Topic "Error accessing IBM 4690 server..."
parkerfly5150
I've been trying to access an IBM 4690 server using WinSCP's SFTP from a WinXP SP2 PC and receive the error... "Error listing directory 'c:'. I was using a previous version of WinSCP (not sure how many levels back) but then upgraded to the latest 4.0.5 (Build 354) and received the same results. I've tried changing Remote Directories and protocol versions to no avail. Using a command-line SFTP program such as PSFTP from Putty works just fine. Is this a known issue or could it be investigated?
While researching this error online, I've noticed that several SSH/SFTP clients either list a fix for 4690 in their version change logs or have an existing issue which may provide some insight.
SecureCRT - http://www.vandyke.com/products/securecrt/history.txt
SecureFT - http://www.censoft.com/support/kb/?cat=57
RoboFTP - http://www.robo-ftp.com/ftp-history.php
Here is an excerpt from the log file. Please let me know if you need more info.
. 2007-10-31 11:55:00.623 Getting current directory name.
. 2007-10-31 11:55:00.623 Listing directory "c:".
> 2007-10-31 11:55:00.623 Type: SSH_FXP_OPENDIR, Size: 11, Number: 13579
> 2007-10-31 11:55:00.623 0B,00,00,35,0B,00,00,00,02,63,3A,
. 2007-10-31 11:55:00.623 Sent 15 bytes
. 2007-10-31 11:55:00.623 There are 0 bytes remaining in the send buffer
. 2007-10-31 11:55:00.623 Looking for network events
. 2007-10-31 11:55:00.623 Timeout waiting for network events
. 2007-10-31 11:55:00.623 Waiting for another 4 bytes
. 2007-10-31 11:55:00.623 Looking for incoming data
. 2007-10-31 11:55:00.810 Detected network event
. 2007-10-31 11:55:00.810 Enumerating network events for socket 808
. 2007-10-31 11:55:00.810 Enumerated 32 network events for socket 808
. 2007-10-31 11:55:00.810 Detected network close event on socket 808 with error 0
. 2007-10-31 11:55:00.810 Selecting events 0 for socket 808
. 2007-10-31 11:55:00.810 Server unexpectedly closed network connection
* 2007-10-31 11:55:00.810 (ESshFatal) Server unexpectedly closed network connection.
* 2007-10-31 11:55:00.810 Error listing directory 'c:'.
Thank you!
Can you see anything useful in the server's log file?
