Topic "Displaying time duration of copying files"
ThomasW
is there a way in WinSCP (I use version 3.6.8) to display the total time duration taken for copying files; if yes, how?
Of course "time elapsed" is displayed during the copy process. But afterwards, i. e. after finishing the copy process, the copy dialog suddenly disappears and the information about the total time needed for copying the files is lost.
Thanks for all good hints.
Thomas Wiedmann
What would you use the information for?
ThomasW
Sometimes there a large files to be copied using WinSCP. So it takes time until the copy process is finished and I don't like to observe the copy dialog permanently. Therefore it would be interesting to know the total time of copying large files after a copy process (to assume the time duration for other copy processes with large files)
Thomas Wiedmann
"Time estimated" shows you what you need, doesn't it?
Where can I find this info message "Time estimated", i. e. where it is displayed?
Thomas Wiedmann
On transfer progress window, left of time elapsed. You have to have Calculate total size option enabled (what is default).
