01d64c04
< 2007-11-02 17:00:13.819 150 Opening ASCII mode data connection for /bin/ls.
. 2007-11-02 17:00:13.819 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=9 caller=0x01d64c04
. 2007-11-02 17:00:13.866 TransferSocket.cpp(418): OnAccept(0) caller=0x01da6d2c
. 2007-11-02 17:00:13.866 TransferSocket.cpp(557): OnClose(0) caller=0x01da6d2c
. 2007-11-02 17:00:13.866 TransferSocket.cpp(1179): Close() caller=0x01da6d2c
. 2007-11-02 17:00:13.866 FtpControlSocket.cpp(2070): TransferEnd(4) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:13.866 FtpControlSocket.cpp(1276): List(TRUE,0,"","",0) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:13.866 11-02-07 04:49PM <DIR> un ne
. 2007-11-02 17:00:13.866 11-02-07 04:49PM <DIR> une tte
. 2007-11-02 17:00:13.866 TransferSocket.cpp(108): ~CTransferSocket() caller=0x01da6d2c
. 2007-11-02 17:00:14.022 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=10 caller=0x01d64c04
< 2007-11-02 17:00:14.022 226 Transfer complete.
. 2007-11-02 17:00:14.022 FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:14.022 Listage du rpertoire russi
. 2007-11-02 17:00:14.022 FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=4 OpState=10 caller=0x01d64c04
. 2007-11-02 17:00:14.022 Got reply 1 to the command 2
. 2007-11-02 17:00:14.100 Session upkeep
. 2007-11-02 17:00:14.600 Session upkeep
. 2007-11-02 17:00:15.100 Session upkeep
. 2007-11-02 17:00:15.319 Cached directory change via ".." to "/Brochure".
. 2007-11-02 17:00:15.319 Getting current directory name.
. 2007-11-02 17:00:15.319 Directory content loaded from cache.
. 2007-11-02 17:00:15.600 Session upkeep
. 2007-11-02 17:00:16.100 Session upkeep
. 2007-11-02 17:00:16.600 Session upkeep
. 2007-11-02 17:00:16.834 Cached directory change via "Un test" to "/Brochure/Un test".
. 2007-11-02 17:00:16.834 Getting current directory name.
. 2007-11-02 17:00:16.850 Directory content loaded from cache.
. 2007-11-02 17:00:17.100 Session upkeep
. 2007-11-02 17:00:17.600 Session upkeep
. 2007-11-02 17:00:18.100 Session upkeep
. 2007-11-02 17:00:18.600 Session upkeep
. 2007-11-02 17:00:19.100 Session upkeep
. 2007-11-02 17:00:19.600 Session upkeep
. 2007-11-02 17:00:20.099 Session upkeep
. 2007-11-02 17:00:20.599 Session upkeep
. 2007-11-02 17:00:21.099 Session upkeep
. 2007-11-02 17:00:21.599 Session upkeep
. 2007-11-02 17:00:22.099 Session upkeep
. 2007-11-02 17:00:22.599 Session upkeep
. 2007-11-02 17:00:23.099 Session upkeep
. 2007-11-02 17:00:23.615 Session upkeep
. 2007-11-02 17:00:24.115 Session upkeep
. 2007-11-02 17:00:24.615 Session upkeep
. 2007-11-02 17:00:25.115 Session upkeep
. 2007-11-02 17:00:25.614 Session upkeep
. 2007-11-02 17:00:26.114 Session upkeep
. 2007-11-02 17:00:26.614 Session upkeep
. 2007-11-02 17:00:27.114 Session upkeep
. 2007-11-02 17:00:27.614 Session upkeep
. 2007-11-02 17:00:28.114 Session upkeep
. 2007-11-02 17:00:28.614 Session upkeep
. 2007-11-02 17:00:29.114 Session upkeep
. 2007-11-02 17:00:29.614 Session upkeep
. 2007-11-02 17:00:30.114 Session upkeep
. 2007-11-02 17:00:30.614 Session upkeep
. 2007-11-02 17:00:31.114 Session upkeep
. 2007-11-02 17:00:31.614 Session upkeep
. 2007-11-02 17:00:32.114 Session upkeep
. 2007-11-02 17:00:32.614 Session upkeep
. 2007-11-02 17:00:33.114 Session upkeep
. 2007-11-02 17:00:33.614 Session upkeep
. 2007-11-02 17:00:34.114 Session upkeep
. 2007-11-02 17:00:34.614 Session upkeep
. 2007-11-02 17:00:35.113 Session upkeep
. 2007-11-02 17:00:35.613 Session upkeep
. 2007-11-02 17:00:36.113 Session upkeep
. 2007-11-02 17:00:36.613 Session upkeep
. 2007-11-02 17:00:37.113 Session upkeep
. 2007-11-02 17:00:37.613 Session upkeep
. 2007-11-02 17:00:38.113 Session upkeep
. 2007-11-02 17:00:38.613 Session upkeep
. 2007-11-02 17:00:39.113 Session upkeep
. 2007-11-02 17:00:39.613 Session upkeep
. 2007-11-02 17:00:40.113 Session upkeep
. 2007-11-02 17:00:40.613 Session upkeep
. 2007-11-02 17:00:41.113 Session upkeep
. 2007-11-02 17:00:41.613 Session upkeep
. 2007-11-02 17:00:42.113 Session upkeep
. 2007-11-02 17:00:42.613 Session upkeep
. 2007-11-02 17:00:43.113 Session upkeep
. 2007-11-02 17:00:43.613 Session upkeep
. 2007-11-02 17:00:44.112 Session upkeep
. 2007-11-02 17:00:44.612 Session upkeep
. 2007-11-02 17:00:45.112 Session upkeep
> 2007-11-02 17:00:45.112 TYPE A
. 2007-11-02 17:00:45.112 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:00:45.112 200 Type set to A.
. 2007-11-02 17:00:45.612 Session upkeep
. 2007-11-02 17:00:46.112 Session upkeep
. 2007-11-02 17:00:46.612 Session upkeep
. 2007-11-02 17:00:47.112 Session upkeep
. 2007-11-02 17:00:47.612 Session upkeep
. 2007-11-02 17:00:48.112 Session upkeep
. 2007-11-02 17:00:48.612 Session upkeep
. 2007-11-02 17:00:49.112 Session upkeep
. 2007-11-02 17:00:49.612 Session upkeep
. 2007-11-02 17:00:50.112 Session upkeep
. 2007-11-02 17:00:50.612 Session upkeep
. 2007-11-02 17:00:51.112 Session upkeep
. 2007-11-02 17:00:51.612 Session upkeep
. 2007-11-02 17:00:52.112 Session upkeep
. 2007-11-02 17:00:52.612 Session upkeep
. 2007-11-02 17:00:52.862 [Background 1] Connexion 91.121.72.16...
. 2007-11-02 17:00:52.862 [Background 1] FtpControlSocket.cpp(1056): OnConnect(0) OpMode=1 OpState=-1 caller=0x01d46658
. 2007-11-02 17:00:52.862 [Background 1] Connect 91.121.72.16. En attente du message de bienvenue...
. 2007-11-02 17:00:52.955 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-1 caller=0x01d46658
< 2007-11-02 17:00:52.955 [Background 1] 220 Microsoft FTP Service
> 2007-11-02 17:00:52.955 [Background 1] USER isa
. 2007-11-02 17:00:52.987 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=0 caller=0x01d46658
< 2007-11-02 17:00:52.987 [Background 1] 331 Password required for isa.
> 2007-11-02 17:00:52.987 [Background 1] PASS ****
. 2007-11-02 17:00:53.033 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=3 caller=0x01d46658
< 2007-11-02 17:00:53.033 [Background 1] 230 User isa logged in.
> 2007-11-02 17:00:53.033 [Background 1] SYST
. 2007-11-02 17:00:53.080 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-14 caller=0x01d46658
< 2007-11-02 17:00:53.080 [Background 1] 215 Windows_NT
> 2007-11-02 17:00:53.080 [Background 1] FEAT
. 2007-11-02 17:00:53.111 Session upkeep
. 2007-11-02 17:00:53.127 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01d46658
< 2007-11-02 17:00:53.127 [Background 1] 211-FEAT
. 2007-11-02 17:00:53.346 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01d46658
< 2007-11-02 17:00:53.346 [Background 1] SIZE
< 2007-11-02 17:00:53.346 [Background 1] MDTM
< 2007-11-02 17:00:53.346 [Background 1] 211 END
. 2007-11-02 17:00:53.346 [Background 1] Connect
. 2007-11-02 17:00:53.346 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=1 OpState=-13 caller=0x01d46658
. 2007-11-02 17:00:53.346 [Background 1] Got reply 1 to the command 1
. 2007-11-02 17:00:53.346 [Background 1] --------------------------------------------------------------------------
. 2007-11-02 17:00:53.346 [Background 1] Using FTP protocol.
. 2007-11-02 17:00:53.346 [Background 1] Doing startup conversation with host.
. 2007-11-02 17:00:53.346 [Background 1] FtpControlSocket.cpp(1269): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01d46658
> 2007-11-02 17:00:53.346 [Background 1] PWD
. 2007-11-02 17:00:53.611 Session upkeep
. 2007-11-02 17:00:54.111 Session upkeep
. 2007-11-02 17:00:54.455 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d46658
< 2007-11-02 17:00:54.455 [Background 1] 257 "/" is current directory.
