Topic "enable creation of customised commands"
wacky
it will be very nice to be able to create customised commands...
for example i can have a script or command that takes a file and automatically run the script/command with the file... afterall it is possible to execute commands using Ctrl-T to Open Terminal...
so it will be nice if we can define some commands like:
checkout <filename>
and we can assign this customised command to the pop-up menu such that i can right-click on a file and run our command with that filename...
regards,
wacky
Good idea.
guest
checkout <filename>
regards,
wacky
yes, can this extend the command line feature to support "commands that require user input" as the warning states in that window? Then i dont have to switch between putty and this to run simple tar.gz opterations and downloading them with winscp
thanks
