Topic "Error message "could not rename filename""
El rollo
Smile Great software, keep up the good work. I have a problem transferring to a ssh.com server. When a file is copied there an error message appears: "could not overwrite filename". It copies the file sucessfully to the remote server but adds a .filepart extension to the file.
eg. test.txt appears as test.txt.filepart
Any ideas?
Cheers El
Please post a log file. Try also different protocol (SCP/SFTP).
El Rollo
Hi Martin,
I tried using SFTP/SCP and SFTP only, SSH1, 2 etc same message. It looks like a permissions issue yet the local admin copied files into the target directory using my login no problems at all. He was using an expensive ssh.com client.
Here is the log file:
. WinSCP Version 3.1.0 (Build 165)
. Login time: Tuesday, 29 July 2003 8:57:05 a.m.
. Session name: SHXXX@144.X.X.X
. Host name: 144.X.X.X (Port: 22)
. User name: SHXXX (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. SSH protocol version: 1; Compression: Yes
. Agent forwarding: Yes; TIS/CryptoCard: Yes; KI: Yes
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: SOCKS
. HostName: 10.X.X.X (Port: 2022); Username: ; Passwd: No
. SOCKS Version: 5
. Shell: default, EOL: 1
. Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. Alias LS: No, Ign LS warn: Yes, Scp1 Comp: Yes
. Looking up host "144.X.X.X"
. Connecting to 144.X.X.X port 22
. Server version: SSH-2.0-3.2.0 SSH Secure Shell Windows NT Server
. We claim version: SSH-2.0-PuTTY-Local: Jul 14 2003 13:14:02
. Host key fingerprint is:
. ssh-dss 2048 cf:e8:86:7a:5d:09:18:6c:2e:00:ef:8d:88:7d:1c:97
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
! Using username "SHXXX".
. Sent password
! Access denied
. Access denied
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 34, Number: -1
> Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< Type: SSH_FXP_NAME, Size: 23, Number: 16
. Listing directory "/".
> Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
< Type: SSH_FXP_HANDLE, Size: 17, Number: 267
> Type: SSH_FXP_READDIR, Size: 17, Number: 524
< Type: SSH_FXP_NAME, Size: 115, Number: 524
> Type: SSH_FXP_READDIR, Size: 17, Number: 780
< Type: SSH_FXP_STATUS, Size: 22, Number: 780
> Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
< Type: SSH_FXP_STATUS, Size: 21, Number: 1028
. Startup conversation with host finished.
. Changing directory to "HNFTP".
> Type: SSH_FXP_REALPATH, Size: 15, Number: 1296
< Type: SSH_FXP_NAME, Size: 35, Number: 1296
> Type: SSH_FXP_OPENDIR, Size: 16, Number: 1547
< Type: SSH_FXP_HANDLE, Size: 17, Number: 1547
> Type: SSH_FXP_CLOSE, Size: 17, Number: 1796
< Type: SSH_FXP_STATUS, Size: 21, Number: 1796
. Listing directory "/HNFTP".
> Type: SSH_FXP_OPENDIR, Size: 15, Number: 2059
< Type: SSH_FXP_HANDLE, Size: 17, Number: 2059
> Type: SSH_FXP_READDIR, Size: 17, Number: 2316
< Type: SSH_FXP_NAME, Size: 423, Number: 2316
> Type: SSH_FXP_READDIR, Size: 17, Number: 2572
< Type: SSH_FXP_STATUS, Size: 22, Number: 2572
> Type: SSH_FXP_CLOSE, Size: 17, Number: 2820
< Type: SSH_FXP_STATUS, Size: 21, Number: 2820
. Changing directory to "ToHNA".
> Type: SSH_FXP_REALPATH, Size: 21, Number: 3088
< Type: SSH_FXP_NAME, Size: 45, Number: 3088
> Type: SSH_FXP_OPENDIR, Size: 21, Number: 3339
< Type: SSH_FXP_HANDLE, Size: 17, Number: 3339
> Type: SSH_FXP_CLOSE, Size: 17, Number: 3588
< Type: SSH_FXP_STATUS, Size: 21, Number: 3588
. Listing directory "/HNFTP/ToHNA".
> Type: SSH_FXP_OPENDIR, Size: 21, Number: 3851
< Type: SSH_FXP_HANDLE, Size: 17, Number: 3851
> Type: SSH_FXP_READDIR, Size: 17, Number: 4108
< Type: SSH_FXP_NAME, Size: 541, Number: 4108
> Type: SSH_FXP_READDIR, Size: 17, Number: 4364
< Type: SSH_FXP_STATUS, Size: 22, Number: 4364
> Type: SSH_FXP_CLOSE, Size: 17, Number: 4612
< Type: SSH_FXP_STATUS, Size: 21, Number: 4612
. Copying 1 files/directories to remote directory "/HNFTP/ToHNA/"
. PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No; FnCs: N; Resume: S (10240)
. TM: B; AscM: *.*htm*; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. File: "C:\Documents and Settings\dXX\Desktop\56k_scripts.hqx"
. Copying "C:\Documents and Settings\dXX\Desktop\56k_scripts.hqx" to remote directory started.