. 2007-11-02 17:00:54.455 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d46658
. 2007-11-02 17:00:54.455 [Background 1] Got reply 1 to the command 16
. 2007-11-02 17:00:54.455 [Background 1] Changing directory to "/Brochure/Un test".
. 2007-11-02 17:00:54.455 [Background 1] FtpControlSocket.cpp(1269): FtpCommand(CWD /Brochure/Un test) OpMode=0 OpState=-1 caller=0x01d46658
> 2007-11-02 17:00:54.455 [Background 1] CWD /Brochure/Un test
. 2007-11-02 17:00:54.502 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d46658
< 2007-11-02 17:00:54.502 [Background 1] 250 CWD command successful.
. 2007-11-02 17:00:54.502 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d46658
. 2007-11-02 17:00:54.502 [Background 1] Got reply 1 to the command 16
. 2007-11-02 17:00:54.502 [Background 1] Getting current directory name.
. 2007-11-02 17:00:54.502 [Background 1] FtpControlSocket.cpp(1269): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01d46658
> 2007-11-02 17:00:54.502 [Background 1] PWD
. 2007-11-02 17:00:54.549 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d46658
< 2007-11-02 17:00:54.549 [Background 1] 257 "/Brochure/Un test" is current directory.
. 2007-11-02 17:00:54.549 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d46658
. 2007-11-02 17:00:54.549 [Background 1] Got reply 1 to the command 16
. 2007-11-02 17:00:54.549 [Background 1] FtpControlSocket.cpp(1276): List(FALSE,0,"/Brochure/Un test/","",1) OpMode=0 OpState=-1 caller=0x01d46658
. 2007-11-02 17:00:54.549 [Background 1] Listage du rpertoire en cours...
> 2007-11-02 17:00:54.549 [Background 1] TYPE A
. 2007-11-02 17:00:54.580 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=8 caller=0x01d46658
< 2007-11-02 17:00:54.580 [Background 1] 200 Type set to A.
. 2007-11-02 17:00:54.580 [Background 1] FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=8 caller=0x01d46658
> 2007-11-02 17:00:54.580 [Background 1] PORT 192,168,200,5,16,125
. 2007-11-02 17:00:54.611 Session upkeep
. 2007-11-02 17:00:54.627 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=7 caller=0x01d46658
< 2007-11-02 17:00:54.627 [Background 1] 200 PORT command successful.
. 2007-11-02 17:00:54.627 [Background 1] FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=7 caller=0x01d46658
. 2007-11-02 17:00:54.627 [Background 1] TransferSocket.cpp(597): SetActive() caller=0x01db392c
> 2007-11-02 17:00:54.627 [Background 1] LIST -a
. 2007-11-02 17:00:54.674 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=9 caller=0x01d46658
< 2007-11-02 17:00:54.674 [Background 1] 150 Opening ASCII mode data connection for /bin/ls.
. 2007-11-02 17:00:54.674 [Background 1] FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=9 caller=0x01d46658
. 2007-11-02 17:00:54.721 [Background 1] TransferSocket.cpp(418): OnAccept(0) caller=0x01db392c
. 2007-11-02 17:00:54.721 [Background 1] TransferSocket.cpp(557): OnClose(0) caller=0x01db392c
. 2007-11-02 17:00:54.721 [Background 1] TransferSocket.cpp(1179): Close() caller=0x01db392c
. 2007-11-02 17:00:54.721 [Background 1] FtpControlSocket.cpp(2070): TransferEnd(4) OpMode=4 OpState=10 caller=0x01d46658
. 2007-11-02 17:00:54.721 [Background 1] FtpControlSocket.cpp(1276): List(TRUE,0,"","",0) OpMode=4 OpState=10 caller=0x01d46658
. 2007-11-02 17:00:54.721 [Background 1] 11-02-07 04:49PM <DIR> un ne
. 2007-11-02 17:00:54.721 [Background 1] 11-02-07 04:49PM <DIR> une tte
. 2007-11-02 17:00:54.721 [Background 1] TransferSocket.cpp(108): ~CTransferSocket() caller=0x01db392c
. 2007-11-02 17:00:54.846 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=10 caller=0x01d46658
< 2007-11-02 17:00:54.846 [Background 1] 226 Transfer complete.
. 2007-11-02 17:00:54.846 [Background 1] FtpControlSocket.cpp(1276): List(FALSE,0,"","",0) OpMode=4 OpState=10 caller=0x01d46658
. 2007-11-02 17:00:54.846 [Background 1] Listage du rpertoire russi
. 2007-11-02 17:00:54.846 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=4 OpState=10 caller=0x01d46658
. 2007-11-02 17:00:54.846 [Background 1] Got reply 1 to the command 2
. 2007-11-02 17:00:54.846 [Background 1] Startup conversation with host finished.
. 2007-11-02 17:00:54.846 [Background 1] Copying 1 files/directories to remote directory "/Brochure/Un test/"
. 2007-11-02 17:00:54.846 [Background 1] PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (10240000); CalcS: Yes; Mask: *.*
. 2007-11-02 17:00:54.846 [Background 1] TM: M; ClAr: No; ExclM(No):
. 2007-11-02 17:00:54.846 [Background 1] AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-11-02 17:00:54.846 [Background 1] File: "F:\Tourinter\Hotel Carayou\Vues_Aeriennes\Carayou_2_0905.jpg"
. 2007-11-02 17:00:54.877 [Background 1] Copying "F:\Tourinter\Hotel Carayou\Vues_Aeriennes\Carayou_2_0905.jpg" to remote directory started.
. 2007-11-02 17:00:54.877 [Background 1] Binary transfer mode selected.
. 2007-11-02 17:00:54.877 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(31045968, FALSE, 0) OpMode=0 OpState=-1 caller=0x01d46658
. 2007-11-02 17:00:54.877 [Background 1] Dbut de l''envoi de F:\Tourinter\Hotel Carayou\Vues_Aeriennes\Carayou_2_0905.jpg
> 2007-11-02 17:00:54.877 [Background 1] TYPE I
. 2007-11-02 17:00:54.924 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=13 caller=0x01d46658
< 2007-11-02 17:00:54.924 [Background 1] 200 Type set to I.
. 2007-11-02 17:00:54.924 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=13 caller=0x01d46658
> 2007-11-02 17:00:54.924 [Background 1] PORT 192,168,200,5,16,127
. 2007-11-02 17:00:54.971 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=17 caller=0x01d46658
< 2007-11-02 17:00:54.971 [Background 1] 200 PORT command successful.
. 2007-11-02 17:00:54.971 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=17 caller=0x01d46658
. 2007-11-02 17:00:54.971 [Background 1] TransferSocket.cpp(597): SetActive() caller=0x01dc57cc
> 2007-11-02 17:00:54.971 [Background 1] STOR Carayou_2_0905.jpg
. 2007-11-02 17:00:55.002 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=18 caller=0x01d46658
< 2007-11-02 17:00:55.002 [Background 1] 150 Opening BINARY mode data connection for Carayou_2_0905.jpg.
. 2007-11-02 17:00:55.002 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=18 caller=0x01d46658
. 2007-11-02 17:00:55.049 [Background 1] TransferSocket.cpp(418): OnAccept(0) caller=0x01dc57cc
. 2007-11-02 17:00:55.111 Session upkeep
. 2007-11-02 17:00:55.611 Session upkeep
. 2007-11-02 17:00:56.111 Session upkeep
. 2007-11-02 17:00:56.611 Session upkeep
. 2007-11-02 17:00:57.111 Session upkeep
. 2007-11-02 17:00:57.611 Session upkeep
. 2007-11-02 17:00:58.111 Session upkeep
. 2007-11-02 17:00:58.611 Session upkeep
. 2007-11-02 17:00:59.111 Session upkeep
. 2007-11-02 17:00:59.611 Session upkeep
. 2007-11-02 17:01:00.111 Session upkeep
. 2007-11-02 17:01:00.611 Session upkeep
. 2007-11-02 17:01:01.111 Session upkeep
. 2007-11-02 17:01:01.611 Session upkeep
. 2007-11-02 17:01:02.111 Session upkeep
. 2007-11-02 17:01:02.610 Session upkeep
. 2007-11-02 17:01:03.110 Session upkeep
. 2007-11-02 17:01:03.610 Session upkeep
. 2007-11-02 17:01:04.110 Session upkeep
. 2007-11-02 17:01:04.610 Session upkeep
. 2007-11-02 17:01:05.110 Session upkeep
. 2007-11-02 17:01:05.610 Session upkeep
. 2007-11-02 17:01:06.110 Session upkeep
. 2007-11-02 17:01:06.610 Session upkeep
. 2007-11-02 17:01:07.110 Session upkeep
. 2007-11-02 17:01:07.610 Session upkeep
. 2007-11-02 17:01:08.110 Session upkeep
. 2007-11-02 17:01:08.610 Session upkeep
. 2007-11-02 17:01:09.110 Session upkeep
. 2007-11-02 17:01:09.610 Session upkeep
. 2007-11-02 17:01:10.110 Session upkeep
. 2007-11-02 17:01:10.610 Session upkeep
. 2007-11-02 17:01:11.110 Session upkeep
. 2007-11-02 17:01:11.609 Session upkeep
. 2007-11-02 17:01:12.109 Session upkeep
. 2007-11-02 17:01:12.609 Session upkeep
. 2007-11-02 17:01:13.109 Session upkeep
. 2007-11-02 17:01:13.609 Session upkeep
. 2007-11-02 17:01:14.109 Session upkeep
. 2007-11-02 17:01:14.609 Session upkeep
. 2007-11-02 17:01:15.109 Session upkeep
> 2007-11-02 17:01:15.109 TYPE I
. 2007-11-02 17:01:15.109 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:01:15.109 200 Type set to I.
