Topic "UNC paths are not supported"
Awgan
Hi there,
I have strange problem with WINSCP 4.0.5 (newest if I recall).
Whenever I Try to log on I get message "UNC paths are not supported" but :
1) I've red forum/docs and tried all workarounds ...
2) I have pointed local directory as "u:\" which is a mapped home dir on domain controller (message still appears);
3) I have tried to point to "c:\temp" directory which is on local drive with rw rights for this particular user (same message)
any idea ?
Can I have an email contact to you?
Caspa
Hello there,
I have the same problem with winscp 4.0.5, cai i have a solution please ?
awgan
l.stankiewicz on server spray.pl
knkk
I am having the same problem - not able to access folders on other machines in the LAN. Can you please help? Thanks. kishorek at gmail dot com
WinSCP does not support browsing UNC paths.
