Topic "can we use syndelete option to delete files on remote dir"
tong
hi ,
i have try to synchronize a local and remote dir, it works perfectly.
but i will like to perform a delete on the remote dir after this syn, so as to safe space on the remote dir. can we do it using scripting?
i try to use syndelete but it does not work, not sure if i do it correctly, please advice, thanks
So you want to download all the files from remote server and delete them afterwards?
Just use get and rm then.
tong
hmmm... but the file names at the remote dir are randomly generated, can get and rm support *.* ?
tong
thanks prikryl, I check already, winscp do support wildcat mask, thanks alot.
autourdupc
I had this problem for other job...
You can make a script that list the directory, and put this list into the command file of winSCP.
Then, launch WinSCP with this command file.
see http://winscp.net/forum/viewtopic.php?t=4688
Best regards,
Laurent.
guest
if you are using get and rm what happens if a file is created in the folder after the get and before the rm?
What do you think? Smile
BTW, the next version will support "get /delete".