. 2007-11-02 17:01:15.609 Session upkeep
. 2007-11-02 17:01:16.109 Session upkeep
. 2007-11-02 17:01:16.609 Session upkeep
. 2007-11-02 17:01:17.109 Session upkeep
. 2007-11-02 17:01:17.609 Session upkeep
. 2007-11-02 17:01:18.109 Session upkeep
. 2007-11-02 17:01:18.609 Session upkeep
. 2007-11-02 17:01:19.109 Session upkeep
. 2007-11-02 17:01:19.609 Session upkeep
. 2007-11-02 17:01:20.109 Session upkeep
. 2007-11-02 17:01:20.608 Session upkeep
. 2007-11-02 17:01:21.108 Session upkeep
. 2007-11-02 17:01:21.608 Session upkeep
. 2007-11-02 17:01:22.108 Session upkeep
. 2007-11-02 17:01:22.608 Session upkeep
. 2007-11-02 17:01:23.108 Session upkeep
. 2007-11-02 17:01:23.608 Session upkeep
. 2007-11-02 17:01:24.108 Session upkeep
. 2007-11-02 17:01:24.608 Session upkeep
. 2007-11-02 17:01:25.108 Session upkeep
. 2007-11-02 17:01:25.608 Session upkeep
. 2007-11-02 17:01:26.108 Session upkeep
. 2007-11-02 17:01:26.608 Session upkeep
. 2007-11-02 17:01:27.108 Session upkeep
. 2007-11-02 17:01:27.608 Session upkeep
. 2007-11-02 17:01:28.108 Session upkeep
. 2007-11-02 17:01:28.608 Session upkeep
. 2007-11-02 17:01:29.108 Session upkeep
. 2007-11-02 17:01:29.608 Session upkeep
. 2007-11-02 17:01:30.107 Session upkeep
. 2007-11-02 17:01:30.607 Session upkeep
. 2007-11-02 17:01:31.107 Session upkeep
. 2007-11-02 17:01:31.607 Session upkeep
. 2007-11-02 17:01:32.107 Session upkeep
. 2007-11-02 17:01:32.607 Session upkeep
. 2007-11-02 17:01:33.107 Session upkeep
. 2007-11-02 17:01:33.607 Session upkeep
. 2007-11-02 17:01:34.107 Session upkeep
. 2007-11-02 17:01:34.607 Session upkeep
. 2007-11-02 17:01:35.107 Session upkeep
. 2007-11-02 17:01:35.607 Session upkeep
. 2007-11-02 17:01:36.107 Session upkeep
. 2007-11-02 17:01:36.607 Session upkeep
. 2007-11-02 17:01:37.107 Session upkeep
. 2007-11-02 17:01:37.607 Session upkeep
. 2007-11-02 17:01:38.107 Session upkeep
. 2007-11-02 17:01:38.607 Session upkeep
. 2007-11-02 17:01:39.106 Session upkeep
. 2007-11-02 17:01:39.606 Session upkeep
. 2007-11-02 17:01:40.106 Session upkeep
. 2007-11-02 17:01:40.606 Session upkeep
. 2007-11-02 17:01:41.138 Session upkeep
. 2007-11-02 17:01:41.606 Session upkeep
. 2007-11-02 17:01:42.106 Session upkeep
. 2007-11-02 17:01:42.606 Session upkeep
. 2007-11-02 17:01:43.106 Session upkeep
. 2007-11-02 17:01:43.606 Session upkeep
. 2007-11-02 17:01:44.106 Session upkeep
. 2007-11-02 17:01:44.606 Session upkeep
. 2007-11-02 17:01:45.106 Session upkeep
> 2007-11-02 17:01:45.106 PWD
. 2007-11-02 17:01:45.106 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:01:45.106 257 "/Brochure/Un test" is current directory.
. 2007-11-02 17:01:45.606 Session upkeep
. 2007-11-02 17:01:46.106 Session upkeep
. 2007-11-02 17:01:46.606 Session upkeep
. 2007-11-02 17:01:47.106 Session upkeep
. 2007-11-02 17:01:47.606 Session upkeep
. 2007-11-02 17:01:48.106 Session upkeep
. 2007-11-02 17:01:48.605 Session upkeep
. 2007-11-02 17:01:49.137 Session upkeep
. 2007-11-02 17:01:49.605 Session upkeep
. 2007-11-02 17:01:50.105 Session upkeep
. 2007-11-02 17:01:50.605 Session upkeep
. 2007-11-02 17:01:51.105 Session upkeep
. 2007-11-02 17:01:51.605 Session upkeep
. 2007-11-02 17:01:52.105 Session upkeep
. 2007-11-02 17:01:52.605 Session upkeep
. 2007-11-02 17:01:53.121 Session upkeep
. 2007-11-02 17:01:53.605 Session upkeep
. 2007-11-02 17:01:54.105 Session upkeep
. 2007-11-02 17:01:54.605 Session upkeep
. 2007-11-02 17:01:55.105 Session upkeep
. 2007-11-02 17:01:55.605 Session upkeep
. 2007-11-02 17:01:56.105 Session upkeep
. 2007-11-02 17:01:56.605 Session upkeep
. 2007-11-02 17:01:57.105 Session upkeep
. 2007-11-02 17:01:57.604 Session upkeep
. 2007-11-02 17:01:58.104 Session upkeep
. 2007-11-02 17:01:58.604 Session upkeep
. 2007-11-02 17:01:59.104 Session upkeep
. 2007-11-02 17:01:59.604 Session upkeep
. 2007-11-02 17:02:00.104 Session upkeep
. 2007-11-02 17:02:00.604 Session upkeep
. 2007-11-02 17:02:01.104 Session upkeep
. 2007-11-02 17:02:01.604 Session upkeep
. 2007-11-02 17:02:02.104 Session upkeep
. 2007-11-02 17:02:02.604 Session upkeep
. 2007-11-02 17:02:03.104 Session upkeep
. 2007-11-02 17:02:03.604 Session upkeep
. 2007-11-02 17:02:04.104 Session upkeep
. 2007-11-02 17:02:04.604 Session upkeep
. 2007-11-02 17:02:05.104 Session upkeep
. 2007-11-02 17:02:05.604 Session upkeep
. 2007-11-02 17:02:06.104 Session upkeep
. 2007-11-02 17:02:06.603 Session upkeep
. 2007-11-02 17:02:07.103 Session upkeep
. 2007-11-02 17:02:07.603 Session upkeep
. 2007-11-02 17:02:08.103 Session upkeep
. 2007-11-02 17:02:08.603 Session upkeep
. 2007-11-02 17:02:09.103 Session upkeep
. 2007-11-02 17:02:09.603 Session upkeep
. 2007-11-02 17:02:10.103 Session upkeep
. 2007-11-02 17:02:10.603 Session upkeep
. 2007-11-02 17:02:11.103 Session upkeep
. 2007-11-02 17:02:11.603 Session upkeep
. 2007-11-02 17:02:12.103 Session upkeep
. 2007-11-02 17:02:12.603 Session upkeep
. 2007-11-02 17:02:13.103 Session upkeep
. 2007-11-02 17:02:13.603 Session upkeep
. 2007-11-02 17:02:14.103 Session upkeep
. 2007-11-02 17:02:14.603 Session upkeep
. 2007-11-02 17:02:15.103 Session upkeep
> 2007-11-02 17:02:15.103 PWD
. 2007-11-02 17:02:15.103 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:02:15.103 257 "/Brochure/Un test" is current directory.