. Binary transfer mode selected.
. Checking existence of file.
> Type: SSH_FXP_LSTAT, Size: 37, Number: 4871
< Type: SSH_FXP_STATUS, Size: 105, Number: 4871
. Error status: 2, Message: 4871, Server: syserr: No such file or directory, file: D:\advertising\ToHNA\56k_scripts.hqx, Language: en
. Checking existence of partially transfered file.
> Type: SSH_FXP_LSTAT, Size: 46, Number: 5127
< Type: SSH_FXP_STATUS, Size: 114, Number: 5127
. Error status: 2, Message: 5127, Server: syserr: No such file or directory, file: D:\advertising\ToHNA\56k_scripts.hqx.filepart, Language: en
. Opening remote file.
> Type: SSH_FXP_OPEN, Size: 54, Number: 5379
< Type: SSH_FXP_HANDLE, Size: 17, Number: 5379
> Type: SSH_FXP_WRITE, Size: 4125, Number: 5638
. 55 skipped SSH_FXP_WRITE, SSH_FXP_READ and SSH_FXP_STATUS packets.
> Type: SSH_FXP_REALPATH, Size: 46, Number: 13072
< Type: SSH_FXP_NAME, Size: 95, Number: 13072
> Type: SSH_FXP_RENAME, Size: 78, Number: 12818
< Type: SSH_FXP_STATUS, Size: 106, Number: 12818
. Error status: 3, Message: 12818, Server: syserr: Permission denied, file: D:\advertising\ToHNA\56k_scripts.hqx.filepart, Language: en
* (ETerminal) Permission denied.
* Error code: 3
* Error message from server: syserr: Permission denied, file: D:\advertising\ToHNA\56k_scripts.hqx.filepart (en)
* Request code: 18
. Asking user:
. Transfer was succesfully finished, but temporary transfer file '56k_scripts.hqx.filepart' could not be renamed to target file name '56k_scripts.hqx'. ("Permission denied.
. Error code: 3
. Error message from server: syserr: Permission denied, file: D:\advertising\ToHNA\56k_scripts.hqx.filepart (en)
. Request code: 18")
> Type: SSH_FXP_CLOSE, Size: 17, Number: 13316
< Type: SSH_FXP_STATUS, Size: 21, Number: 13316
* (EScpSkipFile) Transfer was succesfully finished, but temporary transfer file '56k_scripts.hqx.filepart' could not be renamed to target file name '56k_scripts.hqx'.
* Permission denied.
* Error code: 3
* Request code: 18
> Type: SSH_FXP_OPENDIR, Size: 21, Number: 13579
< Type: SSH_FXP_HANDLE, Size: 17, Number: 13579
> Type: SSH_FXP_READDIR, Size: 17, Number: 13836
< Type: SSH_FXP_NAME, Size: 684, Number: 13836
> Type: SSH_FXP_READDIR, Size: 17, Number: 14092
< Type: SSH_FXP_STATUS, Size: 22, Number: 14092
> Type: SSH_FXP_CLOSE, Size: 17, Number: 14340
< Type: SSH_FXP_STATUS, Size: 21, Number: 14340
. Deleting file "56k_scripts.hqx.filepart".
> Type: SSH_FXP_REMOVE, Size: 46, Number: 14605
< Type: SSH_FXP_STATUS, Size: 21, Number: 14605
. Deleting file "Announcment S Collis.pdf.filepart".
> Type: SSH_FXP_REMOVE, Size: 55, Number: 14861
< Type: SSH_FXP_STATUS, Size: 21, Number: 14861
. Deleting file "Digital Specs for CTP v1.2.pdf.filepart".
> Type: SSH_FXP_REMOVE, Size: 61, Number: 15117
< Type: SSH_FXP_STATUS, Size: 21, Number: 15117
> Type: SSH_FXP_OPENDIR, Size: 21, Number: 15371
< Type: SSH_FXP_HANDLE, Size: 17, Number: 15371
> Type: SSH_FXP_READDIR, Size: 17, Number: 15628
< Type: SSH_FXP_NAME, Size: 207, Number: 15628
> Type: SSH_FXP_READDIR, Size: 17, Number: 15884
< Type: SSH_FXP_STATUS, Size: 22, Number: 15884
> Type: SSH_FXP_CLOSE, Size: 17, Number: 16132
< Type: SSH_FXP_STATUS, Size: 21, Number: 16132
. Closing connection.
Cheers
El
SCP does not work too? It should, because it does not rename file after transfer, because it does not support 'transfer resuming'.
