Topic "Winscp script hangs when wrong .ini session password used"
chli24
Hi!
I'm facing the same problem as in:
http://winscp.net/forum/viewtopic.php?t=1859
I have a script that uses a .ini stored session and when the stored password is wrong for some reason (e.g. expired, changed), the script hangs since winscp prompts for a new correct password.
Is there any winscp" scripting solution to this problem?
My script:
option batch on
open <stored session>
option transfer ascii
cd old
get <remote file> <local file>
close
The last line in the log file:
2007-11-05 09:26:45.532 Session password prompt (<user>@<ip>s password: )
One possible solution is that I introduce an own timeout in my program that execute the winscp script. But I would like to have a more generic solution.
Thanks in advance
/Christian
chli24
Sorry, latest version, 4.05 (Build 354).
Additional information:
To simulate wrong password/force error, I modified the Password field in the winscp.ini file (removed one char) for the Session I'm using in the script.
The password has not been changed on the remote server.
I did this for testing purpose.