. 2007-11-02 17:02:15.603 Session upkeep
. 2007-11-02 17:02:16.102 Session upkeep
. 2007-11-02 17:02:16.602 Session upkeep
. 2007-11-02 17:02:17.102 Session upkeep
. 2007-11-02 17:02:17.602 Session upkeep
. 2007-11-02 17:02:18.102 Session upkeep
. 2007-11-02 17:02:18.602 Session upkeep
. 2007-11-02 17:02:19.102 Session upkeep
. 2007-11-02 17:02:19.602 Session upkeep
. 2007-11-02 17:02:20.102 Session upkeep
. 2007-11-02 17:02:20.602 Session upkeep
. 2007-11-02 17:02:21.102 Session upkeep
. 2007-11-02 17:02:21.602 Session upkeep
. 2007-11-02 17:02:22.102 Session upkeep
. 2007-11-02 17:02:22.602 Session upkeep
. 2007-11-02 17:02:23.102 Session upkeep
. 2007-11-02 17:02:23.602 Session upkeep
. 2007-11-02 17:02:24.102 Session upkeep
. 2007-11-02 17:02:24.602 Session upkeep
. 2007-11-02 17:02:25.101 Session upkeep
. 2007-11-02 17:02:25.601 Session upkeep
. 2007-11-02 17:02:26.101 Session upkeep
. 2007-11-02 17:02:26.601 Session upkeep
. 2007-11-02 17:02:27.101 Session upkeep
. 2007-11-02 17:02:27.601 Session upkeep
. 2007-11-02 17:02:28.101 Session upkeep
. 2007-11-02 17:02:28.601 Session upkeep
. 2007-11-02 17:02:29.101 Session upkeep
. 2007-11-02 17:02:29.601 Session upkeep
. 2007-11-02 17:02:30.101 Session upkeep
. 2007-11-02 17:02:30.601 Session upkeep
. 2007-11-02 17:02:31.101 Session upkeep
. 2007-11-02 17:02:31.601 Session upkeep
. 2007-11-02 17:02:32.101 Session upkeep
. 2007-11-02 17:02:32.601 Session upkeep
. 2007-11-02 17:02:33.101 Session upkeep
. 2007-11-02 17:02:33.601 Session upkeep
. 2007-11-02 17:02:34.101 Session upkeep
. 2007-11-02 17:02:34.600 Session upkeep
. 2007-11-02 17:02:35.100 Session upkeep
. 2007-11-02 17:02:35.600 Session upkeep
. 2007-11-02 17:02:36.100 Session upkeep
. 2007-11-02 17:02:36.600 Session upkeep
. 2007-11-02 17:02:37.100 Session upkeep
. 2007-11-02 17:02:37.600 Session upkeep
. 2007-11-02 17:02:38.100 Session upkeep
. 2007-11-02 17:02:38.600 Session upkeep
. 2007-11-02 17:02:39.100 Session upkeep
. 2007-11-02 17:02:39.600 Session upkeep
. 2007-11-02 17:02:40.100 Session upkeep
. 2007-11-02 17:02:40.600 Session upkeep
. 2007-11-02 17:02:41.100 Session upkeep
. 2007-11-02 17:02:41.600 Session upkeep
. 2007-11-02 17:02:42.100 Session upkeep
. 2007-11-02 17:02:42.600 Session upkeep
. 2007-11-02 17:02:43.100 Session upkeep
. 2007-11-02 17:02:43.599 Session upkeep
. 2007-11-02 17:02:44.099 Session upkeep
. 2007-11-02 17:02:44.599 Session upkeep
. 2007-11-02 17:02:45.099 Session upkeep
> 2007-11-02 17:02:45.099 TYPE I
. 2007-11-02 17:02:45.099 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:02:45.099 200 Type set to I.
. 2007-11-02 17:02:45.599 Session upkeep
. 2007-11-02 17:02:46.099 Session upkeep
. 2007-11-02 17:02:46.599 Session upkeep
. 2007-11-02 17:02:47.099 Session upkeep
. 2007-11-02 17:02:47.599 Session upkeep
. 2007-11-02 17:02:48.099 Session upkeep
. 2007-11-02 17:02:48.599 Session upkeep
. 2007-11-02 17:02:49.099 Session upkeep
. 2007-11-02 17:02:49.599 Session upkeep
. 2007-11-02 17:02:50.099 Session upkeep
. 2007-11-02 17:02:50.599 Session upkeep
. 2007-11-02 17:02:51.099 Session upkeep
. 2007-11-02 17:02:51.599 Session upkeep
. 2007-11-02 17:02:52.099 Session upkeep
. 2007-11-02 17:02:52.598 Session upkeep
. 2007-11-02 17:02:53.098 Session upkeep
. 2007-11-02 17:02:53.598 Session upkeep
. 2007-11-02 17:02:54.098 Session upkeep
. 2007-11-02 17:02:54.598 Session upkeep
. 2007-11-02 17:02:55.098 Session upkeep
. 2007-11-02 17:02:55.598 Session upkeep
. 2007-11-02 17:02:56.098 Session upkeep
. 2007-11-02 17:02:56.598 Session upkeep
. 2007-11-02 17:02:57.098 Session upkeep
. 2007-11-02 17:02:57.598 Session upkeep
. 2007-11-02 17:02:58.098 Session upkeep
. 2007-11-02 17:02:58.598 Session upkeep
. 2007-11-02 17:02:59.098 Session upkeep
. 2007-11-02 17:02:59.598 Session upkeep
. 2007-11-02 17:03:00.098 Session upkeep
. 2007-11-02 17:03:00.598 Session upkeep
. 2007-11-02 17:03:01.098 Session upkeep
. 2007-11-02 17:03:01.598 Session upkeep
. 2007-11-02 17:03:02.097 Session upkeep
. 2007-11-02 17:03:02.160 [Background 1] TransferSocket.cpp(1179): Close() caller=0x01dc57cc
. 2007-11-02 17:03:02.160 [Background 1] FtpControlSocket.cpp(2070): TransferEnd(40) OpMode=40 OpState=19 caller=0x01d46658
. 2007-11-02 17:03:02.160 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, TRUE, 0) OpMode=40 OpState=19 caller=0x01d46658
. 2007-11-02 17:03:02.160 [Background 1] TransferSocket.cpp(108): ~CTransferSocket() caller=0x01dc57cc
. 2007-11-02 17:03:02.597 Session upkeep
. 2007-11-02 17:03:03.097 Session upkeep
. 2007-11-02 17:03:03.597 Session upkeep
. 2007-11-02 17:03:04.097 Session upkeep
. 2007-11-02 17:03:04.597 Session upkeep
. 2007-11-02 17:03:05.097 Session upkeep
. 2007-11-02 17:03:05.597 Session upkeep
. 2007-11-02 17:03:06.097 Session upkeep
. 2007-11-02 17:03:06.597 Session upkeep
. 2007-11-02 17:03:07.097 Session upkeep
. 2007-11-02 17:03:07.597 Session upkeep
. 2007-11-02 17:03:08.097 Session upkeep
. 2007-11-02 17:03:08.597 Session upkeep
. 2007-11-02 17:03:09.097 Session upkeep
. 2007-11-02 17:03:09.597 Session upkeep
. 2007-11-02 17:03:10.097 Session upkeep
. 2007-11-02 17:03:10.597 Session upkeep
. 2007-11-02 17:03:11.096 Session upkeep
. 2007-11-02 17:03:11.596 Session upkeep
. 2007-11-02 17:03:12.096 Session upkeep
. 2007-11-02 17:03:12.596 Session upkeep
. 2007-11-02 17:03:13.096 Session upkeep
. 2007-11-02 17:03:13.596 Session upkeep
. 2007-11-02 17:03:14.096 Session upkeep
. 2007-11-02 17:03:14.596 Session upkeep
. 2007-11-02 17:03:15.096 Session upkeep
> 2007-11-02 17:03:15.096 TYPE I
. 2007-11-02 17:03:15.096 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:03:15.096 200 Type set to I.
. 2007-11-02 17:03:15.596 Session upkeep
. 2007-11-02 17:03:16.096 Session upkeep
. 2007-11-02 17:03:16.596 Session upkeep
. 2007-11-02 17:03:17.096 Session upkeep
. 2007-11-02 17:03:17.596 Session upkeep
. 2007-11-02 17:03:17.846 [Background 1] Expiration du dlai dtecte !
. 2007-11-02 17:03:17.846 [Background 1] FtpControlSocket.cpp(1199): DoClose(0) OpMode=40 OpState=19 caller=0x01d46658
. 2007-11-02 17:03:17.846 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(4100) OpMode=40 OpState=19 caller=0x01d46658
. 2007-11-02 17:03:17.846 [Background 1] Copie de fichiers vers le cot distant choue.
. 2007-11-02 17:03:17.846 [Background 1] Got reply 1004 to the command 4
. 2007-11-02 17:03:18.096 Session upkeep
. 2007-11-02 17:03:18.596 Session upkeep
. 2007-11-02 17:03:19.096 Session upkeep
. 2007-11-02 17:03:19.596 Session upkeep
. 2007-11-02 17:03:19.846 [Background 1] Connexion 91.121.72.16...
. 2007-11-02 17:03:19.846 [Background 1] FtpControlSocket.cpp(1056): OnConnect(0) OpMode=1 OpState=-1 caller=0x01d46658
. 2007-11-02 17:03:19.846 [Background 1] Connect 91.121.72.16. En attente du message de bienvenue...
. 2007-11-02 17:03:19.924 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-1 caller=0x01d46658
< 2007-11-02 17:03:19.924 [Background 1] 220 Microsoft FTP Service
> 2007-11-02 17:03:19.924 [Background 1] USER isa
. 2007-11-02 17:03:19.986 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=0 caller=0x01d46658
< 2007-11-02 17:03:19.986 [Background 1] 331 Password required for isa.
> 2007-11-02 17:03:19.986 [Background 1] PASS ****
. 2007-11-02 17:03:20.033 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=3 caller=0x01d46658
< 2007-11-02 17:03:20.033 [Background 1] 230 User isa logged in.
> 2007-11-02 17:03:20.033 [Background 1] SYST
. 2007-11-02 17:03:20.064 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-14 caller=0x01d46658
< 2007-11-02 17:03:20.064 [Background 1] 215 Windows_NT
> 2007-11-02 17:03:20.064 [Background 1] FEAT
. 2007-11-02 17:03:20.095 Session upkeep
. 2007-11-02 17:03:20.111 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01d46658
< 2007-11-02 17:03:20.111 [Background 1] 211-FEAT
. 2007-11-02 17:03:20.283 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01d46658
< 2007-11-02 17:03:20.283 [Background 1] SIZE
< 2007-11-02 17:03:20.283 [Background 1] MDTM
< 2007-11-02 17:03:20.283 [Background 1] 211 END
. 2007-11-02 17:03:20.283 [Background 1] Connect
. 2007-11-02 17:03:20.283 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=1 OpState=-13 caller=0x01d46658
. 2007-11-02 17:03:20.283 [Background 1] Got reply 1 to the command 1
. 2007-11-02 17:03:20.283 [Background 1] Doing startup conversation with host.
