Topic "Ftp uploading issue"
Blakmagik
How do i upload a file to a site and get it to show? Because my website doesn't work because the home page (and other files) aren't set up to work with it properly... How and where do i upload them on my sites server to get it to run properly without any issues? Question Question Question
blakmagikforums.3host.biz
See? Not working is it?? I have my files on the server though...
Go spontaneously combust and implode you butt pirate!!!
It's likely a server configuration and/or files permission problem.
If you have uploaded an index.htm or index.html or default.htm or whatever your server considers the "default" file for directories, and if the web server is configured not to allow default listings, then your files are probably not readable by the web server user account. In this case uploading the files and specifying "set permissions" to rw-r--r-- (+x) may fix the problem.
If the web server is configured to allow default directory listings, then the problem is that the directory from which your web page is being served is not readable by the web server user account. Correcting that will require changing the permissions on the directory that acts as / for your website, or changing the web server configuration.
Or it could be any number of other issues, but start with those. None of these are problems with WinSCP itself.
