Topic "ssh connection over firewall"
Mario_m
Is it possible connect to a server by ssh over a firewall.
In Putty I connect to a local machine by telnet and then I set the command:ssh -CX servername. Is it possible to do that with WinSCP?
I have found a solution. So my configuration looks like this:
A-LocalPC -> B-PassthroughServer -> C-Firewall -> D-Server
There is no direct connection to the D-Server from my A-LocalPC. Only by the B-PassthtroughServer there is a SSH connection to D-Server and a SSH connection from the A-LocalPC to the B-PassthroughServer.
So I take the plink.exe utility from the putty project and create a SSH tunnel to the D-Server Server. Open a Dos Box and type the following command:
plink.exe -ssh passthrougserver -l username -pw password -L 666:D-Server:22
(Port 666 is an imagine local Port of your PC so make sure the port is not used by another application, use a port scanner instead)
Please check that your Dos Box has connected to the passthrougserver. You will see a command prompt. The port should always be connected during the SCP session
Then start WinSCP separately. Make a new session and type localhost as hostname and 666 as portname. Use the username and password as you would normally use for the D-Server.
Now you have a direct tunnel. You can do the same using the last putty release instead of using plink.exe. Just create a new tunnel configuration and start WinSCP
Thanks so much! This was *very* helpful! Mr. Green
You can also read FAQ covering the topic.
