Topic "remember state of synchronized directory changes"
nullbarriere
see subject Smile
it would be nice, if WinSCP could remember the last active state of the synchronized directory changes feature, if possible on a per session basis
What state do you mean?
nullbarriere
State means (this means "I mean by using the word state") wheter the feature is activated or not.
To give your the (my) idea: I work with different projects, some of which are cms directory structures, which require the using of the feature "synchronized directory changes" frequently if not constantly, other project doesnt require the featur since the dir structures locally and remotely doesnt match. So i would welcome the possibility of having either a) a config checkbox "synchronized directory changes on/off" or b) a config checkbox ("remember state of synchronized directory changes") for every saved session.
It's just a tiny thing, but it would help me, and perhaps others who work with cms directory structures, save the ever-same extra click to enable the feature on all the cms sessions.
IMHO it is not a tiny thing, but a basic feature needed all the time when syncing directories. Please make WinSCP remember that setting.
OK, added to TODO list Smile
nullbarriere
Thank you prikryl for your quick response and your great piece of software (forgot to mention this before).
and thank you unknown guest for backing this
stanman
This would indeed be great! I'm using winscp for quite some time now and it has become one of my daily software. It's great, my compliments. If this feature would be built in, it makes it soo much easier. Keep up the good work!
zero
Seconded! Would make things much easier. Thanks for adding it to the wishlist.
nullbarriere
Please keep us informed about the proceedings of this "issue". Thank you.
zero
Since it's been a while:
any chance this feature will make it into an upcoming version?
Hardly. Sorry.
zero
Sad