. 2007-11-02 17:03:20.283 [Background 1] Changing directory to "/Brochure/Un test".
. 2007-11-02 17:03:20.283 [Background 1] Synchronizing current directory "/Brochure/Un test".
. 2007-11-02 17:03:20.283 [Background 1] FtpControlSocket.cpp(1269): FtpCommand(CWD /Brochure/Un test) OpMode=0 OpState=-1 caller=0x01d46658
> 2007-11-02 17:03:20.283 [Background 1] CWD /Brochure/Un test
. 2007-11-02 17:03:20.595 Session upkeep
. 2007-11-02 17:03:21.095 Session upkeep
. 2007-11-02 17:03:21.205 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d46658
< 2007-11-02 17:03:21.205 [Background 1] 250 CWD command successful.
. 2007-11-02 17:03:21.205 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d46658
. 2007-11-02 17:03:21.205 [Background 1] Got reply 1 to the command 16
. 2007-11-02 17:03:21.205 [Background 1] FtpControlSocket.cpp(1269): FtpCommand(CWD /Brochure/Un test) OpMode=0 OpState=-1 caller=0x01d46658
> 2007-11-02 17:03:21.205 [Background 1] CWD /Brochure/Un test
. 2007-11-02 17:03:21.252 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d46658
< 2007-11-02 17:03:21.252 [Background 1] 250 CWD command successful.
. 2007-11-02 17:03:21.252 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d46658
. 2007-11-02 17:03:21.252 [Background 1] Got reply 1 to the command 16
. 2007-11-02 17:03:21.252 [Background 1] Getting current directory name.
. 2007-11-02 17:03:21.252 [Background 1] FtpControlSocket.cpp(1269): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01d46658
> 2007-11-02 17:03:21.252 [Background 1] PWD
. 2007-11-02 17:03:21.298 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01d46658
< 2007-11-02 17:03:21.298 [Background 1] 257 "/Brochure/Un test" is current directory.
. 2007-11-02 17:03:21.298 [Background 1] FtpControlSocket.cpp(4184): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01d46658
. 2007-11-02 17:03:21.298 [Background 1] Got reply 1 to the command 16
. 2007-11-02 17:03:21.298 [Background 1] Startup conversation with host finished.
. 2007-11-02 17:03:21.298 [Background 1] File: "F:\Tourinter\Hotel Carayou\Vues_Aeriennes\Carayou_2_0905.jpg"
. 2007-11-02 17:03:21.298 [Background 1] Copying "F:\Tourinter\Hotel Carayou\Vues_Aeriennes\Carayou_2_0905.jpg" to remote directory started.
. 2007-11-02 17:03:21.298 [Background 1] Binary transfer mode selected.
. 2007-11-02 17:03:21.298 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(31134788, FALSE, 0) OpMode=0 OpState=-1 caller=0x01d46658
. 2007-11-02 17:03:21.298 [Background 1] Dbut de l''envoi de F:\Tourinter\Hotel Carayou\Vues_Aeriennes\Carayou_2_0905.jpg
> 2007-11-02 17:03:21.298 [Background 1] TYPE A
. 2007-11-02 17:03:21.345 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=8 caller=0x01d46658
< 2007-11-02 17:03:21.345 [Background 1] 200 Type set to A.
. 2007-11-02 17:03:21.345 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=8 caller=0x01d46658
> 2007-11-02 17:03:21.345 [Background 1] PORT 192,168,200,5,16,141
. 2007-11-02 17:03:21.377 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=7 caller=0x01d46658
< 2007-11-02 17:03:21.377 [Background 1] 200 PORT command successful.
. 2007-11-02 17:03:21.377 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=7 caller=0x01d46658
. 2007-11-02 17:03:21.377 [Background 1] TransferSocket.cpp(597): SetActive() caller=0x01db1774
> 2007-11-02 17:03:21.377 [Background 1] LIST -a
. 2007-11-02 17:03:21.439 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=9 caller=0x01d46658
< 2007-11-02 17:03:21.439 [Background 1] 150 Opening ASCII mode data connection for /bin/ls.
. 2007-11-02 17:03:21.439 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=9 caller=0x01d46658
. 2007-11-02 17:03:21.517 [Background 1] TransferSocket.cpp(418): OnAccept(0) caller=0x01db1774
. 2007-11-02 17:03:21.517 [Background 1] TransferSocket.cpp(557): OnClose(0) caller=0x01db1774
. 2007-11-02 17:03:21.517 [Background 1] TransferSocket.cpp(1179): Close() caller=0x01db1774
. 2007-11-02 17:03:21.517 [Background 1] FtpControlSocket.cpp(2070): TransferEnd(4) OpMode=40 OpState=10 caller=0x01d46658
. 2007-11-02 17:03:21.517 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, TRUE, 0) OpMode=40 OpState=10 caller=0x01d46658
. 2007-11-02 17:03:21.517 [Background 1] 11-02-07 05:03PM 13591928 Carayou_2_0905.jpg
. 2007-11-02 17:03:21.517 [Background 1] 11-02-07 04:49PM <DIR> un ne
. 2007-11-02 17:03:21.517 [Background 1] 11-02-07 04:49PM <DIR> une tte
. 2007-11-02 17:03:21.595 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=10 caller=0x01d46658
< 2007-11-02 17:03:21.595 [Background 1] 226 Transfer complete.
. 2007-11-02 17:03:21.595 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=10 caller=0x01d46658
. 2007-11-02 17:03:21.595 [Background 1] TransferSocket.cpp(108): ~CTransferSocket() caller=0x01db1774
. 2007-11-02 17:03:21.595 [Background 1] TransferSocket.cpp(1179): Close() caller=0x01db1774
. 2007-11-02 17:03:21.595 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=20 caller=0x01d46658
> 2007-11-02 17:03:21.595 [Background 1] TYPE I
. 2007-11-02 17:03:21.595 Session upkeep
. 2007-11-02 17:03:21.642 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=13 caller=0x01d46658
< 2007-11-02 17:03:21.642 [Background 1] 200 Type set to I.
. 2007-11-02 17:03:21.642 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=13 caller=0x01d46658
> 2007-11-02 17:03:21.642 [Background 1] PORT 192,168,200,5,16,143
. 2007-11-02 17:03:21.673 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=17 caller=0x01d46658
< 2007-11-02 17:03:21.673 [Background 1] 200 PORT command successful.
. 2007-11-02 17:03:21.673 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=17 caller=0x01d46658
. 2007-11-02 17:03:21.673 [Background 1] TransferSocket.cpp(597): SetActive() caller=0x01dc4bec
> 2007-11-02 17:03:21.673 [Background 1] STOR Carayou_2_0905.jpg
. 2007-11-02 17:03:21.720 [Background 1] FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=18 caller=0x01d46658
< 2007-11-02 17:03:21.720 [Background 1] 150 Opening BINARY mode data connection for Carayou_2_0905.jpg.
. 2007-11-02 17:03:21.720 [Background 1] FtpControlSocket.cpp(2107): FileTransfer(0, FALSE, 0) OpMode=40 OpState=18 caller=0x01d46658
. 2007-11-02 17:03:21.767 [Background 1] TransferSocket.cpp(418): OnAccept(0) caller=0x01dc4bec
. 2007-11-02 17:03:22.095 Session upkeep
. 2007-11-02 17:03:22.595 Session upkeep
. 2007-11-02 17:03:23.095 Session upkeep
. 2007-11-02 17:03:23.595 Session upkeep
. 2007-11-02 17:03:24.095 Session upkeep
. 2007-11-02 17:03:24.595 Session upkeep
. 2007-11-02 17:03:25.095 Session upkeep
. 2007-11-02 17:03:25.595 Session upkeep
. 2007-11-02 17:03:26.095 Session upkeep
. 2007-11-02 17:03:26.595 Session upkeep
. 2007-11-02 17:03:27.095 Session upkeep
. 2007-11-02 17:03:27.595 Session upkeep
. 2007-11-02 17:03:28.110 Session upkeep
. 2007-11-02 17:03:28.595 Session upkeep
. 2007-11-02 17:03:29.095 Session upkeep
. 2007-11-02 17:03:29.594 Session upkeep
. 2007-11-02 17:03:30.094 Session upkeep
. 2007-11-02 17:03:30.594 Session upkeep
. 2007-11-02 17:03:31.094 Session upkeep
. 2007-11-02 17:03:31.594 Session upkeep
. 2007-11-02 17:03:32.094 Session upkeep
. 2007-11-02 17:03:32.594 Session upkeep
. 2007-11-02 17:03:33.094 Session upkeep
. 2007-11-02 17:03:33.594 Session upkeep
. 2007-11-02 17:03:34.094 Session upkeep
. 2007-11-02 17:03:34.594 Session upkeep
. 2007-11-02 17:03:35.094 Session upkeep
. 2007-11-02 17:03:35.594 Session upkeep
. 2007-11-02 17:03:36.094 Session upkeep
. 2007-11-02 17:03:36.594 Session upkeep
. 2007-11-02 17:03:37.094 Session upkeep
. 2007-11-02 17:03:37.594 Session upkeep
. 2007-11-02 17:03:38.094 Session upkeep
. 2007-11-02 17:03:38.593 Session upkeep
. 2007-11-02 17:03:39.093 Session upkeep
. 2007-11-02 17:03:39.593 Session upkeep
. 2007-11-02 17:03:40.093 Session upkeep
. 2007-11-02 17:03:40.593 Session upkeep
. 2007-11-02 17:03:41.093 Session upkeep
. 2007-11-02 17:03:41.593 Session upkeep
. 2007-11-02 17:03:42.093 Session upkeep
. 2007-11-02 17:03:42.593 Session upkeep
. 2007-11-02 17:03:43.093 Session upkeep
. 2007-11-02 17:03:43.593 Session upkeep
. 2007-11-02 17:03:44.093 Session upkeep
. 2007-11-02 17:03:44.593 Session upkeep
. 2007-11-02 17:03:45.093 Session upkeep
> 2007-11-02 17:03:45.093 TYPE A
. 2007-11-02 17:03:45.093 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:03:45.093 200 Type set to A.
