Topic "connect to an other machine"
Klaus
how can I connect to an other machine via winscp? Normaly I use putty and I use following way:
ssh myname@machine1
ssh myname@machine2
ssh myname@machine3
because I cant connect directly to machine3. Can I use winscp for such a procedure? At the terminal window I cant execute commands that require user-inputs, but I must put my name and the password to connect via putty to connect the other machines.
Thank in advance.
Klaus
This is not possible with SCP/SFTP. You may try to use SSH port forwarding, but I've never tried, so I cannot give you any advice.
You may also read topic ssh connection over firewall.
