Topic "How to auto-convert text file carriag returns WinXP-to-Linux"
pstein
I dragged a text file (shell script) created under WinXP from WinExplorer onto WinSCP and uploaded it to a Linux system.
Because Linux system treat Carriage Returns different
from the handling under Win systems a conversion is necessary.
How can I tell WinSCP to automatically convert
these eol bytes in the text file to the necessary Linux bytes when transferring?
Please read documentation.
pstein
So if I understand all corrently it depends on the extension of the file. If I up-/download a file
with one of the listed extensions then an auto-conversion took place.
But what if I upload a file with NO extension?
How can I specify: transfer all files with NO extension as ASCII with auto-conversion ?
Furthermore I miss (espcially for the no-extension files) a feature which peeks into the real content of the files.
If this is more likely a text file then the file should be transferred as ASCII otherwise as BIN.
Is there a content-inspection+decision option or
only simple extension-only decision-making ?
Peter
Quote:
Is there a content-inspection+decision option?
No.