. 2007-11-02 17:03:45.593 Session upkeep
. 2007-11-02 17:03:46.093 Session upkeep
. 2007-11-02 17:03:46.593 Session upkeep
. 2007-11-02 17:03:47.093 Session upkeep
. 2007-11-02 17:03:47.593 Session upkeep
. 2007-11-02 17:03:48.092 Session upkeep
. 2007-11-02 17:03:48.592 Session upkeep
. 2007-11-02 17:03:49.092 Session upkeep
. 2007-11-02 17:03:49.592 Session upkeep
. 2007-11-02 17:03:50.108 Session upkeep
. 2007-11-02 17:03:50.592 Session upkeep
. 2007-11-02 17:03:51.092 Session upkeep
. 2007-11-02 17:03:51.592 Session upkeep
. 2007-11-02 17:03:52.092 Session upkeep
. 2007-11-02 17:03:52.592 Session upkeep
. 2007-11-02 17:03:53.092 Session upkeep
. 2007-11-02 17:03:53.592 Session upkeep
. 2007-11-02 17:03:54.092 Session upkeep
. 2007-11-02 17:03:54.592 Session upkeep
. 2007-11-02 17:03:55.092 Session upkeep
. 2007-11-02 17:03:55.592 Session upkeep
. 2007-11-02 17:03:56.092 Session upkeep
. 2007-11-02 17:03:56.592 Session upkeep
. 2007-11-02 17:03:57.091 Session upkeep
. 2007-11-02 17:03:57.591 Session upkeep
. 2007-11-02 17:03:58.091 Session upkeep
. 2007-11-02 17:03:58.591 Session upkeep
. 2007-11-02 17:03:59.091 Session upkeep
. 2007-11-02 17:03:59.591 Session upkeep
. 2007-11-02 17:04:00.091 Session upkeep
. 2007-11-02 17:04:00.591 Session upkeep
. 2007-11-02 17:04:01.091 Session upkeep
. 2007-11-02 17:04:01.591 Session upkeep
. 2007-11-02 17:04:02.091 Session upkeep
. 2007-11-02 17:04:02.591 Session upkeep
. 2007-11-02 17:04:03.091 Session upkeep
. 2007-11-02 17:04:03.591 Session upkeep
. 2007-11-02 17:04:04.091 Session upkeep
. 2007-11-02 17:04:04.591 Session upkeep
. 2007-11-02 17:04:05.091 Session upkeep
. 2007-11-02 17:04:05.591 Session upkeep
. 2007-11-02 17:04:06.090 Session upkeep
. 2007-11-02 17:04:06.590 Session upkeep
. 2007-11-02 17:04:07.090 Session upkeep
. 2007-11-02 17:04:07.590 Session upkeep
. 2007-11-02 17:04:08.090 Session upkeep
. 2007-11-02 17:04:08.590 Session upkeep
. 2007-11-02 17:04:09.090 Session upkeep
. 2007-11-02 17:04:09.590 Session upkeep
. 2007-11-02 17:04:10.090 Session upkeep
. 2007-11-02 17:04:10.590 Session upkeep
. 2007-11-02 17:04:11.090 Session upkeep
. 2007-11-02 17:04:11.590 Session upkeep
. 2007-11-02 17:04:12.090 Session upkeep
. 2007-11-02 17:04:12.590 Session upkeep
. 2007-11-02 17:04:13.090 Session upkeep
. 2007-11-02 17:04:13.590 Session upkeep
. 2007-11-02 17:04:14.090 Session upkeep
. 2007-11-02 17:04:14.590 Session upkeep
. 2007-11-02 17:04:15.090 Session upkeep
> 2007-11-02 17:04:15.090 TYPE A
. 2007-11-02 17:04:15.090 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:04:15.090 200 Type set to A.
. 2007-11-02 17:04:15.589 Session upkeep
. 2007-11-02 17:04:16.089 Session upkeep
. 2007-11-02 17:04:16.589 Session upkeep
. 2007-11-02 17:04:17.089 Session upkeep
. 2007-11-02 17:04:17.589 Session upkeep
. 2007-11-02 17:04:18.089 Session upkeep
. 2007-11-02 17:04:18.589 Session upkeep
. 2007-11-02 17:04:19.089 Session upkeep
. 2007-11-02 17:04:19.589 Session upkeep
. 2007-11-02 17:04:20.089 Session upkeep
. 2007-11-02 17:04:20.589 Session upkeep
. 2007-11-02 17:04:21.089 Session upkeep
. 2007-11-02 17:04:21.589 Session upkeep
. 2007-11-02 17:04:22.089 Session upkeep
. 2007-11-02 17:04:22.589 Session upkeep
. 2007-11-02 17:04:23.089 Session upkeep
. 2007-11-02 17:04:23.589 Session upkeep
. 2007-11-02 17:04:24.089 Session upkeep
. 2007-11-02 17:04:24.588 Session upkeep
. 2007-11-02 17:04:25.088 Session upkeep
. 2007-11-02 17:04:25.588 Session upkeep
. 2007-11-02 17:04:26.088 Session upkeep
. 2007-11-02 17:04:26.588 Session upkeep
. 2007-11-02 17:04:27.088 Session upkeep
. 2007-11-02 17:04:27.588 Session upkeep
. 2007-11-02 17:04:28.088 Session upkeep
. 2007-11-02 17:04:28.588 Session upkeep
. 2007-11-02 17:04:29.088 Session upkeep
. 2007-11-02 17:04:29.588 Session upkeep
. 2007-11-02 17:04:30.088 Session upkeep
. 2007-11-02 17:04:30.588 Session upkeep
. 2007-11-02 17:04:31.088 Session upkeep
. 2007-11-02 17:04:31.588 Session upkeep
. 2007-11-02 17:04:32.088 Session upkeep
. 2007-11-02 17:04:32.588 Session upkeep
. 2007-11-02 17:04:33.088 Session upkeep
. 2007-11-02 17:04:33.588 Session upkeep
. 2007-11-02 17:04:34.087 Session upkeep
. 2007-11-02 17:04:34.587 Session upkeep
. 2007-11-02 17:04:35.087 Session upkeep
. 2007-11-02 17:04:35.587 Session upkeep
. 2007-11-02 17:04:36.087 Session upkeep
. 2007-11-02 17:04:36.587 Session upkeep
. 2007-11-02 17:04:37.087 Session upkeep
. 2007-11-02 17:04:37.587 Session upkeep
. 2007-11-02 17:04:38.087 Session upkeep
. 2007-11-02 17:04:38.587 Session upkeep
. 2007-11-02 17:04:39.087 Session upkeep
. 2007-11-02 17:04:39.587 Session upkeep
. 2007-11-02 17:04:40.087 Session upkeep
. 2007-11-02 17:04:40.587 Session upkeep
. 2007-11-02 17:04:41.087 Session upkeep
. 2007-11-02 17:04:41.587 Session upkeep
. 2007-11-02 17:04:42.087 Session upkeep
. 2007-11-02 17:04:42.587 Session upkeep
. 2007-11-02 17:04:43.086 Session upkeep
. 2007-11-02 17:04:43.586 Session upkeep
. 2007-11-02 17:04:44.086 Session upkeep
. 2007-11-02 17:04:44.586 Session upkeep
. 2007-11-02 17:04:45.086 Session upkeep
> 2007-11-02 17:04:45.086 TYPE A
. 2007-11-02 17:04:45.086 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:04:45.086 200 Type set to A.
. 2007-11-02 17:04:45.586 Session upkeep
. 2007-11-02 17:04:46.086 Session upkeep
. 2007-11-02 17:04:46.586 Session upkeep
. 2007-11-02 17:04:47.086 Session upkeep
. 2007-11-02 17:04:47.586 Session upkeep
. 2007-11-02 17:04:48.086 Session upkeep
. 2007-11-02 17:04:48.586 Session upkeep
. 2007-11-02 17:04:49.086 Session upkeep
. 2007-11-02 17:04:49.586 Session upkeep
. 2007-11-02 17:04:50.086 Session upkeep
. 2007-11-02 17:04:50.586 Session upkeep
. 2007-11-02 17:04:51.086 Session upkeep
. 2007-11-02 17:04:51.586 Session upkeep
. 2007-11-02 17:04:52.085 Session upkeep
. 2007-11-02 17:04:52.585 Session upkeep
. 2007-11-02 17:04:53.085 Session upkeep
. 2007-11-02 17:04:53.585 Session upkeep
. 2007-11-02 17:04:54.085 Session upkeep
. 2007-11-02 17:04:54.585 Session upkeep
. 2007-11-02 17:04:55.085 Session upkeep
. 2007-11-02 17:04:55.585 Session upkeep
. 2007-11-02 17:04:56.085 Session upkeep
. 2007-11-02 17:04:56.585 Session upkeep
. 2007-11-02 17:04:57.085 Session upkeep
. 2007-11-02 17:04:57.585 Session upkeep
. 2007-11-02 17:04:58.085 Session upkeep
. 2007-11-02 17:04:58.585 Session upkeep
. 2007-11-02 17:04:59.085 Session upkeep
. 2007-11-02 17:04:59.585 Session upkeep
. 2007-11-02 17:05:00.085 Session upkeep
. 2007-11-02 17:05:00.585 Session upkeep
. 2007-11-02 17:05:01.085 Session upkeep
. 2007-11-02 17:05:01.584 Session upkeep
. 2007-11-02 17:05:02.084 Session upkeep
. 2007-11-02 17:05:02.584 Session upkeep
. 2007-11-02 17:05:03.084 Session upkeep
. 2007-11-02 17:05:03.584 Session upkeep
. 2007-11-02 17:05:04.084 Session upkeep
. 2007-11-02 17:05:04.584 Session upkeep
. 2007-11-02 17:05:05.084 Session upkeep
. 2007-11-02 17:05:05.584 Session upkeep
. 2007-11-02 17:05:06.084 Session upkeep
. 2007-11-02 17:05:06.584 Session upkeep
. 2007-11-02 17:05:07.084 Session upkeep
. 2007-11-02 17:05:07.584 Session upkeep
. 2007-11-02 17:05:08.084 Session upkeep
. 2007-11-02 17:05:08.584 Session upkeep
. 2007-11-02 17:05:09.084 Session upkeep
. 2007-11-02 17:05:09.584 Session upkeep
. 2007-11-02 17:05:10.084 Session upkeep
. 2007-11-02 17:05:10.583 Session upkeep
. 2007-11-02 17:05:11.083 Session upkeep
. 2007-11-02 17:05:11.583 Session upkeep
. 2007-11-02 17:05:12.083 Session upkeep
. 2007-11-02 17:05:12.583 Session upkeep
. 2007-11-02 17:05:13.083 Session upkeep
. 2007-11-02 17:05:13.583 Session upkeep
. 2007-11-02 17:05:14.083 Session upkeep
. 2007-11-02 17:05:14.583 Session upkeep
. 2007-11-02 17:05:15.083 Session upkeep
> 2007-11-02 17:05:15.083 REST 0
. 2007-11-02 17:05:15.083 FtpControlSocket.cpp(878): OnReceive(0) OpMode=0 OpState=-1 caller=0x01d64c04
< 2007-11-02 17:05:15.083 350 Restarting at 0.
. 2007-11-02 17:05:15.583 Session upkeep
. 2007-11-02 17:05:16.083 Session upkeep
. 2007-11-02 17:05:16.583 Session upkeep
. 2007-11-02 17:05:17.083 Session upkeep
. 2007-11-02 17:05:17.583 Session upkeep
. 2007-11-02 17:05:18.083 Session upkeep
. 2007-11-02 17:05:18.583 Session upkeep
. 2007-11-02 17:05:19.083 Session upkeep
. 2007-11-02 17:05:19.582 Session upkeep
. 2007-11-02 17:05:20.082 Session upkeep
. 2007-11-02 17:05:20.582 Session upkeep
. 2007-11-02 17:05:21.082 Session upkeep
. 2007-11-02 17:05:21.582 Session upkeep
. 2007-11-02 17:05:22.082 Session upkeep
. 2007-11-02 17:05:22.582 Session upkeep
. 2007-11-02
fiddlerdave
This looks like my problem I had. I was trying to download 4.4 gb Mandriva 2006.4 from Mandriva server (password connection, I bought the paid package). I downloaded the latest Winscp 12/25/07(after a failure with IE ftp)and after some stalls where the connection remained but the download stopped (restart download with or without WinSCP restart and resume worked OK, but when after 10 hours, it got to 99% and counting down the last kBs, there was a very brief error flash (something about error from server but too quick to read), then it restarted the download from 0% without any input or hesitation, this all in a matter of 1 or 2 seconds. This happened twice, I believe, before I was sitting there to watch it. It has been a long 3 days.
Windows XP professional, downloading directly onto 16 gig free NTFS disk with (no drag n drop to avoid a temp file - main drive is FAT32) using Norton interface gui in FTP, Passive on.
Last log session (I believe the 99% error restart happened at "2007-12-27 14:29:38.265 Timeout detected."):
2007-12-27 13:36:48.265 --------------------------------------------------------------------------
. 2007-12-27 13:36:48.265 WinSCP Version 4.0.5 (Build 354) (OS 5.1.2600 Service Pack 2)
. 2007-12-27 13:36:48.265 Login time: Thursday, December 27, 2007 1:36:48 PM
. 2007-12-27 13:36:48.265 --------------------------------------------------------------------------
. 2007-12-27 13:36:48.265 Session name: noname@abc.com@download.mandriva.com
. 2007-12-27 13:36:48.265 Host name: download.mandriva.com (Port: 21)
. 2007-12-27 13:36:48.265 User name: noname@abc.com(Password: Yes, Key file: No)
. 2007-12-27 13:36:48.265 Tunnel: No
. 2007-12-27 13:36:48.265 Transfer Protocol: FTP
. 2007-12-27 13:36:48.265 Ping type: C, Ping interval: 30 sec; Timeout: 40 sec
. 2007-12-27 13:36:48.265 Proxy: none
. 2007-12-27 13:36:48.265 FTP: Passive: Yes
. 2007-12-27 13:36:48.265 Local directory: D:\mandriva 2008, Remote directory: /pub/2008.0/isos/i586, Update: Yes, Cache: Yes
. 2007-12-27 13:36:48.265 Cache directory changes: Yes, Permanent: Yes
. 2007-12-27 13:36:48.265 DST mode: 1
. 2007-12-27 13:36:48.296 Connecting to download.mandriva.com ...
. 2007-12-27 13:36:48.453 Connected with download.mandriva.com. Waiting for welcome message...
< 2007-12-27 13:36:48.609 220 ProFTPD 1.2.10 Server ready.
> 2007-12-27 13:36:48.609 USER noname@abc.com
< 2007-12-27 13:36:48.781 331 Password required for noname@abc.com.
> 2007-12-27 13:36:48.781 PASS *******
< 2007-12-27 13:36:51.312 230 User noname@abc.comlogged in.
> 2007-12-27 13:36:51.312 SYST
< 2007-12-27 13:36:51.468 215 UNIX Type: L8
> 2007-12-27 13:36:51.468 FEAT
< 2007-12-27 13:36:51.625 211-Features:
< 2007-12-27 13:36:51.625 MDTM
< 2007-12-27 13:36:51.781 REST STREAM
< 2007-12-27 13:36:51.781 SIZE
< 2007-12-27 13:36:51.781 AUTH GSSAPI
< 2007-12-27 13:36:51.781 ADAT
< 2007-12-27 13:36:51.781 PBSZ
< 2007-12-27 13:36:51.781 PROT
< 2007-12-27 13:36:51.781 ENC
< 2007-12-27 13:36:51.781 MIC
< 2007-12-27 13:36:51.781 CONF
< 2007-12-27 13:36:51.781 CCC
< 2007-12-27 13:36:51.781 211 End
. 2007-12-27 13:36:51.781 Connected
. 2007-12-27 13:36:51.781 --------------------------------------------------------------------------
. 2007-12-27 13:36:51.781 Using FTP protocol.
. 2007-12-27 13:36:51.781 Doing startup conversation with host.
> 2007-12-27 13:36:51.781 PWD
< 2007-12-27 13:36:51.937 257 "/" is current directory.
. 2007-12-27 13:36:51.937 Changing directory to "/pub/2008.0/isos/i586".
> 2007-12-27 13:36:51.937 CWD /pub/2008.0/isos/i586
< 2007-12-27 13:36:52.093 250 CWD command successful
. 2007-12-27 13:36:52.093 Getting current directory name.
> 2007-12-27 13:36:52.093 PWD
< 2007-12-27 13:36:52.250 257 "/pub/2008.0/isos/i586" is current directory.
. 2007-12-27 13:36:52.250 Retrieving directory listing...
> 2007-12-27 13:36:52.250 TYPE A
< 2007-12-27 13:36:52.406 200 Type set to A
> 2007-12-27 13:36:52.406 PASV
< 2007-12-27 13:36:52.562 227 Entering Passive Mode (212,85,147,126,233,94).
> 2007-12-27 13:36:52.562 LIST -a
< 2007-12-27 13:36:52.875 150 Opening ASCII mode data connection for file list
< 2007-12-27 13:36:53.031 226 Transfer complete.
. 2007-12-27 13:36:53.046 Directory listing successful
. 2007-12-27 13:36:53.046 Startup conversation with host finished.
. 2007-12-27 13:36:53.093 Disconnected from server
. 2007-12-27 13:37:04.781 File: "/pub/2008.0/isos/i586/mandriva-linux-2008.0-pwp-dvd-i586.iso"
. 2007-12-27 13:37:04.781 Copying "/pub/2008.0/isos/i586/mandriva-linux-2008.0-pwp-dvd-i586.iso" to local directory started.
. 2007-12-27 13:37:04.796 Binary transfer mode selected.
. 2007-12-27 13:37:04.796 Starting download of /pub/2008.0/isos/i586/mandriva-linux-2008.0-pwp-dvd-i586.iso
. 2007-12-27 13:37:04.796 Asking user:
. 2007-12-27 13:37:04.796 Local file 'mandriva-linux-2008.0-pwp-dvd-i586.iso' already exists. Overwrite?
. 2007-12-27 13:37:04.796 New: 4596914176 bytes, 10/5/2007 10:00:00 PM
. 2007-12-27 13:37:04.796 Existing: 3632441828 bytes, 12/27/2007 1:36:05 PM ()
> 2007-12-27 13:37:06.828 TYPE I
< 2007-12-27 13:37:06.984 200 Type set to I
> 2007-12-27 13:37:06.984 PASV
< 2007-12-27 13:37:07.140 227 Entering Passive Mode (212,85,147,126,233,95).
> 2007-12-27 13:37:07.140 REST 3632441828
< 2007-12-27 13:37:07.296 350 Restarting at 3632441828. Send STORE or RETRIEVE to initiate transfer
> 2007-12-27 13:37:07.296 RETR mandriva-linux-2008.0-pwp-dvd-i586.iso
< 2007-12-27 13:37:07.609 150 Opening BINARY mode data connection for mandriva-linux-2008.0-pwp-dvd-i586.iso (964472348 bytes)
. 2007-12-27 14:29:38.265 Timeout detected.
. 2007-12-27 14:29:38.265 Copying files from remote side failed.
. 2007-12-27 14:29:38.359 Connection was lost, asking what to do.
. 2007-12-27 14:29:38.359 Asking user:
. 2007-12-27 14:29:38.359 Lost connection. ("Timeout detected.","Copying files from remote side failed.","Opening BINARY mode data connection for mandriva-linux-2008.0-pwp-dvd-i586.iso (964472348 bytes)")
. 2007-12-27 14:29:43.406 Connecting to download.mandriva.com ...
. 2007-12-27 14:29:43.578 Connected with download.mandriva.com. Waiting for welcome message...
< 2007-12-27 14:29:43.734 220 ProFTPD 1.2.10 Server ready.
> 2007-12-27 14:29:43.734 USER noname@abc.com
< 2007-12-27 14:29:43.953 331 Password required for noname@abc.com.
> 2007-12-27 14:29:43.953 PASS *******
< 2007-12-27 14:29:46.640 230 User noname@abc.comlogged in.
> 2007-12-27 14:29:46.640 SYST
< 2007-12-27 14:29:46.796 215 UNIX Type: L8
> 2007-12-27 14:29:46.796 FEAT
< 2007-12-27 14:29:46.953 211-Features:
< 2007-12-27 14:29:46.953 MDTM
< 2007-12-27 14:29:47.093 REST STREAM
< 2007-12-27 14:29:47.093 SIZE
< 2007-12-27 14:29:47.109 AUTH GSSAPI
< 2007-12-27 14:29:47.109 ADAT
< 2007-12-27 14:29:47.109 PBSZ
< 2007-12-27 14:29:47.109 PROT
< 2007-12-27 14:29:47.109 ENC
< 2007-12-27 14:29:47.109 MIC
< 2007-12-27 14:29:47.109 CONF
< 2007-12-27 14:29:47.109 CCC
< 2007-12-27 14:29:47.109 211 End
. 2007-12-27 14:29:47.109 Connected
. 2007-12-27 14:29:47.109 Doing startup conversation with host.
. 2007-12-27 14:29:47.109 Changing directory to "/pub/2008.0/isos/i586".
. 2007-12-27 14:29:47.109 Synchronizing current directory "/pub/2008.0/isos/i586".
> 2007-12-27 14:29:47.109 CWD /pub/2008.0/isos/i586
< 2007-12-27 14:29:47.265 250 CWD command successful
> 2007-12-27 14:29:47.265 CWD /pub/2008.0/isos/i586
< 2007-12-27 14:29:47.421 250 CWD command successful
. 2007-12-27 14:29:47.421 Getting current directory name.
> 2007-12-27 14:29:47.421 PWD
< 2007-12-27 14:29:47.578 257 "/pub/2008.0/isos/i586" is current directory.
. 2007-12-27 14:29:47.578 Startup conversation with host finished.
. 2007-12-27 14:29:47.609 File: "/pub/2008.0/isos/i586/mandriva-linux-2008.0-pwp-dvd-i586.iso"
. 2007-12-27 14:29:47.609 Copying "/pub/2008.0/isos/i586/mandriva-linux-2008.0-pwp-dvd-i586.iso" to local directory started.
. 2007-12-27 14:29:47.609 Binary transfer mode selected.
. 2007-12-27 14:29:47.609 Starting download of /pub/2008.0/isos/i586/mandriva-linux-2008.0-pwp-dvd-i586.iso
> 2007-12-27 14:29:47.609 TYPE A
< 2007-12-27 14:29:47.765 200 Type set to A
> 2007-12-27 14:29:47.765 PASV
< 2007-12-27 14:29:47.921 227 Entering Passive Mode (212,85,147,126,233,157).
> 2007-12-27 14:29:47.921 LIST -a
< 2007-12-27 14:29:48.234 150 Opening ASCII mode data connection for file list
< 2007-12-27 14:29:48.390 226 Transfer complete.
> 2007-12-27 14:29:48.390 TYPE I
< 2007-12-27 14:29:48.546 200 Type set to I
> 2007-12-27 14:29:48.546 PASV
< 2007-12-27 14:29:48.703 227 Entering Passive Mode (212,85,147,126,233,158).
> 2007-12-27 14:29:48.734 RETR mandriva-linux-2008.0-pwp-dvd-i586.iso
< 2007-12-27 14:29:49.046 150 Opening BINARY mode data connection for mandriva-linux-2008.0-pwp-dvd-i586.iso (4596914176 bytes)
. 2007-12-27 14:30:11.875 Download aborted
. 2007-12-27 14:30:11.953 Terminated by user.
< 2007-12-27 14:30:11.953 451 Transfer aborted. Broken pipe
> 2007-12-27 14:30:18.546 TYPE A
< 2007-12-27 14:30:18.546 200 Type set to A
> 2007-12-27 14:30:48.375 TYPE A
< 2007-12-27 14:30:48.875 200 Type set to A
> 2007-12-27 14:31:18.375 PWD
< 2007-12-27 14:31:18.875 257 "/pub/2008.0/isos/i586" is current directory.
> 2007-12-27 14:31:48.375 TYPE I
< 2007-12-27 14:31:48.875 200 Type set to I
> 2007-12-27 14:32:18.375 TYPE A
< 2007-12-27 14:32:18.875 200 Type set to A
> 2007-12-27 14:32:48.375 PWD
< 2007-12-27 14:32:48.875 257 "/pub/2008.0/isos/i586" is current directory.
> 2007-12-27 14:33:18.375 REST 0
< 2007-12-27 14:33:18.875 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
> 2007-12-27 14:33:48.375 REST 0
< 2007-12-27 14:33:48.875 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
> 2007-12-27 14:34:18.375 TYPE I
< 2007-12-27 14:34:18.875 200 Type set to I
> 2007-12-27 14:34:48.375 REST 0
< 2007-12-27 14:34:48.875 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
< 2007-12-27 14:35:11.875 421 No Transfer Timeout (300 seconds): closing control connection.
. 2007-12-27 14:35:11.875 Disconnected from server
* 2007-12-27 14:35:11.875 (ESshFatal) Lost connection.
* 2007-12-27 14:35:11.875 Terminated by user.
* 2007-12-27 14:35:11.875 Disconnected from server
* 2007-12-27 14:35:11.875 No Transfer Timeout (300 seconds): closing control connection.
fiddlerdave
An error - I am downloading Mandriva 2008.0, not 2006!
And I am now at 85% using Free Download Manager, keeping my fingers crossed (although I got ATT to get my DSL back up to 3 Mbs, so its only 4 hours instead of 10 hours for each try!). I will post those results - perhaps WinSCP is perfect! I hope to find what happened with WinSCP, I would hate to mess with several FTP programs, Winscp is so straightforward, its great when I am coaching someone else over the phone to do the input for me at a remote location.
I cannot tell why the connection was interrupted. But it definitely looks strange that WinSCP has restarted download from zero. I'll check that. It may be a problem with 4GB boundary.
Julien Nitard
I ve got the same issue, but not only with "large" files (12MB).
Ithinkt that's because the FTPserver is closing down the connection right after download completes.
I can see the popup "the server closed the connection" with a count down to restart ... But on restart the download overwrites everything.
Thanks in advance,
Julien
Julien Nitard wrote:
I ve got the same issue, but not only with "large" files (12 MB).
I thinkt that's because the FTP server is closing down the connection right after download completes.
Please post a log file.
julien.nitard
Oh yeah, and what happened during the session :
Firt, I download a small file that gets downloaded well.
Then I download a larger file. There is an interruption, and the download is successfully resumed and reaches its end. I see the popup that asks me if I want to reconect but has a timer. The timer completes, the download restarts from the beginning.
Thanks for your help.
It seems that the web server is down. I will try later.
julien.nitard
It is down indeed. I ll try to host that elsewhere.
OK, let me know then.
